Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Setting HD as secondary
Recently my PC reset button start to blink yellow.
We figured out that there is a problem with the HD. When HD was disconnected the Reset button was green again.
No we are trying to set the HD as secondary on another PC to try to recover some data. When we connected it in second slot as is we got the blinking yellow light again. We probably should set jumper, although there are only 4 pins and no jumper on the HD
The HD is Barracuda 7200.7 80 GB, model ST380819AS
Please help,
Thank you,
Tania.
  • 265 Answers
ok easiest option to do this is to buy a USB Hard Drive Caddy.
Click Here
Then you just insert the HDD into the caddy and plug it in via usb and you will have access to all your files unless your hard drive is corrupt :)
Hope this helps
alex
Posted on May 08, 2009
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Reset supertooth HD to original factory settings
To reset you SuperTooth HD:
Turn off the device. Press and hold all three buttons until the left LED indicator starts blinking Blue and Red this means that your SuperTooth HD device has been reset. You will soon be prompted for language information like the first time you used your SuperTooth HD device.
Note: Disconnect all handheld devices from your SuperTooth HD device before performing a Reset.
Jun 07, 2012 | Supertooth Hd Bluetooth Speakerphone Car...
Targus COMPACT laptop charger isn't working
Your battery sounds like its buggered. I would suggest buying a new battery
May 20, 2010 | Lenovo 3000 G530 Notebook
Seems like only on HD inputs
U must have HD subscription to get HD channels.If u do ur HMDI have a sort or not leave it to factory setting it work ok right?
Aug 24, 2009 | Toshiba 56HM66 56" Projection HDTV
Compaq presario v5000 won't start or post
It's the motherboard. Check to see if yours is still under warranty even if you've had it for over a year.
HP / Compaq has recently extended their warranty period for certain models.
Warranty Check
Let me know if you have any other questions.
Mar 04, 2009 | HP Compaq Presario V5000Z Notebook
Motherboard
Could be the CPU...
Jan 16, 2009 | E-Machines (T2824) PC Desktop
Dell 5100 won't start... Power button blinks yellow.
hi disconnect pc and try to charge ups without anything connected
Dec 04, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computer wont start
replace your bios battery
Jun 14, 2008 | Gateway 506GR PC Desktop
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Blinking lights when PC is turned off
This works if you boot the monitor with a pc, open the osd menu and go to reset. reset the monitor.
Dec 08, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
302 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
