Question about Sony ICF-CDK50 Clock Radio
My unit lost its sound. everything works but no sound?
Lights, clock, timer, CD tray, info on dash is there. Everything but no sound!
No dash lights when headlights are turned on. Everything works fine on my vehicle EXCEPT today the panel lights don't work. Turn signals, hazard blinker, oil gauge, rpm gauge, speedometer, drive shift...
there is a regulator for the display brightness, you may have it turn'd down or it has stopped working;. it controls the brightness at which the dash lights are. usually has a speedo sign on it. goes up and down. it works with the main light and is conecter to them on the same lighting board if it has gone then a new light swtch control switch will be needed.
Oct 13, 2013 | 2001 Chrysler Town & Country
Model MH7130xez won't heat. everything else works. the clock, timer and lights. does this model have a fuse?
if unit won't heat, then there is a problem with either the magnetron or the diode. if its the magnetron, the microwave will sound almost normal. if its the diode, it will make a humming sound
Mar 26, 2011 | Whirlpool MH7135XE Microwave Oven
Replacing a aftermarket stereo in my 2000 eclipse gs
I had the same exact problem with my wife's 2003 eclipse. Her sun roof, center display, key fobs/ alarm, radio 2000 Mitsubishi Eclipse
How do you reset the clock in an Alpine...Com 9821 dash stero...I
unplug the the wire at the back of unit everything will reset
Jun 20, 2009 | Alpine CDM-9821 CD Player
Microwave not heating
OK, if everything, including the fan, is working, this will confirm Magnetron failuer. you cannot reset the function of a failed Magnetron heating unit. replace this failed device asap if possible.
Jun 05, 2009 | GE Microwave Ovens
Illumination?
you need to splice the + wire into the Acc wire. the with power only when you turn the key. and the - wire into the black ground wire. hope this helps
Jan 29, 2009 | iLO XM-MP3-CD Car Stereo
No dash lights and gauges dont work
Ok first of is fuses. Is the radio lights and everything else working? If so i would start looking into the cluster it is all one unit and is a plug and play deal if for some reason it got loose. or it just is bad. Please get back to me with more info.
Jan 01, 2009 | 2002 Dodge Neon
Cant get the Unit to respond to the remote control
My remote won't work. It will work once, maybe twice and then no response from it. New batteries, haven't dropped it, etc.. HELP !!
Aug 19, 2008 | Audio Players & Recorders
Emerson iTone iC200 Clock... Problem
I get no sound on either the radio or CD player. I need help.
Nov 17, 2007 | Emerson iTone iC200 Clock Radio
CD tray doesn't open
if the unit actually tries to open but does not, it is not locked. a locked unit does not even try to open. it sound like a mechanical misalignment. take it back to get a new one, since it's only 2 days old.
Nov 12, 2006 | Sony CMT-CPX22 CD Shelf System
Sony ICF-CDK50 Clock Radio Logo
41 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
