Why does the picture do this. Press sky on remote and all colours seem to b wrong but when tv button is pressed the pic is fine but not hd
Seems to b a scart or sky box fault. Tried 3scarts and all the same. So having to watch sky tv in tv mode and not after sky button pressed. This is a brand new tv but my last tv did exact same for 3yr but was an old tv so just assumed age of tv was the problem but obviously not. When I change sky settings rom rgn to pal it sorts this :(
  • 794 Answers
If you are getting your video picture (t.v) through a cable box, satellite dish etc. you will have to adjust the internal settings of that box to match the HD settings of the T.V. as well.
Posted on Nov 27, 2013
4 Suggested Answers
chrispurs1
  • 372 Answers
SOURCE: Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Posted on Jan 20, 2008
  • 90 Answers
SOURCE: no sound on the hd setting on my lcd phillips hd tv
look in the owners manual about installing devices or components--- sounds like you have something hooked up wrong that is not allowing the video and sound to work--- if that doesnt work--- try using a combination device and hooking the two items to it--then run that device's wires to the television
Posted on Feb 24, 2009
milkburp
  • 416 Answers
SOURCE: recently purchased a Sony Bravia KDL37EX403 1080p
Your old TV was most likely a SD (Standard Definition) TV. SD signals look better on SD TV sets than they do on HD TV sets. This is normal. If you will, imagine having a tiny wallet photo reprinted as an 8"x10" photo. The image would be grainy and not have the crispness of the original. This is the same principle. Your SD source is being blown up to fill an HD screen. Once you add HD to your programming, the old TV will be forgotten. I hope this was helpful.
Posted on Jun 12, 2010
Sky hd remote code needed please
Sky High Definition SkyHD uses a new design of Slim line remote control. The Default TV code pre-programmed into the RCU is now for Phillips and is (0)065. The SkyHD RCU is programmed in the usual manner using either the instructions in the Digital Installation Manual or via the Sky Customer Service option in the Interactive on-screen menu.
The SkyHD RCU can also be programmed to operate Sky+ boxes as well as SkyHD:
Press the TV button.
Press and hold SELECT and i together until the LED flashes twice.
Press the number button 1 and then press SELECT.
(Obviously you can't have a SkyHD and a Sky+ Digibox both in the same room).
Note: To re-programme the RCU for Sky HD box operation only, repeat the above process pressing the 2 button in step three.
Keep pressing HELP and waiting a few seconds until you find the correct command that activates the AV source you require then press SELECT.
The HELP button will now directly activate the chosen AV source instead of toggling through the alternative options to reach it.
There are 18 AV source commands to be tried before the RCU blinks 3 times to indicate it is out of options.
The Sky Guide buttons (SKY, tv guide, box office, services & interactive) can now be directed to use the same AV source as the newly programmed HELP button.
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice.
The Sky Guide buttons will now instruct the TV to switch to the desired AV source and the RCU will be in Sky Mode.
Discussion here: http://www.digitalspy.co.uk/forums/showthread.php?t=944054
You can also use a Sky+ remote to control a SkyHD digibox.
See codes page for SkyHD
Mar 17, 2010 | Televison & Video
Operating Manual for aToshiba CT-9371 remote or TV #CX2769J
press menu or red button ( NOT STANDBY ) find pic format( aspect ) and change screen size to match tv
Nov 07, 2009 | Toshiba Televison & Video
Technika sky code volume needed 42-502
0246 is the code 1st cover the top of the remote with your hand press TV you can now move your hand, now press and hold select and the red button togeather the remote light will flash twice enter the code 0246 then press select cover top again and press SKY button it should now control your tv
Jun 03, 2009 | RCA DIRECTV Satellite Remote Control
Grainy Sky+ Tv picture
Can't say it's a fix but when you press the tv button to make the picture better, cover the end of the remote and press sky so the tv and box don't pick it up.
It's more of a work around than a fix!
Mar 30, 2009 | Panasonic TH-42PHD8UK 42 in. Plasma...
Cannot find code to program sky remote control
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0156
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Mar 12, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Remote control code
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Feb 15, 2009 | Panasonic TH-42PZ80B 42 in. HD-Ready...
Cannot optimize picture width on new flat screen HD
On your cable box remote press the hd zoom button. I have comcast cable box and it worked for me.
Dec 25, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
PHILIPS 32PF7331/12 LCD TV
Press tv on sky remote then press help ,channel list appears . goto tv set use onset channel change button to scroll to hd channel .press volume up button onset to select.
Sep 28, 2008 | Philips 26PF5320 26 in. LCD Television
32PFL5232D/37
The code is 0081 and this is how you do it.
'4 digit' or 'Brand Set' method
1. Turn on your TV.
2. Press TV on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press TV on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press TV , then press the on/off button. Repeat this (press TV , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press TV guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide, you must now set the TV Guide function as follows:
8. Press TV on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice. The remote control setup process is complete.
Mar 11, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
2. Press tv on your Sky remote control.
4. Press tv on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
7. Press tv guide .
If you did not see the TV Guide,you must now set the TV Guide function as follows:
8. Press tv on your Sky remote control.
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Feb 13, 2008 | Televison & Video
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
