Question about Water Heaters
Gulfstream kingsport rv 2009 - Water Heaters
How do i replace the power cord in an rv that has been cut off
3 wire cord or 4 wire cord?
3 wire would be normally 120 volts
4 wires would be 240 volts
don't know if that would be common in an RV? If 120, is it 15 amp or 20 amp?
Again, would not know if 20 A would be found in an RV? If 20 A you would have one position in the cord - Sideways.
Any with the presumption 120 Volt - Same for either 15A or 20 A , Black wire onto Gold lug.
White wire onto Silver lug.
Green wire onto Green lug
if 220, comment back
May 30, 2015 | Atwood GCH10A-4E GCH10A4E Gas and Electric...
Tankless water heater for 2006 gulfstream cavalier travel trailer
What you really need to know is what the maximum flow rate and at what temperature you need. These do not store water, they heat it as it passes through.
Apr 09, 2014 | Water Heaters
Need free owners manual for a 2002 Gulfstream Classic RV
http://gulfstreamrvtrailers.com/contact-gulfstream.php
Aug 01, 2013 | Water Heaters
Fleetwood rv 2009
Copy following link to identify valve:
http://waterheatertimer.org/Repair-water-heater-valve.html
Add a comment and give more specific information, and add what you have tried so far.
Jul 16, 2013 | Water Heaters
Last year we had all the siding on our tv, trailer, replaced due to hail damage. When we finally got our trailer back from the rv repair shop we have had nothing but problems with our Atwood hot water tank...
Immediate danger!
You have a gas leak.
Propane is heavier than air and will settle on the floor.
The floor can be covered and ignite and you will not smell it while standing or sitting or laying in bed.
Absolutely open the door and leave trailer. Turn off the gas to the heater if the shut-off is outside.
Possibly you have a bad gas control valve. This should be repaired professionally.
Aug 08, 2012 | Water Heaters
What does DSI mean when referring to RV water heaters?
D.S.I. = Direct Spark Ignition. You would have a 12 volt switch inside RV, that when turned to ON, will ignite water heater automatically, provided ignition module and rest of components are there, or come with new water heater. Otherwise you would have to go outside with a lighter/matches or whatever and manually start the water heater.
Oct 22, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
We can not locate the switch for the hot water heatr in our 2009 Fleetwood Terra LX Morothome, can we get a manual for this unit?
Wall by kitchen counter, or end of kitchen counter, near cabinet or counter on same side of motorhome as water heater, as well as a switch on the monitor panel itself. Some hide them on underside of kitchen cabinets as well.
Jul 12, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Hot Water Heater in 1991 Pace Arrow RV is not working
If you look on the outside of the RV, you will find the vent for the water heater behind and access door. There usually is a drain plug and valve located as well. Generally they will be tucked away under the kitchen sink area with internal access as well. You will need to find where the valve that shuts the water off to the unit is and turn it on. Most times the water heater is either electric or propane. But sometimes they are only propane. Once your find the access door, you will know where the water heater is. You can also contact Fleetwood who makes the Pace Arrow to see if they have any information on your unit. Usually your unit info or trim number will be located on a little plaque right by the entrance to the RV. You will need this when you contact them. Hope this helps.
Mar 31, 2009 | Water Heaters
I need a service manual for Atwood 2001 series RV LP gas detect
Call one of the motor home supplier and you will be able to get it.
Mar 30, 2009 | RTO Atwood Water Heater - 6 Gal LP
Water Heaters Logo
13 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
