Question about Compaq Presario 2199us PC Notebook
Presario 2199us How to switch IDE HD from
Presario 2199us How to switch IDE HD from Priamry to secondary controller - primary will not get out of PIO mode
  • 2 more comments
  • bargoot May 12, 2009
    Thanks for you willingness to help !
    I see an entry in BIOS for the controller and it is something like fpio/dma but I cannot navigate to it.
    I have tried resetting in manage-IDE controllers-properties-advanced but it won't change to DMA on the primary controller. Meanwhile the secondary controller is in DMA mode - that's why I wanted to switch the HD to that controller. Since it is a laptop I am reluctant to try to take it apart - and cannot be sure it will be switchable in HW. SO I am looking for a SW solution...
    Thanks,
    Nick
  • bargoot May 13, 2009
    Thanks for the response to first posting - but BIOS (which I just updated) does not offer the option to move the HD from the primary to the secondary IDE controller on my Presario 2199US running XP SP3.
    Is there a better version of BIOS out there, or is there some other way to change it in SW ? My primary controller is stuck in PIO mode and resetting it in Manage Devices and the registry does not help. The secondary is in DMA so I want to move the brand new HD (I replaced my original) to it the Secondary IDE COntroller to get the better speed.
    Yes I think we are on the same page - thanks ! My BIOS (which I just updated) won't let me navigate to the entry for setting the IDE controller. The primary is set to FPIO (or simular). However there is a method to fix it in My Computer - manage- devices-IDE controllers-advanced but setting it there also won't work. I even tried a registry fix offered on another site. All of this is what caused me to coclude that the best thing to do was to just switch controllers. Since it is a laptop I wanted to check for a SW fix before opening the HW on the off chance that the controllers would be HW switchable.
  • 741 Answers
In BIOS boot order; you just switch them.
or
On the motherboard you switch the wires connected to the motherboard.
Posted on May 09, 2009
  • 1 more comment
  • Randall  Trahan
    Randall Trahan May 11, 2009
    Sorry amigo, did not read all of your question, missed the PIO part, that's why you got such a crappy answer...so you tried resetting in BIOs correct from PIO to DMA? Cause your real problem is getting out of PIO mode and switching is just a temp fix..let me know if you tried BIOS and I'll guide you from there..
  • Randall  Trahan
    Randall Trahan May 13, 2009
    No you're correct you can't change controllers in BIOS, I was hoping you could change the PIO mode to DMA..
    But I think there is some miscommunication between us. The controller connection is the actual plug-in for the hard drive cable. There is one controller for your hard drive and another physical controller for your DVD. So if you wanted to switch which device is plugged into which controller then you would have to open the case and switch the cables. This is what I was referring to in my first solution.
    In my second solution, I was asking if you can change the PIO mode to DMA mode on the hard drive controller in your BIOS. You may not be able too, some manufacturers made them that way. But that is the normal way to change from PIO to DMA, in the BIOS options of the same controller vs switching cables. Are we on the same page?
  • Randall  Trahan
    Will if there is please let me know :)...cause it is wired to the controller to the HD, so it would be kinda tough to switch data from it...good luck, let me know how it turns out..
Installed win98se in maxtor 8gig hd on 2nd ribbon cable,deviceman sees 3 standard IDE controllers(no warning flags),3 primary and 3 secondary with the old yellow exclim.(!) warnings.I believe I need some...
windows 98 in year 2017, why/?
good luck,
why mess with this old box.
why not get a 10 year newer box for near nothing at GOODWILL.
really this box is land fill fodder. now. know body beats there head on w98 now....
mx.com no support
hp.com no support its on the no support page, seen here
Compaq Presario Media Center SR2030NX Desktop PC
so if a driver is bad (hell the hardware is too)
then go to the chips that fails home page
the mobo is ASUS>
A8M2N-LA
may be the they have 19 year old IDE drivers for win98
 GeForce 6150 LE chipset
the IDE is nforce , (old)
the only hope is Asus, old pages or nvida relic pages.
http://www.nvidia.com/object/nforce_nf4_winxp32_8.26_11.09.html
Mar 26, 2017 | HP Compaq Presario SR2030NX PC Desktop
DMA
You can download a software fix for it:
http://winhlp.com/node/10
It's called resetdma.vbs ,download it and then install it.
The site also has some tips if the software doesn't help you.
May 14, 2009 | Compaq Presario Notebook
Need to move HD from Primary to Secondary IDE Controller
its so easy man.....dont have to upgrade the Bios...open the tower CPU..check the HDD data cable ...find the socket on the mb whr it is connected to,,u will find a similar socket next to it....unplug from the 1st one and plug into the other one and its done
May 11, 2009 | Compaq Presario 2199us PC Notebook
How do I make my Acer E661GXM mobo read an IDE primary HDD and a SATA secondary HDD?
I didnt got exactly what ya want ...but I have some idea...
probably it says something like ( at identification on boot ) primary ide controller.....cd/dvd...... secondary ..ide ...hdd...... sata controller hdd....
this is not an issue of which one is primary ans so ....cause those are 2 completely different bus-es ...and the only way to make your ide hdd be read like primary ...its to change the plug with the one from the cd /dvd..drive ..
the rest doesnt matter cause it s a different controller...
Apr 11, 2009 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Maxtor Internal EIDE hard drive dip switch settings.
I assume you have two IDE controllers? IDE1 and IDE2, I'll try to help, the primary HD needs to have the pin set to primary and the secondary set to slave, if you're running both of these drives off of the same ribbon cable. You may have to go into your BIOS settings and check to make sure the Primary HD is the WD drive.
Apr 06, 2009 | Western Digital Caviar 500GB Internal EIDE...
Still needed solution of problem
Go to Control Panel - click on System - Click on Hardware - Click on Device Manager - click on IDE ATA/ATAPI Controller.
Then right click on Primary IDE Chanel - then click on Properties - Then Advance Settings - For the Device 0 in Transfer Mode select DMA if available. Then Click OK.
You can also select DMA for Device 1 too
Feb 09, 2009 | Compaq Presario Notebook
Need Solution of a problem
try this. go to BIOS, from your main page choice sata1 and press enter then press DMA MODE and chanege to UDMA5 press enter F10 save and exit
Feb 07, 2009 | Compaq Presario Notebook
Cone of HDRW720 Hard Disk
In order to use this software you need motherboard with two IDE ports.
You have to use both primary IDE ports, HD must be single mode...
IDE1 Primary - Your HD
IDE1 Secondary - Don't use it
IDE2 Primary - Your HD
IDE2 Secondary - Don't use it
Because it was so long ago I don't remember exact details, and it takes time to reconfigure PC...
But if need help let me know, and I will get you step by step instructions...
May 26, 2008 | Philips HDRW720 DVD Recorder
945GZT-M: HD listed as third IDE master in bios
If the drive is set as Cable Select you are allowing the motherboard to detect where it is on the ribbon cable. If the drive is shown as Primary slave then the drive is on the wrong connector on the ribbon cable. If it is shown as secondary master than the IDE cables on the board need to be switched (primary to secondary, secondary to primary)
Apr 10, 2008 | ECS 945GZT-M (V1.0) Motherboard
Compaq Presario 2199us PC Notebook Logo
170 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
