Question about Panasonic Lands Phones
Panasonic kx-tc1000bxb pulse dialing
How to change panasonic kx-tc1000bxb to pulse dialing? how to change panasonic kx-tc100-B to pulse dialing?
4 Suggested Answers
SOURCE: Dialing mode option change.
Program --> Auto --> ** --> Program (Pulse to DTMF)
Program --> Auto --> ## --> Program (DTMF to Pulse)
Posted on Dec 22, 2007
  • 66 Answers
SOURCE: Hello, could you please help me with my panasonic
The owner/user manual should have instructions on how to accomplish this. I take it that you no longer have the manual, so you'll have to root around in the phone's settings (you may have to access the tone/pulse setting from the base unit), to select the desired dialing mode. On some older phones (including cordless), the tone/pulse selection is a physical switch on the base unit (on the top/bottom/side/back). Look carefully... I hope I've helped you!
Posted on Aug 13, 2009
SOURCE: Panasonic KX-A115CE changing pulse to tone dialing
Can anyone tell me how to change it? There is an option ''Setting Base'' on the handset and when I enter it it says ''Input Command'' but I have no idea what should be entered.
Thanks a lot!
Posted on Jan 27, 2010
Selecting dialing mode
The directions for changing the dialing mode from tone to pulse can be found in the owner's manual for the main base unit.
Press the [MENU] button then choose "Set tel line". Then choose "Set dial mode", then choose Pulse or Tone and press [OK].
Additional details can be found in the below link.
http://service.us.panasonic.com/OPERMANPDF/KXTG1031.PDF#page=14
Jun 28, 2014 | Panasonic KX-TGA101S Cordless Handset
Changing from pulse to tone panasonic phone
Touch the following keys: Menu 0 5 1 and then select 1 (tone, the factory default) or 2. Then Save (a softkey with the label in the LCD screen) and Off (opposite Talk on the keypad).
The manual for the Panasonic KX-TG5664 is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/KXTG5664.PDF . See page 17 for setting the Dialing mode.
I hope this helps.
Apr 06, 2013 | Panasonic Lands Phones
My KX-T7030 phone will not send a tone during a call, so I cannot "Press 1" or any number to use automated options. It does dial numbers ok??
If it dials O.K., try pressing # and see if it turns on the DTMF pad. You could have pulse dial on outside calls enabled, and that would keep the keypad in pulse mode until it's told to send tones.
This is really only a guess. The type of dialing is programmed in CO trunks and it's possible it's been set to Call Blocking! It is designed to send pulse only and block the audio of DTMF so the CO won't get confused. You might start with changing the Type Dial to DTMF and test. If that doesn't work, try Pulse and test. Last, if that doesn't work, you will need to keep call blocking and try the # after dialing.
Please comment back if it does or doesn't work. We don't see much pulse dial around here.
Carl
Dec 09, 2009 | Panasonic KX-T7730 Corded Phone
Both phones have no dial tone and don't work - could it be because they don't support digital?
Hi, Welcome to FixYa.
The cordless phones supports pulse dialing than tone now a days.
If your provider supports pulse dialing & tone you can just change the tone to pulse to use cordless phone. Otherwise you have to request for pulse dialing from your provider.
We appreciate your feedback; it will help us improve this Web site.
Please select 'YES' if satisfied.
Jul 08, 2009 | Panasonic KX-TG2352 Cordless Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Panasonic KX-FT71 dial lock by gobuzer
needed to reset,
press menu,#9000*550 and start,is all.
Feb 18, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Change pulse into tone
Go to the menu and choose Tel line and the go to set dial mode and then choose the dial mode like dial or pulse mode
Nov 22, 2008 | Panasonic KX-TG2631 Cordless Phone
Panasonic cordless phone KX-TG6052
reset the dial mode if it is on tone and you have pulse it will not dial out.
Feb 08, 2008 | Panasonic KX-TG6052B Phone
Jul 30, 2007 | Panasonic KX-TGA101S Cordless Handset
Lands Phones Logo
111 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
