Question about Precision Camera Home Security
Need wiring map for evo2-vpdnvf600wdr-2.8~11(S79270)
Have used 4g63turbo evo2 . Aftermarket bov etc . 800kms through bottom end run-in process . All is well but tonight acceleration is straining .airflow/turbo related? Also thinking exhaust.
first with engine cooled down removed spark plugs then turn engine in direction of running rotation by hand from the crank to see if its mechanical related like eg bearing seized. With the spark plugs removed engine must turn easily by hand if not something is holding
May 28, 2016 | Cars & Trucks
Need a wiring diagram for map sensor in 2006 Jeep Liberty 4x4 3.7L
Go to autozone and ask for the wiring diagram. They will print one for you for free. If you dont have an autozone near you try another parts store. If you purchase a haines of chiltons manual ($25 in a retail store or $18 on amazon), it will have a detailed wiring diagram of the MAP sensor.
Good Luck!
Jul 13, 2014 | 2002 Jeep Liberty
Wiring on map sensor
Some of those models had a MAP Sensor and some didn't.The mazda and the Ford ranger are the exact same truck with the exception of the grill and tail lights. I am not sure if your saying that you have a map sensor and no wire or a wire and not map sensor.If there is no wire for a map sensor then you truck does not require one. If it has the wire then you will have to get a map sensor.The trucks that don't have a map sensor will have a Mass Air Flow Sensor, located at the top of the air filter box.
I hope this will help you.
Apr 18, 2014 | 1994 Mazda 2WD B Series Pickup
How do you set a resistor to 2200 ohm
Connect two resistors in serial eg 1kOhm +1.2 kOhm. You may not need exact 2200 assumung that standard resistors tolerance is 5% - check with Ohmmeter if it's between 2,11 and 2,32 kOhm. But if it's special and value is critical then get trimmer (small adjustable resistor) and adjust value to Ohmmeter indication. Watch out required power.
Mar 01, 2014 | Gardner Bender GB GMT-312 12 Range Pocket...
What does the map sensor do on 1994 geo prisim
new spark wires. old wires hate, cold damp weather.
spark plugs, cap,rotor wires, try the 60k mile tuneup. per the opr.guide.
magic happens....
the map is ok.
and to test a map you need the graph and you need to compensate for altitude and local weather (barometer readings) to correct what you see.
is the check engine light glowing running?
most maps read like this, 1bar maps.
http://www.fixkick.com/sensors/my-map.html#Jeep
i bet your's is ok. the map.
your car is a toyota corolla in snake clothing.
the toy FSM covers this is find details.
Feb 08, 2014 | 1994 Geo Prizm
Need wiring diagram for map sensor for 1993 850
If its a three wire sensor one is a ground , one is the 5 volt refrence and the other one is the signal .Key on the 5 volt refrence shuld be about 4.8 signal should be under 1 but above .5
May 23, 2012 | 1993 Volvo 850
95 cadillac reading code current p105 sometimes engine light comes on sometimes harder to start than normal, idles up and down up on stopping
Symptoms Symptoms of a P0105 check engine light code may include:
  • Poor running engine
  • Engine runs rich
  • Engine won't idle
  • Engine backfires through tailpipe
  • Engine misfire under load or at idle
  • MIL (Malfunction Indicator Lamp) illumination
  • In some extreme cases there may be no symptoms other than MIL illumination
Causes A P0105 DTC could be caused by:
  • MAP sensor vacuum hose disconnected or plugged
  • Bad MAP Sensor
  • Bad TPS
  • Damaged or problematic MAP sensor connector
  • Damaged or problematic TPS connector
  • Damaged wiring
  • Short to reference voltage on signal circuit of MAP Sensor
  • Loss of ground to MAP sensor or TPS
  • Open on signal circuit of MAP sensor
  • Bad PCM
Possible Solutions Using a scanner or code reader, turn the ignition on and engine OFF; what does the MAP sensor voltage read? It should be about 4 Volts for sea level. If you are at a higher altitude, it should decrease about half a volt or so for each 1,000 ft. of altitude (this will vary from model to model) Or if you have a separate MAF (Mass air flow) sensor on your vehicle, they are usually equipped with a Barometric pressure reading. If so, the Baro reading should match the MAP reading (they both measure ambient air pressure). If they're roughly equal, then, check for Freeze Frame data of the MAP sensor (if available).
