Question about Kohler Persuade Two-Piece Elongated Toilet with Dual Flush Technology, with
Leaking kohler persuade - Kohler Persuade Two-Piece Elongated Toilet with Dual Flush Technology, with
Kohler single handle sink faucet 10 years old leaking
William, you or a plumber will have to replace the cartridge and seals to stop the leaks. The parts may have life time warranty, check your manual if you still have it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
KOHLER Canada Warranty Information Planning
Maintenance Replacement Parts KOHLER
Fort single control pullout kitchen sink faucet with color matched...
Kohler kitchen faucet repair
May 12, 2016 | Kohler Model 10433: FortĀ® Single-control...
K-1357 kohler whirlpool tub there is leaking only when the tub is filled and drained. when taking showers there are no leaks 3yrs old
Overflow? Seal around drain may be good enough for shower, but leaks with a little more pressure from the filled tub. Filled tub may flex the tub and drain components. What about the overflow. I bet some water is going over, but it isn't used for showers. Double check. Paper towels tied in stratigic locations always help me find a leak. Leak makes the towel soak up water nearby. It's most wet at the point of leak.
Mar 08, 2015 | Kohler Home
Kohler K-34-39 leaks
Hi James
You need to replace the rubber gasket between the tank and the bow, that is where yoiur tank is leaking from..
Be sure to use a level when tightening down on the screws to keep the tank level
Bud
Apr 20, 2013 | KOHLER Memoirs elongated toilet with...
My kohler persuade toilet won't fill up
Kenny, the gurgling sound is coming from a stoppage in the air vent located above the toilet on the roof. It has to be open to allow proper drawing of air to pull the contents from the toilet. You also have something lodged in the trap as the water goes out. If a snake doesn't clean it out, then you probably will need to take the toilet up and clean from the bottom side. You can a hose with a sprayer and bllast out from the bottom and most of the time that will free up the blockage.
Feb 18, 2013 | Kohler Persuade Two-Piece Elongated Toilet...
I can see water trickeling on the bottom of the overflow tube. Already replaced gasket and removed the fill tube. Very slow, about every 20 min. the fill valve kicks on for about 5 sec.
The problem is your flapper. It is leaking water into the bowl, causing the valve to kick in as the water level slowly drops in the tank. It will also solve most condensation issues as well.
Aug 23, 2011 | Kohler Persuade Two-Piece Elongated Toilet...
Newly installed toilet is intermittently running and tank empties if water supply is shut off.
Sound like the flapper is not sealing. Check to make sure taht the chain or whatever controls the flapper movement is not too tight, holding the flapper up and, that it is not so loose that it gets tangled and/or gets caught in between the flapper and sealing surface. You should maybe be able to hear the toilet leaking and if so, push down on flapper and, if the leak stops, you have definately found your culprit. The first thing I would do is check the adjustments and if all else fails, replace the flapper and see what happens. Unless it's leaking on the floor, it's really the only way you would lose the water out of the back tank, unless you could possibly have a cracked or a bad seal on the overflow tube assembly.
Jun 25, 2011 | Kohler K-3654-0 Persuade Two Piece...
Water level in bowl is too l;ow
There is a float in the back of the tank. It needs adjusted. I will explain more if you would like.
Jan 26, 2011 | Kohler Persuade Two-Piece Elongated Toilet...
I'm about to install a kohler ''persuade'' dual flush toilet bowl but I found out that the slot where you put the 2 screws wasn't in there so what should i DO?
Are you talking about the slot where the two screws hold the base down to the floor?
If so, that is called a closet flange. You will need to pick one up at Home Depot or Lowes. There are various kinds. If your floor is a concrete pad then you may have to get one that just slides down inside your waste pipe. It can be glued in. If you are upstairs and have a wooden sub floor you can get one with treated deck screws to screw into the floor.
If you have a digital camera, tale close up pictures of the waste site and take them to the store and show them to someone who works in the department. He will know what you need.
Oct 24, 2009 | Kohler Persuade Two-Piece Elongated Toilet...
Kohler Persuade Two-Piece Elongated Toilet with Dual Flush Technology, with Logo
37 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
