Question about GE Spacemaker JVM1640SJ Microwave Oven
Both lights on JVM1642AB blew. Replaced bulbs, still don't light.
Both work surface lights on my GE JVM1642AB blew within a few days of each other, the second one before I had a chance to get the first one replaced. When the second one blew, I heard a loud popping sound. Both bulbs broke off in their sockets and were very discolored. I replaced the bulbs, but they still do not work. I know this microwave is 10 years old, but everything else still works on it. Is there anything I can do to get the lights to work?
    New Friend:
  • 160 Answers
Something wrong on the curcuit board, to much voltage
Posted on May 08, 2009
All three lights on my microwave ge model 1800 do not work. Is there a common fuse or something
suggest you go back to 10 amp globes and check that the fuse is good
Jan 01, 2015 | GE Microwave Ovens
I have a GE micro ange hood Model# HVM1540DM1BB, bulbs blew,change them out, now the lights will not shut off. I have powered it down over night, pluged it back in next morning same thing. Any ideas
There is a possibility that the light relay is stuck on. Sometimes a sharp tap on the relay will fix it. If not the control board will need replacing.
Sep 26, 2014 | GE Microwave Ovens
Changed the light bulbs in my ge jvm315 and know the surface light will not turn off ?
This sounds like the control board also called a smart board in some models has to be replaced.
May 02, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
Replace the burned-out
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
the bulb by gently turning.
4 Replace the screw.
Connect electrical power
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light,
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
to the oven.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
When i plug in the microwave it starts running & will not stop
Sounds like you blew a device on the main board when you didn't unplug it first. The whole main timer board must be replaced to repair the unit. Pricey, sorry!!
Aug 01, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
The vent fan and surface light do not work
1. Check your circuit breaker for this m/w. Reset it.
2. Microwaves usually have 20A fuse inside. It could be broken.
Dec 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Surface Lights
The control circuits for the cooktop lights and the hood fan are spearate. The problem is indeed with the control unit. It's usually caused by either the filaments shorting when the lamp blows or by removing or installing the bulbs while the oven is still plugged into the power line. We regularly repair these nationwide for $32.50. Details of our service, as well as *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Spacemaker oven, Model JVM240
That would almost certainly be a problem on the control circuit board. If the bulbs happen to short / blow out or if they are removed or installed while the microwave is still plugged in, there is often an arc which causes damage to the board. We repair regularly these boards for such problems for $32.50 nationwide.
Dec 23, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
300 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
