Question about Health & Beauty
Rascal 329le mobility scooter
Just purchased rascal 329 le have had it charging and got a red light on charger and flashing green light will green light stay on when fully charged
  • 23 Answers
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
Posted on May 06, 2010
mcdevito75
  • 1970 Answers
SOURCE: Battery full on Ascot Mobility scooter but wont start
mcdevito75 here, Double chek the connection at the battery and motor.
Posted on Jun 26, 2010
wcdoc1953
  • 278 Answers
SOURCE: please find users manual for Rascal 329 LE
The following link may be helpful for the users manual for your rascal scooter:
http://www.rascalscooters.com/manuals/300_manual.pdf
You can also call the manufacturer and they will send you one. The manufacturer is
Electric mobility at 1-800-MOBILITY or 800-662-4548. Hope this helps.
Posted on Nov 23, 2010
  • 692 Answers
SOURCE: Low hour, RASCAL 600
The green light on your charger indicates a full charge but you know thats not right since you didn't charge the batteries when they were in storage they have dropped so low the charger cannot detect them and provide a charge. The batteries will need to be replaced with new ones. Charge before use and charge for at least 20 days to get them operating at 100% now you will have to use it for those 20 days to get the batteries used to charging charge every night when you go to bed and unplug when you get up in the morning. If you do have to leave the chair for a week or so put up fully charged and charge once a week overnight. If you put the chair in storage again disconnect the batteries from the chair and store with a full charge. Hope this helps you
Posted on May 08, 2011
gfreed100
  • 60 Answers
SOURCE: can I over charge my mobility scooter batteries with a pihsiang charger the green light wont go solid
Take the batteries to a battery shop or a Battery plus store have them load test the batteries. Deep cycle batteries are different from normal batteries. Normal batteries are design for max output for short periods of time, Deep cycle batteries are designed for a modest output for long periods of time. My batteries are rated at 35 amp/hr.. Basically a load tester places a load in amps [cranking amps] on the battery. How many cranking amps depends on if there is a voltage drop when you apply the load. I can apply 480 cranking amps before my voltage drops. What i do is load test a new battery of the same type to find out the cranking amps. You will not find a cranking amp rating for aq deep cycle battery but retail places have load testers that read in cranking amps. Use only deep cycle batteries in scooters, garden tracker batteries will not last. If the batteries are ok test the charger. A CHARGER KNOWS THE CHARGE OF THE BATTERY BY BATTERY RESISTANCE. As a battery charges its resistance get bigger. Once the battery reaches a preset resistance the light goes solid. You can have the charger checked by a battery shop. To properly charge a battery a charger will put out 27volts @ 4amps, they can easily test for voltage. Now if the charger is built in there is going to be an external fuse find it, check it. hope this helps
Posted on Jun 09, 2012
Rascal 329LE working OK but constant beeping. Not the flashing indicators or hazard flashers. What else should I check?
Shortage on wiring.. or your pc board is defective. Start by evaluating your head light and pc board.
Aug 25, 2016 | Health & Beauty
Red lite flashes when i plug it in
I can only guess that the batteries need replaced .
Sep 05, 2015 | Rascal Auto Go 550 Portable Power Scooter...
How to change batteries in a Rascal
The Rascal 600/300, remove the seat, lift off the cover, unplug a battery, replace the old battery with a new one, putting the cable connections on the same way, red is +, black is -. Do the same with the next battery, reconnect the anderson plugs,reinstall the cover and seat and plug in the charger with the key on watch to see the needle raises up toward the full mark, allow to charge fully, overnight is good. keep the bats charged up not allowing them to drop below half way for the first 20 charges to break in the batteries. as a rule charge the scooter after every use!
Scooter Doctor App
Jun 29, 2014 | Rascal 300 Electric Scooter - Used...
My dads mobility scooter wont go and the two light on the black box under the seat are not on .
A blown charging circuit fuse? The fuse may be under a floor hatch and mat and not feature in the manual - that turned out to be the case with a Pride Mobility scooter.
Jun 03, 2014 | Pride Health & Beauty
My Rascal 329LE wont move and the light flashes 7 times on the dash
Hello please visit:-www.alldatasheet.com its free and you can download as a PDF File what you require.have a nice day Colin.
Feb 22, 2011 | Health & Beauty
Please find users manual for Rascal 329 LE disabled scooter
Nov 22, 2010 | Electric Health & Beauty
I just got a pre owned rascal 329le scooter and i need to replace the tyres< but i can not read the size on the original tyre as they scuffed and badly damaged
Your best bet is to call the manufacturer and give them the model and serial number if available. They will give you the tire and wheel size and a local dealer to purchase from. The Rascal is manufactured by Electric Mobility at 1-800-MOBILITY.
Aug 25, 2010 | Health & Beauty
I have just purchased a secondhand Rascal 329le Mobility Scooter but there is no instruction manual. Where can I get one please?
Hi
Contact your local Dealer and ask for a Photo Copy of the Manual which can be sent to you via an attachment file in your email or your home address,
Gerry,
Aug 11, 2010 | Health & Beauty
Electric mobility Rascal 265 LE scooter won't run 24 volts dc on batteries no sound or movement
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
May 02, 2009 | Electric Mobility Mobility Electric Power...
Health & Beauty Logo
24 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
