Question about Husky Wet Tile/Stone Saw with with Laser and Stand
Thd 950 saw motor
Need replacement motor
I need a replacement fence for a Husky THD 750L tile saw where might I find one?
http://www.fixya.com/support/t16308541-husky_thd_750l_replacement_guide_fence
Apr 27, 2017 | Saws
Which bulb is faulty and when replaced how do I get rid of symbol
Turn all the lights on and walk around thd car when you find thd one replace it the warning lamp will go out automatically if all is well. Regards Jim...
Jun 11, 2015 | BMW Cars & Trucks
Motor replacment
Try to contact ereplacement . Or check out the motor from Baldor electric company. They have available motors. If you need band saw blade, my supplier is sawblade.com . Check them out.
Nov 11, 2013 | Delta Machinery 14" Band Saw with 1HP...
Where can I purchase a new saw or a part for my Ryobi TS1352 10" miter saw in NJ I live in Marlton NJ 08053. I would like to go to a store for the part or new saw
Ryobi is a The Home Depot exclusive brand, you have to go there to buy new Ryobi tools. Whether they have that particular model in stock or have to order it will depend on the size of your THD.
Parts for your tool are available at www.ereplacementparts.com Put your model number in the search block and you'll get a breakdown of your tool and what parts are available.
Sep 08, 2010 | Ryobi Garden
How many ohms is this amp
your amplifier has the following specs:
Output Power at 12V:
1 x 200W @ 4 ohms (0.05% THD, 20Hz - 20kHz)
1 x 400W @ 2 ohms (0.5% THD, 1kHz)
Output Power at 14.4V:
1 x 300W @ 4 ohms (0.05% THD, 20Hz - 20kHz)
  • 1 x 600W @ 2 ohms (0.5% THD, 1kHz)
May 10, 2010 | Kenwood KAC-X401M Car Audio Amplifier
I need to know what the wattage the alpine mrv-f407 puts out when its bridged or only running 2 channels?
RMS Continuous Power (at 12.0V)
Per channel into 4 ohms...............40W, 0.08% THD
Per channel into 2 ohms ..............50W, 0.3% THD
Bridged into 4 ohms.....................100W, 0.3% THD
RMS Continuous Power (at 14.4V)
Per channel into 4 ohms...............60W, 0.08% THD
Per channel into 2 ohms...............80W, 0.3% THD
Bridged into 4 ohms.....................160W, 0.3% THD
Max. Power (at 14.4V)
Per channel into 4 Ohms..............120W
Bridged into 4 Ohms....................320W
This should help.
Apr 30, 2010 | Alpine MRV-F407 Car Audio Amplifier
Want to replace under powered saw motor on sears 10"table saw
u can put a 2 and above if u want just need to have the correct rpms
Jan 26, 2010 | Craftsman 10" Table Saw
The wet saw husky thd 950l wore out yhe bearing and make
I am a contractor who has used this saw for about four years. I just ordered the new motor for $79. The Husky has been a great saw. Don't waste your money buying some junk for Harbor Freight.
Oct 14, 2009 | Wet International Husky 7" Wet Tile Saw...
What is the watts of this amplifier
The XM-1002HX is a two-channel amplifier with power ratings of 100 watts x 2 or 280 watts x 1 into 4 ohms and 140 watts x 2 into 2 ohms. ...
Mar 21, 2009 | Sony XM-1002HX Car Audio Amplifier
My HP PSC 950 printer copies and scans in color but prints in black
normally when the color tank runs out 2 things happen.
1] not all the colors run out at the same time.
2] the printer complains the tank needs to ne replaced.
If the tank isn't dry, it could simply be clogged. I like to use rubbing alcohol or distilled water and a cotton swab.
Dip the swab, & then gently apply pressure in the nozzles.
I would expect to see the clog before the cleaning process, some color to come off & when pressed on a paper towel, hopefully 3 bands.
Jul 05, 2008 | HP PSC 950 All-In-One InkJet Printer
Husky Wet Tile/Stone Saw with with Laser and Stand Logo
Top Husky Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Husky Measuring Tool and Sensor Expert? Answer questions, earn points and help others
