Question about Motorola Mobility HS820 Consumer Headset
Hs820 light stays on
When you charge the hs820 the light goes out... when you unplug it the light comes on right then and will do nothing until battery goes dead..the device was working before..i use it with a moto. v551phone..any help would be very much app...
Same problem with mine...
there is no solution for that, I've had the same problem a year ago... and it's a useless unit... there's no solution and there are a lot of Hs820 with this problem....
This headset is a piece of sh** !!
Posted on Dec 12, 2007
SOURCE:
My droid 2 is not recognizing the motorola hs820 bluetooth device; I have no info on how to set the hs820 to pair
I think I can help here:
Make sure your headset and phone are charged before doing anything else. The blue light on your headset will come on when it is charging, and will shut off when fully charged.
To put your headset in pairing mode, make sure it is completely off first (no blinking blue light). Then hold down the Call button for 6-10 seconds until the blue light stays on. (It will likely flash once and shut off, but keep holding until it is all the way on and stays there!)
From there, go into the settings on your Droid 2 and access the bluetooth connections. Do a new scan for your headset if you don't see it listed, pair, and connect!
http://www.motorola.com/mdirect/manuals/QG-HS820_9494A71A.pdf
Feb 23, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
After charging my HS820, the light stays on, no matter what I do, and it is supposed to be in sync mode, but it won't sync with my Samsung, but my other Motorola headsets do!
You need to disconnect it from the charger and keep the button pressed to put it in pairing mode, then associate with the phone with the PIN 0000.
Jan 29, 2010 | Motorola Mobility HS820 Consumer Headset
Does not charge!!!
hi..the best solution to this problem is that
replacing the old battery to a new one.It could
be your battery problem.It may have some fault
in it.so go for a new one.
try this out..
thank u..
rate me..
Feb 09, 2009 | Motorola Mobility HS820 Consumer Headset
Blue light on
i opened it,the upper part does not detach completely but slides,the blue light turned off finally but then on pressing the button nothing happened.Now i'm charging the battery and the blue light is on as usual so i hope it's just out of energy and it will work again when recharge will be finished:)
Aug 21, 2008 | Motorola Mobility HS820 Consumer Headset
Light always ON!!!
hold the button and wait till the light blinks twice and it will turn off
Jan 29, 2008 | Motorola Mobility HS820 Consumer Headset
Motorola hs820
I am having the same proble too..I am going to open it up and see if I can fix it, I'll keep u guys posted...
Blazemorefire..
Oct 09, 2007 | Motorola Mobility HS820 Consumer Headset
My Phone Does Not Locate My HS820 Headset
Try the following:
1) Make sure the HS820 is fully charged up.
2) Remove the battery and SIM card from your phone for about 1 minute and put them back in.
3) As soon as your phone is booted up, access the "find devices" function for adding your HS820.
4) Hold the HS820 button down until the blue light is solid.
5) Then do whatever your phone requres to "search for devices."
6) Here's the key: as the phone is searching for devices, PHYSICALLY TOUCH touch the HS820 to the phone.
I couldn't get my HS820 to synch with my new Blackberry Curve the normal way and ultimately got it to synch by going through this process.
Sep 11, 2007 | Motorola Mobility HS820 Consumer Headset
Motorola HS820
the always on light mens that it is in pairing mode and wont go out until it has paired with a phone, if you wish to turn it off, press and hold for 3 seconds, it will then flash 3 times and then go off. Try pairing again by pressing and holding the button until the light stays on.
Jul 10, 2007 | Motorola Mobility HS820 Consumer Headset
Samsung e900 pairing
if you press the power button and hold until the blue light stays on the set is then in find mode, at this point use your phone to search for new devices and when it finds it it will see the HS820 and probably ask for a pin number this is 0000, when they are paired the blue light will flash and then flash intermitently from then on.
May 26, 2007 | Motorola Mobility HS820 Consumer Headset
Light stays on
This sound like you have it constantly in pairing mode(this is when light is always on)
Dec 14, 2006 | Motorola Mobility HS820 Consumer Headset
Motorola Mobility HS820 Consumer Headset Logo
108 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
