Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
Black Line down center of screen
For the past week I have had a 1.5" solid black line runnning vertically down the center of the TV screen.  Sometimes it will go away for 2-3 hours, but the frequency of which it is occurring keeps increasing.  How can I get rid if this line?  Is the TV shot?  It is only 2 years old.
  • Anonymous Nov 09, 2007
    I have the same problem with my hitachi. I took it in to get repaired and was told it was the panel which would cost at least $2,000 to repair.
  • Mike 2342 Dec 15, 2007
    I have an intermittent Black line down the centre of my TV, and I have taken no steps to resolve the problem.
I have the exact same problem, I was told however that it was a ribbon wire. You can find wires for your television on ebay for approx. 35-40 bucks, or you can just take your tv to someone have them order it for 100 and fix it for 1000. However I do recomend that you have someone do it that knows what they're doing, because it is a very complicated process to change one of these said wires.
Posted on Jan 18, 2009
Had the same problem.  Was quoted $800 to fix.  Searched the internet for 6 months and found this thread on avforums.com
http://www.avforums.com/forums/showthread.php?t=462873&highlight=black+line+on+plasma&page=4
Read through all the posts.  Very simple fix, but you have to have some mechanical inclinations or you can cause more problems than you started with.  I was up to 5 of the black lines, but decided to attempt the soldering these guys did and fixed it all for the cost of a soldering iron!
Posted on Oct 12, 2007
SOURCE:
Lcd tv vertical line
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 26, 2016 | RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV...
Panasonic plasma 1 solid black vertical line left of center
faint chance here, the larger or thicker the line the worse it is. Usually this is a defect inside the panel where it cannot be gotten at---rarely this will be a plug or connection outside of the panel.
The screen unit or display panel costs more than the set did new.
Sep 01, 2012 | Panasonic Televison & Video
Thin coloured lines running down center of tv. Panasonic Viera.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP TO SOLVE THE PROBLEM.....
Aug 07, 2011 | Panasonic Televison & Video
I have a black line on the tv samsung
Hope this help......
Jun 22, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
1" black vertical line in center of screen. Sony Plasma.
NOT DEFECTIVE!!!
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable2_bing.gifnear the black lines. Unplug the ribbon cable and look for black chipson the underside of it, I think they say 100 on them, you need toresolder both ends on each chip. Should fix the black line issue.
Aug 19, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Black line in centr of Screen
sounds like a bad panel, try reseating any cables you can on the buffers . the buffers would be on the lower edge right where the black line appears. unfortunately Vizio does not supply panels.
E
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jul 28, 2009 | Televison & Video
Vertical black line on the screen of my 42" Magnavox flat panel lcd tv
I wish I could post a solution, but I don't have one. I too have a Magnavox. About 6 months ago, once every 2 weeks or so, the screen would just go black- all but an inch or two on either side. Now, it seems like it's a weekly thing, sometimes every hour or two. As of tonight, it has happened twice in a matter of thirty minutes. It usually repairs itself if I turn it on and then off again but that's just not working anymore. If anyone has a solution, let me know.
Oct 10, 2008 | Televison & Video
Black line down the center of the tv wont go away
Sorry, justindorval;
I did not complete my questions.
4. Does line move when the channels are changed?
Good luck, big IRISH. ps let me know, I'll more happy to help you.
Jul 19, 2008 | Televison & Video
did you fix the black line? please let me know as my TV (same model) has the same problem.
Jul 14, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black line in center of screen
These black lines on the plasma screens are very fixable.  There is a dry solder joint on a circuit board at the bottom of the plasma that needs resoldered.  There are 6 or 7 "ribbons" along the bottom of the screen that correspond to vertical sections of the display, so you just follow the black vertical line down to figure out which one is faulty.  I just performed this fix successfully on my first attempt on a Gateway plasma, but it will work on most plasma's, specifically Hitachi, gateway, LG, Hyundai, & Akai. I think they may all have LG boards, my gateway did.
I can't really describe very well what to do, but I assure you it is fixable.  If anyone is near nashville, I might be able to help you out.  My email is [email protected]
thanks,
ST
Jan 18, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
388 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
