Question about Logitech Cordless Mouse
Mouse stopped working, but appears ok, batteries ok, can't determine problem
Ok I have a logitech mouse which I've owned for about two years, and recently it started to act funny. It (the cursor) would stop moving for a moment and then it would start again in less then a second, like a dirty ball mouse. I've experienced this problem before, when my receiver is to far away from my mouse. However they were very close together when i started having these problems. Now the cursor doesn't move at all. The 'connect' button seems to do nothing, or bring up the 'new hardware' dialog. Both the receiver and the mouse appear to be fine, but the fact remains that the cursor does not move. Help anyone?
  • 5 more comments
  • Wd40bomber7 Oct 11, 2007
    Sorry that i failed to mention, the batteries are 100% new out of the package.
  • Wd40bomber7 Oct 12, 2007
    Yes it is optical, do you mean externally or internally, when you see clean the eye?
  • Wd40bomber7 Oct 13, 2007
    Its perfectly clean, if you were talking about internally cleaning the eye, that would be something different. However I tried that first, and it does not appear to be the problem
  • Anonymous May 02, 2008
    mouse stopped working; installed batteries and it lights up. Did this before and I pushed a button and it would start working. I have called in and this is what I was told to do. I need a number to call.
  • Anonymous May 20, 2008
    Same problem. It's not lint on the optics - if it was the mouse buttons would work and they don't.
    New batteries. Cables cleaned and reinserted. Liberal use of reset buttons on mouse and receiver.
    Another electronic piece of landfill.
  • Anonymous Jun 12, 2008
    cursor was erratic. changed batteries and curser will not move.
  • robertpoe Sep 05, 2008
    changed batteries.cursor will not move.
    batteries are new.
    New Friend:
Hope this helps others. My mouse stopped controlling cursor but buttons worked. Problem was it would not work on a black table. Slip a piece of white paper under it and waaala! It works. I'm thinking optical mouse and dark surface might be an issue.
Posted on Dec 28, 2009
  • 101 Answers
Is it an optical mouse?  clean eye of lint.
Posted on Oct 11, 2007
  • Debra V
    Debra V Oct 13, 2007
    the eye is on the bottom. The laser light that 'sees' the surface it's on. Don't look directly in it. It is a laser.  Make sure nothing is blocking the light.  Do NOT open it up.
    President:
  • 317 Answers
Have you tried changing the batteries?
Posted on Oct 10, 2007
2 Suggested Answers
SOURCE:
SOURCE: Mouse stopped working, but appears ok, batteries ok, can't determine problem
I had this same problem. It works fine if i use my left hand instead of right. Could there be left and right handed mouses??? Go figure!
Posted on Jul 16, 2009
Logitech M510 suddenly stopped working
What does the device manager say about the hardware?
It could be loss of the usb device controller. Windows XP is old and that is an indication that the hardware is old too.
Mar 25, 2017 | Logitech M510 Wireless Laser Mouse
Clicking issues on logitech wireless mouse
  • 1 Use the mouse on the same side of the computer where the Logitech USB transmitter is attached so there is a clear signal between the transmitter and the mouse.
  • 2 Check the USB transmitter that comes with the Logitech mouse to be sure it is correctly plugged into the computer. The red LED should be illuminated on the transmitter if it is connected properly. If not, the signal cannot reach the wireless mouse.
  • 3 Turn the mouse upside down to check the on/off switch. Be sure it is switched on.
  • 4 Check the battery compartment by sliding the top housing off the mouse to confirm the rechargeable batteries are installed correctly.
  • 5 Charge the batteries if the mouse LED does not illuminate. The charger cord plugs into the front end of the mouse and the other end connects to a free USB port on the computer.
  • 6 Clean the desk surface or other flat area if the mouse is not tracking. The problem could be dirt or grease interfering with the tracking ability of the device.
  • 7 Open the Logitech software called SetPoint, which manages the mouse, to troubleshoot button functions. Open the program by double-clicking SetPoint from the list of software on the computer, then click "Mouse Settings." Click the "My Mouse" tab and check (or uncheck) all the task boxes that are desired for operating different mouse functions, then click "Apply" and "OK."
  • Mar 17, 2012 | Logitech Cordless Mouse
    My logitech cordles mouse m/n M-R0014, p/n810-001882 has stopped working.
    According to your problem, If you can't access your mouse in your then first check the receiver battery of the mouse is OK. Try to update the external device driver from device manager.You can also try download the device driver from the product website. If it doesn't't help you then replace the mouse.
    Apr 28, 2011 | Logitech Cordless Mouse
    Hadn't used my laptop and vx mouse for about 2 years. was fine when last used. now, nothing. threw in fresh batteries. cursor won't budge.
    I guess you need to pair the mouse with the receiver once again. Logitech provides connection utility on their support site - http://www.logitech.com/en-us/428/3271?softwareid=4338&osid=14&section=downloads.
    However, I would check that the battery connectors are still OK on the mouse. When you turn the mouse on, does the light come on?
    Jan 23, 2011 | Logitech VX Nano Cordless Laser Mouse
    I have problem with my logitech wireless mouse it wont work i have an acer laptop
    Hello, have you tried new batteries? Mine stops working even though the red light is still on, so you'd think the batteries are ok....and it's always new batteries that fixes it.
    Regards,
    nicam49
    Jan 10, 2011 | Logitech Cordless Mouse
    My 2 year old son got hold of my Logitech wireless mouse, and coincidentally it has stopped working. The batteries have been changed, but still no joy. Could something have been pressed to disconnect the...
    Yes, it sounds like something has been pressed.
    There is a small button underneath your wireless mouse, and a more prominent one on the receiver connected to your computer.
    To pair the mouse to the receiver, press the button on the receiver, then the button on the mouse. That should fix it up.
    Oct 13, 2009 | Logitech Cordless Mouse
    New batteries ok. mouse connects to station and
    I'm afraid it does sound like your mouse is beginning to fail. I would seriously consider replacing it.
    Jun 10, 2009 | Logitech Wireless Access Duo Optical...
    Mouse does not work. has new batteries, was working, just stopped, changed batteries then nothing. got to help me please.
    Change batteries of mouse. if it does not help then uninstall driver for mouse and reinstall it.
    and the also if it does not appear to work then its time for getting new one.
    good luck
    May 13, 2009 | Logitech WIRELESS OPTICAL CORDLESS MOUSE...
    Is the batteries good. If so try,
    Normal 0 Press the Receiver button (and the lights will start flashing.
    Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
    If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
    Hope this helps. Bud
    Jun 08, 2008 | Logitech Wheel Mouse Optical
    Logitech Cordless Mouse Logo
    1,353 people viewed this question
    Top Logitech Computers & Internet Experts
    Ekse
    Damen Wong
    Damen Wong
    Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
