Question about Electrolux 504199 Dishwasher
Electrolux a1 problem - Electrolux 504199 Dishwasher
Why does my Electrolux commercial dishwasher come up with error code A1?
Check Water supply (valve, filter, pressure)
Check that the overflow pipe is inserted
Jul 12, 2016 | Electrolux commercial undercounter...
Electrolux WT55 fault code A1
AL_1
Appears with hood closedif the top limit switch (FC_UP) cuts in.
Appears with hood closed, if:
  • the bottom limit switch (S3) returns to the rest position_;
  • the top limit switch (S5) cuts in;
  • "S3" does not cut in.
Dado
Nov 13, 2014 | Electrolux Dishwashers
I need a formula length of service in DD/MM/YY on MS Excell
Format cells A1 and B1 to dates.
A1 is the first date
B1 is the 2nd date
C1 enter the formula below
=DATEDIF(A1,B1,"y")&" years "&DATEDIF(A1,B1,"ym")&" months "&DATEDIF(A1,B1,"md")&" days"
Jun 23, 2011 | Microsoft Excel for PC
Cannot find driver for my 750c for windows 7 how can l install my 750c to windows 7
There are free software you can download for this designjet 750c by finding at websearch like yahoo.com or msn.com. Just type the driver name for this printer and you can download it for free. Most of the printer driver now can be downloaded online with free cd key. Just let it try. or Maybe the printer you are installing is not compatible with windows 7. try to read you printer's user manual.
Nov 11, 2010 | HP DesignJet 750c plus InkJet Printer
How to calculate an amount in cell up to a constant amount
Lets say you want Cell A1 is the number that you want to determin which column you want it to go in...try this formual you might need to tweek it or message back and tell me what you need ----First Column----- =IF(AND(500,000>=$A1,$A1>=0),A1," ")
----Second Column----- =IF(AND(2,000,000>=$A1,$A1>=500,001),A1," ")
-----Third Column---- =IF(AND(5,000,000>=$A1,$A1>=2,000,001),A1," ")
so this way it will only appear in the column that it fits in and you can replace A1 with the formula
Jun 25, 2009 | Microsoft Excel for PC
Dishwasher not heating
a1 is no water into solinoil vale
check water hose ..
May 04, 2009 | Electrolux 504199 Dishwasher
Mrps
Use this as a reference
=IF(H4>=70,"A+",IF(H4>=60,"A", IF(H4>=55,"B+",IF(H4>=50,"B",IF(H4>=45,"C+",IF(H4>=40,"C",IF(H4<=39,"F")))))))
A+ >70 A >60 B+ >=55 B >=50 C+ >=45 C >=40 F <40
Apr 08, 2009 | Microsoft Computers & Internet
Excel formulas
hello
yes it is.
example
sheet1
A1 (50)
A2 (50)
sheet2
(A1)=
"=Sheet1!A2+Sheet1!A1" <-this is the actually code in sheet2 column A1
ok let me explain
in A1 and A2 in sheet1 you got 50 and 50 like numbers.
in A1 on Sheet2 you have = sheet1 a1 + sheet1 a2.
did you get it?
dont know else how I should explain it...
good luck
Oct 09, 2008 | Microsoft Excel for PC
Ms excel function
I'm not entirely sure how you want to use this, but it is fairly easy to automatically assign a value to a cell based on the value in another.
Let's assume that you enter your score (A, B, C or D) in cell A1. If you put the following equation in cell A2 it will then display the corresponding score:
=IF(A1="A",3,IF(A1="B",2,IF(A1="C",1,IF(A1="D",0))))
You can go on adding as many further 'IF' statements as you like.
You can elaborate on this a bit by changing it to the following:
=IF(A1="A",3,IF(A1="B",2,IF(A1="C",1,IF(A1="D",0,"Not Scored"))))
By adding the final 'Not Scored' entry it prevents cell A2 from displaying 'FALSE' as an output.
Matt
Feb 26, 2008 | Microsoft Excel for PC
Electrolux 504199 Dishwasher Logo
19 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
