Question about Lexmark X642e MFP Laser Printer
Lexmark x646 invalid scanner code - Lexmark X642e MFP Laser Printer
INVALID SCANNER CODE error
You need to download the firmware from support.lexmark.com then send it to the printer either via the network connection or usb. If you are connected by ethernet you can put the devices IP address into internet explorer and send it via the printers built in webpage, you will find an update firmware option there in the configuration menu. To use usb you would need to get the usb flash utility first
Jan 21, 2013 | Lexmarkr X646E Multifunction Printer -...
E460 invalid firmware
Make sure you're using the correct firmware. First, get the base code version of your printer. Just print a menu settings page from your printer: Menu > Reports > Menu Settings Page > Get the Base code.
Once you have the base code, go to http://bit.ly/biqa0o and use this keycode to download the correct firmware for your printer: e460fb
That firmware if for these code versions:
Base: LR.MN.P510
Kernel: FPR.APS.F348
Network: NR.APS.N528
Nov 04, 2012 | Lexmark E460DN/E460DW CTLRFORMS BAR CODE...
What is 945 error on MFP X646??
This is a hardware issue and the only resolution is to replace the scanner control card. I suggest you contact Lexmark technical support or your authorized service provider for assistance.
Jul 21, 2010 | Lexmark X644e Laser Printer
Invalid engine code on Lexmark Optra T610
Sounds like you've experienced a fairly common problem with Lexmark Optra printers. The engine board has more than likely failed. Rather than go to to Lexmark, try this site for a less expensive replacement board...
http://www.partsnow.com//
Apr 19, 2010 | Lexmark Optra T610 Laser Printer
Invalid engine code?
Try putting the old fuser back and see if it gets rid of the error, then if that's the case the new fuser is defective. If not, here's a link to the Lexmark website which gives you instructions on what to do when having that "Invalid Engine Code" error message. http://bit.ly/9D61W3. Hope this helps. Let me know if you need more assistance.
Apr 16, 2010 | Lexmark Optra T612 Laser Printer
Invalid engine code
The easiest way to solve this is to work through Lexmark Technical Support.
Their web site may have the correct engine code on their site, but installation of the code can be tricky.
Are you getting a 900 Invalid Engine code message?
Don
Apr 23, 2009 | Lexmark Optra T614 Laser Printer
Lexmark T522 (invalid Machine code)
i take it that your getting an invalide engine code error? this is caused usually by the printer taking a power surge. you can get a batch file from lexmark to reflash the engine board however if it will take the code it usually odesnt last to long. change the engine board and your problem will go away
Mar 17, 2009 | Lexmark T522 Laser Printer
Lexmark C510 - Printer will not print
Message:
Invalid Engine Code
What this message means:
The printer engine code has not been programmed or is not valid.
What you can do: [Not much]
Call for service.
See also: Calling for service
Dec 04, 2008 | Lexmark C510 Laser Printer
Lexmark x646 problem with scanning emails have dark background and look like a graph background how can we get a white background
sounds like the optics on this may be dirty, no easy way to fix. I would suggest having a tech look at it and clean. Some fragile pieces in there....
hope that helps
Jun 10, 2008 | Lexmark Office Equipment & Supplies
Code 200.13
Replace Sensor Input Media and it should fine The part Number 40X1223 the cost around $3.60.
Apr 24, 2008 | Lexmark X342n All-In-One Laser Printer
Lexmark X642e MFP Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
