Question about Garden
Which hot and cold pressure washer?
Hi, I am in the process of starting a cleaning business and was wondering if anybody could recommend a quality, reliable and reasonably priced Hot and cold pressure washer?
Many thanks in advance
Chris
  • chris_ken982 May 23, 2009
    Hi Convulsor
    Thanks for your reply,
    Do you know if there are any brand which has this motor that is reliable and produces both hot and cold?
    Chris
  • 27 Answers
Something with a Honda GX motor
Posted on May 08, 2009
I dont know how to heat the water on my pressure washer
most pressure washers are not designed to use hot water.
Sep 10, 2017 | Water Garden
Hot water does not come in, only cold water comes in, the water pump works on cold water does not start on hot water
There are no water inlet pumps on standard washers- the water, both for hot and cold, is fed in simply under 'mains' pressure.
(The following is pre-typed for hot and cold!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Oct 08, 2011 | Magic Chef CAV2000AWW Top Load Washer
Can you use hot water instead of the normal cold water in the Karcher winner 11. I wish to clean the grease trap of my house.
DO NOT USE HOT WATER!!! This machine is rated for cold water, the pump head is made out of plastic, the plastic pump and electric motor are cooled by the cold water that moves through the pump. If you add hot water into the mix there is a good chance that you are going to overheat the unit.
Just using cold water on the grease trap might do the trick, try using a good quality degreaser, I would recommend a product called 8-Ball, this is a great degreaser and should help to solve your problem.
Oct 25, 2010 | Karcher PSI Electric Pressure Washer
What weight oil does the honda 5.5 engine require?
Your Honda 5.5 hp engine specifically calls for SAE 5W30 engine oil. Use a good quality oil in the engine, and change it every 50 hours of run time. The pump will take 30weight non-detergent oil.
Using non-detergent oil in the engine will probably void your warranty, and will certainly shorten the life of the engine. Non-detergent oils have not been recommend by engine manufacturers in nearly 20 years.
Oil is cheap, go ahead and spend $4 - 5 on a quart of high quality oil. Your engine uses about 20 ounces per change.
Oct 01, 2010 | Honda 2500 PSI Gas Pressure Washer
I have resently purchased a second hand super capacity machine, not yet run it. The softner receptor is very dirty and I was wondering how to clean it out. I have taken the top bit off but am unable to...
You can use vinegar to clean the machine take 100ml of vinegar and two buckets of hot water till the plastic tolerance then start the normal program the hole machine inner unit will be cleaned you can use the same process two months once the cloth cleaning quality will be good
May 17, 2010 | Whirlpool 3.2 Cu. Ft. Super Capacity Plus...
Water pressure for Washer (rinse only)
you nead to turn off both cold and hot water.next you nead to remove cold water hose from washer.remove screen and clean it and replace it.hookup cold water hose to washer and turn water back on.you should have better pressure.your rince cycle is cold water.
Nov 18, 2009 | Kitchen Ranges
Pressure washer has no pressure coming out
I think yor hot water softened one of the pressure seals and has allowed it to buccle. This will drop the pressure away from the pump. It will require new seals to be fitted and the cost is close to $200.
Aug 14, 2009 | Garden
My washer works wonderful buy cold water settings do not work even rinse doesn't work hot water works fine
Would say that the cold fill valve is shot
The machine cannot fill with cold water which it uses for setting the temperature on the 60 degree wash.
The cold valve is also used for rinses
Hot water only will give you a wash which is too hot and will cause the colours to run
Can take the pipe off the back of the machine to see if the cold water inlet filter is blocked
Make sure that you turn the fawcet off and also that you have a cloth handy in case there is still some pressure on the hose.
If the filter is blocked take it out and clean it , it just pulls out but be gentle with it it is only plastic.
If the filter is clean you need a new valve
Jun 05, 2009 | Roper RAS8244KQ Top Load Washer
I have a Rinnai system. Good cold water pressure, little hot.
What type of pipes are install on this heater?
Mar 13, 2009 | Water Heaters
Washer cycle has stopped during the cycle and is showing FH wondering what the problem is, we can't find the manual
FH is usually a low pressure warning on the water supply.
You could try cleaning the small filter in the back of the machine, as it may have limescale blocking it.
If this doesn't cure it, you may have to just use a cold supply instead, or arrange to have a pressurised hot water feed.
This usually happens in bungalows and flats without enough hot water pressure.
Nov 05, 2008 | Whirlpool Washing Machines
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