NOTE: Freeze Frame data is the PCM recording a fault when it happens. It captures the readings of the various PIDS (parameter identifiers)available to troubleshoot what happened. It's like a recording of the problem as it happened. At idle a typical MAP sensor Voltage reading should be about a volt, and at WOT (wide open throttle) it should approach 4.5 to 5 Volts. As for the TPS, at idle, the voltage reading is about 1 Volt or less. As the throttle is opened the reading will increase to 4.5 Volts at WOT. Do the two readings make sense? For example, if the TPS reading on Freeze Frame data shows 2.5 Volts (indicating partial throttle) does the MAP sensor indicate a reading that isn't at either extreme? Using the Freeze Frame data (if available) compare the MAP reading to the TPS when the problem occurred. This can help you identify what happened
If you have no access to Freeze Frame data then check if the MAP sensor voltage changes when you apply vacuum to it. You can do this by mouth or a vacuum pump. The voltage should increase as you apply vacuum. If the reading doesn't change as you apply vacuum, make sure there are no obstructions in the hose to the sensor. If the hose is clear, the MAP sensor is usually bad, but it doesn't rule out the following from causing the problem: Does the MAP sensor appear to be stuck at less than .5 Volts? Then:
NOTE: This code shouldn't set if the MAP is stuck at extremely low voltage, however, I'm adding it in because there's no way to know for certain for which vehicles a low voltage condition may set a P0105
  1. Inspect the wiring harness and MAP sensor connector. Repair any damage
  2. Unplug the MAP sensor connector. Also, at the PCM connector, remove the MAP sensor signal wire and check for continuity to the MAP sensor connector. If there is infinite resistance, then repair open in MAP signal circuit. If the signal wire has continuity to the MAP sensor connector, then check for 5 volt reference voltage to the connector and a good ground. If both are present, then re-install all removed wiring and replace the MAP sensor.
Does the MAP sensor appear to be stuck at full 4.5 voltage? Then:
  1. Inspect the wiring harness for damage. Repair as needed
  2. Remove the MAP sensor signal wire from the PCM connector. With a voltmeter measure the voltage with KEY ON ENGINE OFF. Is there 4.5 Volts? If so, unplug the MAP sensor and recheck. If it is still present, then repair short between the signal wire and 5 volt reference wire.
  3. If unplugging the MAP sensor causes the voltage to disappear, check that the ground is intact. If it is, then replace the MAP sensor due to internal short.
Jun 17, 2011 | 1995 Cadillac DeVille
IT IS NOT WORKING
Run this diagnostic
Test Procedures
1. Check if DTC P0110 is set in addition to DTC P0105 or P0106. If DTC P0110 is set, go to next
step. If DTC P0110 is not set, go to step 3 .
2. Turn ignition off. Disconnect MAP sensor 4-pin connector. Measure resistance between ground
and MAP sensor connector terminal No. 4 (Green wire). If resistance is one ohm or less, replace
MAP sensor. If resistance is more than one ohm, repair open in Green wire between MAP sensor
and ECM connector terminal No. 48. After repairs, clear DTC and verify MAP sensor operation.
3. Turn ignition off. Disconnect MAP sensor 4-pin connector. Measure resistance between MAP
sensor connector terminals No. 1 and 4 (component side). Resistance should be about 30,000
ohms. If resistance is as specified, go to next step. If resistance is not as specified, replace MAP
sensor. After repairs, clear DTC and verify MAP sensor operation.
4. Turn ignition on. Measure voltage between ground and MAP sensor connector terminal No. 2
(Red wire). Voltage should be about 5 volts. If voltage is as specified, go to next step. If voltage is
not as specified, repair open in Red wire between ECM connector terminal no. 44 and MAP
sensor connector terminal No. 2. After repairs, clear DTC and verify MAP sensor operation.
5. Turn ignition off. Disconnect ECM 63-pin connector. Check for continuity between ground and
MAP sensor connector terminal No. 1 (Green wire). If continuity does not exist, go to next step. If
continuity exists, repair short to ground in Green wire between MAP sensor and ECM. After
6. Reconnect MAP sensor connector and ECM connector. Turn ignition on. Backprobe MAP sensor
connector and measure voltage between ground and MAP sensor connector terminal No. 1 (Green
wire). Voltage should be 0.2-4.5 volts. If voltage is as specified, go to next step. If voltage is not
as specified, replace MAP sensor. After repairs, clear DTC and verify MAP sensor operation.
7. Check ECM connector for loose or damaged terminals. If problem exists, repair ECM connector.
If problem does not exist, replace MAP. Clear DTC and verify system operation. If problem still
exists, replace ECM. After repairs, clear DTC and verify system operation.
Good luck and hope this helps. If the car does not start diconnect the MAP sensor to get you to the parts store if you need it to get you there.
May 25, 2009 | 2001 Hyundai Elantra
MAP sensor wiring to ECU
There are 3 wires from the MAP to the ECU
Brown is E (Ground)
Yellow is VC to VCC (sensor to ECM)
Light Green with a Red tracer is PIM to PIM
Feb 09, 2009 | 1995 Toyota Corolla
Map Sensor
one wire gos signal,5 volt, other gos 12 volt. other to ground need a wire diagram to determine which one is
Sep 05, 2008 | 1994 Chevrolet S-10
Home Security Logo
Top Precision Camera Home Security Experts
Lawrence Oravetz
Are you a Precision Camera Home Security Expert? Answer questions, earn points and help others
