Question about Westward 1VER1 Infrared Thermometer Range -27 To 230 F
Change C to F westward 1ver1
Would like to change temperature display from Celsius reading to Fahrenheit reading
Sub zero FREEZER temperature display is all of a sudden -22 in lieu of the usual -5. is it possible that somehow it has switched to celsius? if so, how do I change it back to farenheit? Model 601F/F
These instruction are from the site below:
To convert the temperatures from Fahrenheit (°F) to Celsius (°C) readings:
  • Turn the unit off then back on again using the unit on/off button.
  • Within one minute of turning the unit back on, press and hold the door ajar alarm bell ON/OFF key and the UNIT ON/OFF key simultaneously for 5 seconds.
  • Release the keys and "°C" will appear on the LCD indicating that temperatures will now be displayed in Celsius units of measure.
  • To convert back to Fahrenheit units of measure, repeat the steps above. "°F" displayed will confirm Fahrenheit units of measure.
  • Refer to the product use and care guide for further information.
  • Note:
    • Temperature Units Selection must be performed within the first minute after switching the unit ON.
    • Model 427R will require temperature conversion for both the upper wine storage zone and the refrigerator drawers separately.
Without a bell on / off button on the control panel, it is not possible to change the temperature display.
400 600 700 Series Temperature Conversion
Jan 29, 2015 | Refrigerators
How do I change the oven temp from celcius to farenheiton my Maytag Advanced System Model #MGR5710ADW
try unplugging range. If it does not return to F display
You can try this: Hold either timer keys down on power up. The right digit will display "F" or "C". The temperature display can be toggled from C to F by pushing the Broil key.
or
Press cancel and bake buttons simultaneously for 3-5 seconds until C appears then use up/down buttons to change to Fahrenheit.
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/66531-switch-celsius-fahrenheit.html#ixzz37a4SP964
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/66531-switch-celsius-fahrenheit.html#ixzz37a4C5UH2
Jul 15, 2014 | Whirlpool Gold GW399LXU Gas Range
How to change from Celsius to Fahrenheit
To convert degrees C to degrees F, Multiply the Centigrade temperature by 9, then divide by 5, then add 32
Or, degrees F= (9/5 degrees C) + 32
Here's link to website which explains difference between Fahrenheit & Centigrade scales, & how to convert between them:
http://www.mathsisfun.com/temperature-conversion.html
Jul 11, 2014 | 1996 Buick Park Avenue
Changing the external temperature gauge from Fahrenheit to Celsius
If your temperature reads in climate control reads in degrees Celsius "C" instead of Fahrenheit "F", follow these steps to change to Fahrenheit.
  • Turn the ignition on.
  • With the climate control turned on, push and hold the recirculation button in. While holding the button in, push and hold the off button in for 3 seconds or until you hear a beep.
The display should then change to "F". Follow these same steps to change your read-out to Celsius , if preferred.
Sep 21, 2012 | 2005 Land Rover LR3
How do I change the temperature reading from Celsius to Fahrenheit?
with the switch in the 'lock' position, hit the C/F button (also labeled as the 'min' & 'date' button)
Dec 30, 2011 | Elgin Travel Alarm Clock
Croc only heats up to 230 degrees is there a way to reset it
CHANGE TEMPERATURE SETTING from CELSIUS to FAHRENHEIT
To Change the Temperature Setting from CELSIUS [230 Degrees] to FAHRENHEIT [450 Degrees]
If [230] appears on the display screen, then the temperature is set to Celsius. To change back to Fahrenheit:
1. Turn off your flat iron and unplug from electrical socket (wait for 10secs).
2. Then plug the iron back into the electrical socket.
3. Press & hold down the HIGH [?]button, then press ON/OFF button. An "F" will appear on the digital screen. Your device is now in Fahrenheit mode.
Jul 23, 2011 | Crocs Croc 2 Flat Iron Titanium Plates 1"
The stove is stuck on celsius. I pressed and held the CANCEL AND BAKE buttons for 3 seconds and nothing happens. I don't know how it got on celsius. How do I get it back on Fahrenheit?
You can get Whirlpool manuals from http://www.whirlpool.com/custserv/index.jsp
Just got it from there:
The temperature is preset at Fahrenheit, but can be changed to
Celsius.
Style 1 - Electronic Oven Control
To change: Press and hold PRECISE CLEAN for 5 seconds, and
"TEMPERATURE UNIT CELSIUS" will appear in the display.
Repeat to change back to Fahrenheit.
To exit mode, press OFF/CANCEL.
Styles 2, 3 & 4 - Electronic Oven Controls
To change: Press and hold BROIL for 5 seconds. A tone will
sound and "°C" or "°F" will appear on the display. Repeat to
Mar 18, 2011 | Whirlpool GR563LXS Kitchen Range
How do you change the tempature reading for the air conditioner from Celsius to Farenheit?
You can switch the temperature mode between Fahrenheit to Celsius as follows:
While depressing the AUTO button, depress the OFF button for 3 seconds or more. The display will change from Fahrenheit to Celsius, or from Celsius to Fahrenheit.
Feb 03, 2010 | 2004 Kia Optima
Change temperature from Celsius to Fahrenheit on a comfort zone h
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release. - VS
Nov 11, 2009 | Comfort Zone CZ-800 Heater
Change from celsius to fahrenheit
While depressing the AUTO button, depress the OFF button for 3 seconds or more. The display will change from Fahrenheit to Celsius, or from Celsius to Fahrenheit."
Jun 02, 2009 | 2003 Kia Sorento
Westward 1VER1 Infrared Thermometer Range -27 To 230 F Logo
52 people viewed this question
Top Westward Home Experts
Donni Steen
Tom Chichester
Are you a Westward Home Expert? Answer questions, earn points and help others
