Question about Uniden BC72XLT Handheld Scanner
Scanner is always outputting fuzzy noise
I have a uniden bc72xlt that used to work fine, but now when I turn it on, no matter where I have the squelch set at it broadcasts static fuzz. Is there some easy fix I am missing or is it shot?? Thanks for the help in advance
  • 1 more comment
  • Anonymous May 09, 2009
    mine too. maybe a common fault. any ideas?
  • Anonymous May 17, 2009
  • Roberta Smith
    Roberta Smith May 11, 2010
    what you are listening to may have switched to digital.... unless that is a digital scanner you appear to out of luck
    President:
  • 2,761 Answers
The volunteers at FixYa don't like to respond to questions like yours because bad news answers often get us bad feedback.
It's difficult, if not impossible to accurately troubleshoot a scanner without a hands-on exam, but at a minimum, the squelch control is likely shot, and the problem could be worse than that. Parts are hard to obtain, and handhelds are difficult to work on. With the cost of repairs going up and the cost of scanners going down, your best bet is probably a new scanner.
Sorry for being the bearer of bad news.
Is your area going to trunked/digital systems? Before you consider a new scanner, check out your area's active frequencies and systems by visiting
www.RadioReference.com
Posted on Jan 02, 2010
I have a bc60xlt andno matter how i turn the squelch i get the same hiss what happened
The Bearcat Scanner is neat hand held scanner, Is the scanner programed? Depress the WX for weather and see if the weather channel is available. The squelch knob should be turned clockwise and the noise level should decrease (actually you are decreasing the allowable signals to be received). If you get no response from a know frequency, then the squelch pot may need cleaning or replacement may be in order.....Cost for repair at service shop may not be feasible.
May 26, 2014 | Uniden BC60XLT Handheld Scanner
It makes a sound like someone has there finger on the button all the time but it dose this all the time it won't stop that noise is 24/7 it started about 1 month ago begfore it worked fine everything came...
Hello ishaull.
Welcome to FixYa.
My name is John, and I will be assisting you with your issue.
You need to turn your SQUELCH back just a little, but not to much.
Just turn it enough so that the noise disappears!
Hope this was helpful. Your Comments and Testimony's are always welcome here.
Thanks for choosing FixYa today and in the future.
John
Feb 07, 2011 | Uniden BC72XLT Handheld Scanner
I have a Uniden BC72XL scanner and cats knocked it
In your manual, if you have one, if not look it up on the internet. There are ways with all these types of communications, to reset to manufacturer and factory settings at time of new purchase. Then proceed forward in programming.
Feb 15, 2010 | Uniden BC72XLT Handheld Scanner
Unbearable noise after every radio message - squelch doesn't help
Doesn't sound like you're doing anything wrong. Either the scanner is defective or your locale is using some kind of oddball system that's causing the noise. Take it back, show them what it's doing. If possible, try another scanner in the store and see if it does the same thing. You should be entitled to a refund, exchange, or full credit towards a different model . . .
Jan 20, 2010 | Uniden BC72XLT Handheld Scanner
How do i adjust the squlech on my unidenbc12xlt hand held scanner
The actual setting will vary according to the strength of the signals you're receiving, so it may require adjustment as you move around. With the unit scanning, turn the squelch down slowly until scanning stops and you hear a hissing noise. They slowly bring the level up until scanning resumes.
Oct 29, 2009 | Uniden BC72XLT Handheld Scanner
Won't pick anything up (uniden BC72XLT)
Not sure this would be a solution but...
Make sure you don't have the Ch. Locked out so it just skips them..
You may also try and let the scanner sit on one frequency that you know has chatter and see if you receive.
This unit also picks up local weather try that feature and you can tell if you reception is working or not.
Jun 23, 2009 | Uniden BC72XLT Handheld Scanner
Uniden UBC72XLT scanner problem.
The cheapest solution would be to directly program the frequencies that are available in your area, usually this is public information with the exception of high security channels, you can call each location and ask them what frequency they broadcast
Jun 06, 2009 | Uniden BC72XLT Handheld Scanner
Wont get any transmissons
Turn the squelch back until it screams at you and then turn it forward until the radio JUST gets quiet. If you have over squelched, you will also block the signals.
Mar 10, 2009 | Uniden BC72XLT Handheld Scanner
Bc72xlt-no audio/sound/ kids pressing buttons then no sound
The best I can tell you is try readjusting the volume and squelch again. Turn your volume up then adjust the squelch all the way one way and then all the way the other way. At one of the max settings you should get static noise. This should allow you to see if there is any noise coming out of the scanner.
If you get noise then recheck to see that the scanner is programmed correctly. If it has no frequencies or frequencies with no traffic on them, you will not hear them.
If there was no audio with the squelch then you may want to consider that there is a bigger problem. Page 53 in your manual describes how to reset your scanner. This might work as a last ditch effort. You will lose all of your current programming though.
Hope this helps
elijam1
http://www.scannermaster.com/?Click=37131
Dec 15, 2008 | Uniden BC72XLT Handheld Scanner
Uniden BC72XLT Handheld Scanner Logo
200 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
