Question about Lite On LiteOn LH-20A1P - Disk drive - DVD±RW (±R DL) / DVD-RAM - 20x/20x/12x - IDE - in Burner
Can't get my sony recordable dvd eject door to open
3 Suggested Answers
fixit0909090
  • 44 Answers
SOURCE: Liteon LVW-5005 DVD Recorder. Disk drive door will not open.
give it a tap on the bottom as you press the button, this will force it to release the disc,
Posted on Sep 27, 2009
  • 713 Answers
SOURCE: Dear Sirs, my Lite-On DP-A100
yes the only way you will be able to take it out because there was a driver error in your d playing drive is to self push the main button on tower to resart computer up again when your first page comes up take it out.
Posted on Feb 16, 2011
My Sony DVD recorder RDR 515 shows "Open" on the screen, but does not open DVD compartment
That means your player is having problem with the drive unit. Either your ejecting belt snapped or loose. Go really close to your recorder, press eject and listen if theres any motor sound. If there is, then yes theres either gear problem or driving belt snapped.
May 12, 2014 | Sony Televison & Video
I have a Samsung DVD R160 recorder. A few days ago the recorder was not on and it was making a noise like it was trying to read a disk. This went on for quite a while. I then turned it on and it would...
Try this, look for a small hole on the front of the unit.Use a pin and press in to see if it opens,ejects the disk .If no hole try seeing if you can press ,lift,pull at the door/slot while pressing the open door/eject either on the unit or with the remote control.It sounds like you may have a bad CD/DVD (copy) that the unit is trying to read/load but can't. keep trying to eject CD/DVD if this doesn't work unplug unit for 5 minutes,try open door again do press and hold open repeatedly I know it's frustrating but it just may eject.Don't use this recorder for playback of DVD buy a $30 DVD player the cheaper the better they play anything.GOOD LUCK
Jan 04, 2011 | Samsung DVD-R160 DVD Recorder
SONY RDR-VX500 DVD eject not working
On most DVDs there is a small hole under the tray where you can insert a straightened paperclip, push in and it will manually open the tray. If not if you can try GENTLY prising the tray open by inserting screwdrivers on both sides of the tray with the power off
Oct 04, 2009 | Sony RDR-VX500 DVD Recorder/VCR
Not eject
On my Sony SLV-281P DVD/VCR Combo, if you pull down the spring loaded door for DVD you will see a white gear on the left side under tray....rotate that gear counter-clockwise. This will manually drive out the DVD tray far enough to enable you to pull it out the rest of the way.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
How do whe open the door of a dvd recorder ?
Try this - I had the same problem and this worked for me. Don't just turn off the unit but turn off and then unplug from the mains. wait 5 mins and then plug back in, turn back on and press the eject button on the unit just once - and wait for it to finish it's start routine - and then it may open - it did on mine - if not, then try eject button again.
Hope this helps
Dec 24, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
My Sony SLV-N750 recorder works perfectly - except..
If the door is not connected to a "tape in" interlock
Jul 22, 2017 | Sony SLV-N750 VHS/S-VHS playback VCR
Dvd stuck on formatting
Hold down the power button for about 5 seconds to turn off the unit. Pull the DVD door down, and use a paper clip to turn the white gear counter clockwise. The DVD tray should come out after about 5 full revolutions of the gear. Press the open button to reset the unit.
Feb 18, 2008 | Sony RDR-VX515 DVD Recorder/VCR
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Laptop dvd drive door will not open
There is a tiny hole on the draw in which to insert a paperclip to manually eject the draw.
Jan 16, 2007 | Compaq Presario X1000 Notebook
Lite On LiteOn LH-20A1P - Disk drive - DVD±RW (±R DL) / DVD-RAM - 20x/20x/12x - IDE - in Burner Logo
26 people viewed this question
Top Lite On Computers & Internet Experts
Rommel Balcita
Gbenga
William Alequin
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
