Main multi point BF leak to front water valve
4 Suggested Answers
dididsaythat
  • 291 Answers
SOURCE: frig leaking water
sounds like the water valve is not sealing all the way... you can take the hose off the water valve in back of the refregerator and put a cap on it 53560ac.jpg
Posted on Nov 15, 2007
  • 848 Answers
SOURCE: R/front Valve Asbuy or Main
its definitely not ring leaking......
Posted on Jul 15, 2008
SOURCE: GE WCVH6800 front load washer
In order for the pressure switch to work it has to get pressure.
The switch is located near the top of the right side panel and can be seen by removing the top cover. There is a small pressure hose that leads to the switch and should be checked for crackes or chafing. There are three round sponges on this hose to keep it from rubbing on the moving parts. I had to replace mine after just over a year so I used a heaver hose with the same inner diameter. I used a 3/16 fuel line from Princess Auto and two new 3/8 stainless hose clamps.
Posted on May 31, 2011
Oil leak front engine timing chan
1995 Tracker would have a timing BELT. Normal oil leak points (in order) on a Suzuki G16 engine are the distributor base (rear of motor), valve cover (top of motor), front main seal (behind lower timing belt cog) cam seal (behind the upper timing belt cog) and rear main seal. (behind the flywheel). I'd suspect the front main seal or cam seal. I use foot power to help find oil leaks.
Dec 24, 2012 | 1995 Geo Tracker
Need to know how to switch off hot water by combi boiler worcester bosch 240 to be able to fix leak on pipe downstairs
its the vavle 3 one in from the left its a 15mm pipe and there will be a iso vavle what you can turn with a flat point screwdriver and that will turn off the main water to the boiler these are the manual
http://www.worcester-bosch.co.uk/homeowner/literature/discontinued-boiler-literature/discontinued-gas-boiler-literature/240-bf-discontinued-december-1997-literature
Jan 23, 2011 | Heating & Cooling
I see water down on the floor after the wash load is completed. Initially when washer starts, there is water on the ground.
Your observation of the leak is very important to confirm the point of leak. Check for leak from the door gasket on the front door, check for drain pump/valve leak, check for drain hose leak from a faulty clip.
Jan 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Both drawers leak in the front
If your dishwasher leaks, check these:
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Apr 01, 2010 | Dishwashers
I have a pump attatched to my shower and now I have to have the water turned up on the highest point to get it hot enough and the pressure is low now any answers
There's a leak in your line causing you to have a lower pressure. Check for leaks;
1. Start at the installed pump. (Suction point, pump
shaft, pump discharge, Pipelines)
2. Check your mixing valve (the valve where the hot
and cold water meet and mixes)
3. Check you main water line connections.
Hope this will help you.
Nov 29, 2009 | Plumbing
Keeps over filling and water leaking out of side and front
There is a valve mounted on the rear of the cabinet which is supposed to cut off the water flow when the water level reaches a set point. A clear plastic tube will run from the bottom of the tub to this valve. Replace the valve, reconnect the plastic tube. Should solve the problem.
Apr 23, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Water leaking from bottom of front lode washing machine
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Dec 01, 2008 | Frigidaire FTF530FS Front Load Washer
Leaking water from front of door
I replaced the seal part # 154576501. The notch is on the right facing the dishwasher. Just pull it out and insert the new one.
I've fought this problem for over a year, thinking it was an adjustment. I am now running it through the third cycle and I am positive it fixed my leak. Also, while you have the cover off, check and trim the tie-wrap around the wire loom. Mine was interfereing with the seal, but the seal was also slightly distorted allowing the splash to come underneath.
BnoGno
Nov 16, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Leaking water
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
Jun 30, 2008 | GE GSD1180X Dishwasher
Leaking water on floor in front of dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Door gasket or seal
Water-inlet valve
Hoses
thanks for using FixYa
Dec 27, 2007 | Kenmore 24 in. 16022 Built-in Dishwasher
Heating & Cooling Logo
164 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
