Question about Brother FAX-575 Plain Paper Thermal
External TAD If I have an external TAD and it is impossible for it to be attached directly to the EXT jack on the FAX-575, is there a work around or a mode I can set that will allow both the fax machine and the TAD to work on the same line?
  • Frank_G Oct 11, 2007
    I figured it out. The solution is to to place the fax machine in manual recieve mode with easy recieve set to the on position. There is a drawback however, you have to be at the machine to press the hook button when a fax comes in. This solution would only be acceptable for those who send more faxes than they recieve but at least my TAD still works with the fax machine on the same phone line.
    New Friend:
  • 120 Answers
You ought to be able to set the receive mode to tad or something like that. that way you can receive faxes without being there. Lawrence
Posted on Feb 16, 2008
SOURCE:
I have changed from a desinated fax line to sharing a phone and fax line. the fax machine rings along with the phone however the fax does not answer. i was told to purchase a ring decipher but cannot...
Your fax can share the line with your phone, but it needs to be set to answer or not, depending on your equipment and choices.You can download the manual from Brother here. The receive modes are explained on page 5-1.
If you're often out when faxes or phone messages might come in, you probably need to plug an answering machine into the back of the fax (the EXT. jack) and put the fax in FAX / TAD mode. (TAD stands for Telephone Answering Device. Be sure the TAD is set to answer before the fax does. The fax will pass the phone call through to the TAD, and if it hears the beeping of another fax sending, it will cut off the TAD and take the call.
See the manual for more info and other options.
Feb 15, 2011 | Brother IntelliFAX 2600 Fax
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
TAD error
Change the RECEIVE MODE to FAX ONLY. TAD stands for telephone answering device which is used if one of this device is attached the EXT port.
Dec 08, 2009 | Brother IntelliFAX 560 Plain Paper Fax
My fax machine says enternal tad.
TAD stands for telephone answering device. you have to change mode to either fax or phone/fax.
Auto answer is also another option on some faxes
Jun 22, 2009 | Brother FAX-575 Plain Paper Thermal
Can not send or receive fax.
Is the phone line plugged into the "line" jack and not the " phone or Ext " Jack?
Jun 09, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Brother fax model 575 in Manual recieve Mode,won't change
Telephone Answering Device (TAD). This is the mode you use when you have answering machine active on your phone line.
Mar 27, 2009 | Brother FAX-575 Plain Paper Thermal
Fax will not recieve but will send fax
what does the display reed. To receive fax automatically the display needs to reed
( fax mode or auto ) . If in the manual mode you need to pick up the receiver listen for the tones then press start.
make sure the phone cord from the wall jack is from the wall to the line connection MOT THE EXT. CONNECTION on the fax ( nothing in between the wall & fax )
hope this works
C.W.H.
Dec 12, 2008 | Brother FAX-575 Plain Paper Thermal
Still can't get fax not to pick up when answering machine is connected.
if you have the fax-575 there should be a TAD setting.
This is the setting you would use if you're using an answering machine on the same phone line as your fax machine.
To set the Recieve Mode :
Press Recieve Mode. The LCD display shows your current selection.
Continue to press Recieve Mode until your new selection appears. After 2 seconds the screen returns to the date and time display, along with your new Recieve Mode setting.
The 4 Recieve modes are Fax Only, Fax/Tel, TAD:Answering Machine, Manual.
Hope this helps!!!
Jan 30, 2008 | Brother FAX-575 Plain Paper Thermal
What does "TAD" mean when it appears on the screen?
TAD is Telephone Answering Device. TAD mode is the only mode that can be used with an external telephone answering device (unless you are using a distinctive ring number for receiving faxes). Your telephone answering device must be connected to the jack on the fax machine (labeled "EXT" for USA). When someone dials your telephone/fax number (to send a fax or to speak to you), all the telephones (including the FAX) will ring according to the number of rings you set on the TAD. The Ring Delay setting is not recognized in the TAD mode. If you do not answer the call, the TAD will answer. As your outgoing message is playing, the Fax is in the background, silently listening for fax tones. If the FAX hears fax tones, it will automatically go into the receive mode. If the FAX does not hear fax tones, it remains silent, allowing the caller to leave a message. The above information is correct for a Brother fax machine. Is your fax automatically picking up the call or do you have to push a panel button to start the receive fax process? Perhaps the fax is already "in" your fax machine's memory and only needs a manual printout. Check the fax call log.
Aug 16, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother FAX-575 Plain Paper Thermal Logo
366 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
