Question about Jensen's VM9312 Car DVD Player
Lights come on but goes off nothing comes on any display. this was after someone put a code in it to bypass the brake safety switch. now the lights come on briefly and then everything shuts down
  • 909 Answers
Normally you would ground the safety switch wire and not enter a code of any sort.
You need to reset the unit to factory settings, should be in user guide.
Posted on May 08, 2009
My ford laser wont start
What often happens is the switch on the brake pedal gets knocked around by the driver's feet. This switch is suppose to be a safety switch to insure that your foot is on the brake pedal before it lets the starter work. On some models another safety switch is on the gear shift to insure that the vehicle is in Park or Neutral. If your vehicle is a stick-shift they sometimes put the switch on the clutch lever to make sure you do not try to start the car in gear.
Jul 26, 2016 | Ford Cars & Trucks
Why Honda rancher green light wont come when in netural and wont start2008
check for faulty safety micro switches on the machine
(seat ,brake ,clutch gear position -neutral etc)
May 05, 2015 | Honda 2008 FourTrax Rancher 4X4 ES
Where is the starter relay located on a 1992 olds 88 royale
It's piggybacked on to the starter.
1992 olds 88 royale starter solenoid Google Search
Also, check the neutral safety switch - Put your foot on the brake and put the car in neutral. Then try to start it. If it starts the neutral safety switch is bad. It could be the ignition switch. It could be to starter solenoid. Does it have an inertia switch? They rarely go bad but I have seen it.
Feb 20, 2015 | Cars & Trucks
Clarion NZ500 nothing on screen
Clarion ebrake safety bypass without using toggle switch
Clarion has a brake safety wire that has to switch from open to a ground every time you turn on the unit so therefore you cannot just ground the brake wire it has to switch to ground every time you turn on the radio
Aug 22, 2017 | Clarion NZ500 Car Video Player
2001 ford escort stuck in park lever won't move starts normally
If it wont move into gear,the safety switch is malfunctioning. You can take the plug out of the hole on the upper right side of the console just to the right of the gear shift lever. put a philips screwdriver in the hole and press down. this will manually release the gear shifter mechanism.
Feb 08, 2010 | 2001 Ford Escort ZX2
Will not shift out of Park
There is a safety switch that actuates from your brake pedal, that will keep the transmission from shifting into gear until the brake is applied. I first would check at the top of your brake pedal to make sure the wires are connected to the brake switch. Another way to check the brake switch is to turn the key on and step on the brakes and observe that the brake lights are coming on. In an emergency situation to be able to move the car, you can disconnect the shift cable from the top of the transaxle. It is usually secured with one nut. Once removed you can manually move the lever to put the transaxle into neutral so the car can be rolled out of the way.
Jul 04, 2009 | 2006 Dodge Charger
How do i bypass parking brake so i can watch movies
There is a parking brake switch lead that goes to the unit. You need to permanently ground it to bypass the safety feature.
Apr 28, 2009 | Car Audio & Video
I need help to bypass the brake with my Dual XDVD9101
did you try connecting the bypass wire to the ground wire?
Apr 22, 2009 | Car Audio & Video
How do i bypass the brake safety switch on a pionner avh-p4000
CONNECT A SWITHC TO THE PARKING BRAKE WIRE ONE OF THE PINS FROM THE SWITCH TO GROUND AND THE OTHER SIDE TO THE PARKING BRAKE WIRE.
Mar 14, 2009 | Pioneer AVH-P4000DVD Monitor
95 montero sr
Do all the warning lights in the instrument cluster come on when you turn the key? If Yes, then you need to check the neutral safety switch on the side the transmission[Automatic in your Montero?], as these are a known failure part for higher mile Monteros. You lose power to the starter solenoid as a result of the switch contacts going bad. Have someone put a test light on the solenoid wire at the starter motor, while you or a friend carefully tries to start the engine. If the circuit is working correctly, you'd see the test light turn on brightly. I'm betting you'll see no light, since I suspect the switch isn't letting power through.
Sep 04, 2008 | 2007 Mitsubishi Montero Limited
Jensen's VM9312 Car DVD Player Logo
95 people viewed this question
Top Jensen's Car Audio & Video Experts
Richard Foster
Richard Foster
afairman1927
Jose Velazquez
Jose Velazquez
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
