Question about Miele G 1470 SCVi Built-in Dishwasher
Fault f13 What does fault F13 mean?
4 Suggested Answers
  • 37 Answers
SOURCE: F13 error code on Miele dishwasher. I can't find
The water valve on Miele dishwashers is built into the end of the water line where it hooks into your plumbing(in that box-looking assembly) Your best bet is to call Miele USA, I have had very good luck with their customer support system, they can usually diagnose your problem right over the phone.
Technical Support
Residential Appliances Hotline
(800) 999-1360
Monday-Friday: 8:00 am - 8:00 pm EST Saturday-Sunday: Closed
http://www.mieleusa.com/usa/contact/contact_miele.asp?page=1
Posted on Apr 20, 2010
SOURCE: My dishwasher is beeping and giving an F13 and F14...
mee too
Posted on Jul 22, 2010
  • 40 Answers
SOURCE: Optima G2430 Miele dishwasher with F13 error
F13 Indicates that you have a water intake fault. The machine is not receiving the the proper amount of water quantity. You could turn off the water supply and disconnect the water inlet hose. There is a filter inside, to remove the filter you have to take out the seal and then you could use a pair of needle nose pliers to take out the filter basket. If the filter is clean you and your water supply is good, you have a problem with your flow meter not registering pulses when the water is taken in.
Posted on Feb 08, 2012
What is error code f13?
The F13 fault code on this type of range indicates that the EEPROM (Electrically Erasable Programmable Read-Only Memory) on the control board is bad. This can be caused by a power surge or glitch through the electrical lines. You can try to reset the control board by completely unplugging the range (or shutting off the breaker) for 5 minutes. If the error code returns after plugging the range back in, then the control board for the range will need to be replaced.
Feb 05, 2015 | Thermador C301U Electric Single Oven
Frigidaire fault code f13 kitchen range what does that mean ?
Thank you for your inquiry, raymond bouley!
I understand that your Frigidaire range is displaying an error code of "F13". An "F13" error code typically stands for a bad EEPROM (Erasable Programmable Memory) identification or check sum error. The best way to clear this code is to disconnect power from your range for roughly ten minutes. If you continue to experience an issue it could be a possible that you have a faulty board or wiring harness. I would then recommend having a professional out to perform a diagnosis on your range. Hope this helps. -Matt
Jan 13, 2015 | Frigidaire Kitchen Ranges
Flashing fault code F13
Check your oven sensor is what I would do. See if it reads 1100 ohms at room temp. If it is open or shorted it is bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 26, 2013 | Frigidaire Gallery 30" Self-Cleaning...
When I try to turn on the oven it say f13 err
Most of the F13 fault codes say it is either the Main board or a temperature sensor.
May 10, 2011 | Ovens
Cant reset my f13 fault and wen i power on it takes its take to lite front panel up
Hi again,
Whirlpool AWO 'F13' decodes as 'dispenser circuit failure'. If you have tried switching off and back on again and it is still there I suspect it means that you will have to call an engineer. Sorry ;-0(
Good luck,
John C
Mar 29, 2011 | Washing Machines
I have a F13 fault that wont reset on a AWOE9759. I do not know what a F13 fault is but i have tried what it says to do in the manual. Please help.
F13 Error = Dispenser circuit error
If the dispenser motor is not able to be driven to it's proper position.
Potential Causes
• Check mechanical linkage from dispenser motor to the top of the dispenser.
• Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
• Check Dispenser Motor
Replace failed component.
Dec 26, 2010 | Whirlpool Washing Machines
I get a error f13 when i turn on broiler
http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx
Above are the codes and meanings.
The "F13" error code means "Bad EEPROM identification/Checksum error".
If reseting the power does not help then according to Frigidaire suggested corrective action the electronic oven control (aka EOC) has to be replaced.
- The part number for the EOC is AP3874704
Dec 13, 2010 | Frigidaire Kitchen Ranges
I have error code f13, can you help, please..
This s is how i fixed the F-13 Fault on my Hotpoint WD 640 washer dyer. Simple to fix just see the pictures and explanation. Hope this clears things up
Boxie
1_7_2013_12_28_59_am.jpg1_7_2013_12_29_33_am.jpg1_7_2013_12_31_38_am.jpg1_7_2013_12_31_56_am.jpg
Aug 07, 2010 | Dyson Memory CRO1 Front Load Washer
My whirlpool washing machine keeps saying f13 whats wrong and how do i fix it
Hello, the F13 means "Dispenser Circuit Error", if the dispenser motor is not able to be driven to its proper position.
Check the following:
1. Check mechanical linkage from dispenser motor to the top of the dispenser.
2. Check wire harness connection to the dispenser motor and Central Control Unit and lastly
3. Check dispenser motor.
Thanks
Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to fix the F13 error in this stove
F11, 12 & 13) Disconnect power, wait 30 seconds and reapply
power. If fault returns upon power-up, replace EOC.
Apr 15, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Miele G 1470 SCVi Built-in Dishwasher Logo
51 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
