Question about Heavy Duty Arrow T50 Staple Gun
Opened arrow t-50 all inside fell out how do i put bck together?
My door on my 2004 chevy aveo wont open from the inside
Usually the shops don't actually fix a thing
They just put it back together & send you
on your way, without installing new parts
& doing the job correctly
Mar 02, 2013 | 2004 Chevrolet Aveo
I took my arrow ET200 nail master apart to remove jammed nails. I need a diagram on how to put it back together
Susan Sylvia is exactly right. I just fixed my tool with her information. I would add to be very careful not to disturb the 2 small springs(associated with the trigger and safety mechanisms) and take note of how they are positioned. Also, the screws seem to strip unusually easily so be gentle when removing and replacing them.
Jan 24, 2012 | Arrow ET200 Electric Brad Nail Gun
Can some tell me if they have a picture of the inside on the switch my fell apart need put back together?
If you click HERE you will be taken to a web page of part numbers and the exploded view diagram's of the area of the washer the parts is located in.
Dec 15, 2011 | Roper RAS8445KQ Top Load Washer
On/off button fell off Sennheiser wireless mic
This is quite common with G2's, and really annoying!
If you are lucky, 50% of the time the red button is pushed inside the mic.
You need to remove the bottom section:
- open the battery compartment
- there should be 3 star-bit screws around the outside (remove)
- pull the bottom of the mic off
If the red button is not inside, they are available as a spare part from Sennheiser dealers.
Be carefull when putting the mic back together, it needs to line up correctly with the internal guides, forcing the base back on could damage the ribbon cable. when the line-up is correct it slides on very easily.
Best of luck.
PTB
Jul 06, 2009 | Sennheiser 100/500 G2 Series Wireless...
I have a Bernette 50 sewing machine....i was sewing velcro....the screw assembly on the post where the needle goes into fell off and the thread guide fell off it....i can't tell if it is broken or just...
That can be tricky. Some thread guides and needle clamps have to be assembled and then slid up into place with the needle screw holding it together. Some have a set screw to hold it.
Jun 27, 2009 | Bernina Bernette 75
Double cube fell and separated
Use a Flat blade screw driver to take off both grills. Take both speakers out use a phillips screw driver. Put your fingers in the cube with the protruding grommet, turn the object until you see it protruding its maximum. Next align it with the opening in the other cube and press until you here it click back together. re-attach speakers and put grills back on ..Whala!!!
Mar 16, 2009 | Bose Acoustimass 3 IV System
My shaver head broke! PLEASE HELP ME!
I just fixed my husband's razor. I took everything out and washed it all. Then I took the three things that touch the skin and put them in the three holes so that they fit comfortably. Then I put the sharp parts inside those thin parts. The I took the gray thing with three holes and snapped the little brown thing to it and turned the arrows on the brown thing so it snapped it securely to the things with holes. Then I put the head onto the handle by sliding the hook into it's hole, than brought the head onto the handle and snapped it shut. It fell apart the first time I tried it but I put it all back together and after that it worked like a charm.
May 08, 2008 | Norelco 8170XLCC Electric Shaver
My bluetrrek fell into water
When an electronic device falls into the water the best thing is to leave it alone, not use it, for a week or so. This allows for its components to dry well, and eliminates the risk for a short circuit. Since you tried the bluetrek, its possible that now its damaged without repair. However, you can still try placing it in a very dry place for a week or so. If you think it should be dry by now, I would open it - make sure you have contact cement glue around to put it back together. Be careful to ensure the shell does not crack. Then go ahead and thoroughly clean the inside of the unit with a Q-tip. Put it back together and try it.
Mar 18, 2008 | Radio Communications
Heavy Duty Arrow T50  Staple Gun Logo
55 people viewed this question
Top Heavy Duty Tools & Hardware - Others Experts
yoopertech
Paul Carew
Joseph Hoffmann
Are you a Heavy Duty Tool and Hardware - Other Expert? Answer questions, earn points and help others
