Question about Omnitech 9-Sheet Cross-Cut SHREDDER
Power not coming on - Omnitech 9-Sheet Cross-Cut SHREDDER
Can't shift out of park, and brake lights want come on
Check your brake light switch for power to and from if no power to it check your fuses and related wiring. If you have power to it check for power coming out while holding down the brake pedal. If no power coming out replace the switch. If power coming out check your ground and related wiring for open/broken
Sep 29, 2012 | 1997 Chevrolet Blazer
Power light comes on and then goes off.
power light comes on and then goes off
Dec 08, 2009 | Acer Aspire 3680 Laptop
Power wont come on and blue power button just blinks for a while
Do you hear a thumping coming from the speakers when the power switch is pressed? If so, you have a shorted video IC or your convergence ICs need replacing.
Aug 09, 2009 | JVC AV-56P575 56" Rear Projection...
Monitor does not always come on
Sounds like the power board is starting to lose it's dc voltage power and making it hard to start till the board warms.
This will get worse and eventually it will die totally.
You probably need to rehab the power and inverter board
ebays bammbammfran
Sep 22, 2008 | E-Machines eMachines Monitor E15T4
Computer doesn't come on.
Easy check is: power the system off. Unplug the power supply from the outlet. Hold the power on button in for at least 10 seconds. Remove the CMOS battery. Reconnect the power supply to power. Attempt to power up. See what happens. If it comes up and asks for you to set config, power down, unplug the power supply and hold the power on button for 10 secs. Replace the CMOS battery with a new one (CR2032 button battery...about $5 for 2 in the Wal-Mart photo dept) and power on. The reason for the repetition is to reset the BIOS.
Sep 08, 2008 | Dell Dimension 4400 Power Supply ** FREE...
MY COMPUTER IS NOT COMING UP AFTER POWER OUTAGE
when you put the power pack does the power pack roll if yes change the board if does not comes up change the ram if you follow these process am very sure it will work
Jul 17, 2008 | E-Machines eMachines Desktop PC
Omnitech 9-Sheet Cross-Cut SHREDDER Logo
Top Omnitech Office Equipment & Supplies Experts
ray gallant
Are you an Omnitech Office Equipment and Supply Expert? Answer questions, earn points and help others
