DIM SLOT'S 1,2,3 not working. Only DIM SLOT 4 is working.
I have Foxconn P35A motherboard, The DIM RAM slots 1,2,3 are not working. Only DIM slot 4 is working. Please advice how to solve this problem.
  • 4 Answers
Try updating your BIOS to the most recent version, if that does not work then unfortunately it sounds like a motherboard electronics failure or it's just broken, I would try and get a replacement if possible.
Unless you are VERY confident in you electronics skills.
Posted on May 08, 2009
What's your problem?bit ix38 quad gt motherboard with 2 gig of ddr2 ram i want to add a 1 gig stick of more ram that ive bought how do i do this? thanks windows seven
Top view of motherboard, scroll down. (Thought you might also like to read the reviews, and Comments)
http://www.bit-tech.net/hardware/motherboards/2007/12/06/abit_ix38_quadgt/2
Motherboard User Manual,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
1) On the motherboard the Blue ram memory slot that is closest to the copper heatsink, is ram memory Slot 1.
Also known as DIMM 1.
Ram memory ALWAYS has to be in this ram memory slot.
The Processor reads ram memory Slot 1 first.
2) The Blue ram memory slots are Slot 1 (DIMM 1), and Slot 3.
(DIMM 3)
The Black ram memory slots are Slot 2 (DIMM 2), and Slot 4.
(DIMM 4)
To run Dual Channel ram memory, means there are two LIKE ram memory modules ('Stick'), and they are installed in the SAME channel.
This would mean to alike ram memory modules, in both Blue ram memory slots, or both Black ram memory slots.
Since the ram memory modules need to be alike, they are generally purchased from the same manufacturer, and are the same kind.
Running ram memory in a dual channel configuration, is supposed to increase ram memory 'speed', up to 30 percent.
This is Baloney!
May look good on paper, but in actual use in the field it's cr@p.
Actual performance increase is more like 1 to 2 percent.
This has been proven by Tom's Hardware, and many, many motherboards, ram memory, Processors, etc.
So you have 2GB of DDR2 Sdram, huh?
Is it just one 'stick' of ram memory, or are you referring to two 1GB sticks?
If the above holds true install them in Slot 1 and Slot 3.
If not, and it is a 2GB stick of ram memory, be sure it is installed in Slot 1 (DIMM 1)
Install the 1GB stick in Slot 2.
It isn't the same as the 2GB stick.
It is 1GB.
Does NOT go in a dual channel configuration.
(Catching all this? There is NO dual channel ram memory!
It is ram memory that is -> ALIKE, and used in a -> dual channel configuration.
Used in two separate ram memory slots, that support the dual channel configuration.
Sold with the advertising scheme of 'Dual Channel', but really just means the two ram memory modules, (Or four), are -> alike.
1) Same Voltage used
2) Same Ram Timings
3) Same Chip Configuration
4) Same size in amount
5) Same frequency rate ('Speed')
With ram memory in a dual channel configuration, the ram memory modules team up on the task.)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 31, 2012 | Computers & Internet
I cant access my graph it says err:dim 1:
It is a serious problem dim 1 is your ram at the 1st slot
if you use two rams it will affect the other so remove the ram at the1st slot immediately if you have two
else
change your ram
Aug 11, 2010 | Computers & Internet
Foxconn a6vmx motherboard , just installed but no vga output?
Check the Motherboard to make sure that the jumpers on the motherboard are not set to disable the slot. Try the card in a different pc. Try a diffrent card in the same slot. That should tell you if it is
1.motherboard
2.slot
4.or card......
Good luck, hope this helps,
James.
PLEASE VOTE 4 THUMBS UP 4 ME!!!!!!
Apr 26, 2010 | Foxconn A6VMX Socket AM2+ AMD Motherboard...
Dear Sir, My SDRAM were the same and it does not work although I heve changed their position. Best Regards, An.
Try the sticks of RAM, one at a time:
* stick 1 in slot 1
* stick 1 in slot 2
* stick 1 in slot 3
* stick 1 in slot 4
* stick 2 in slot 1
* stick 2 in slot 2
* stick 2 in slot 3
* stick 2 in slot 4
to find something that works.
Oct 09, 2009 | ASUS SiS Chipset TUSI-M Motherboard
One of my ddr2 ram slot is not responding
1. Shut down your computer & unplug the power cord.
2. Try cleaning the slot where the RAM module did notwork using non-oily contact cleaner spray.
3. After spraying the cleaner into the slot, use a brush made of animal hair to clean the slot.
4. Leave it for about 10 minutes to make sure that the liquid totally evaporated off the slot.
5. Install your memory module & power on the PC to test.
6. If it still did not work, swap the 2 memory modules & try again.
Jun 10, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Can i upgrade RAM from 533MHZ to 667MHZ for P4M800P7MA?
Please try to upgrade your BIOS, it may solve the issue.
Jan 14, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Ram not working with motherboard
Hi
Check if your motherboard only supports only dual channel interleaved memory from the manual because it might be the main issue of your problem. Also DO NOT plug in the 512 MB ram you have over there. If it is ok to have one Slot empty then there should be no reason why it should not POST properly. Before jumping to conclusions that the RAM is faulty. Make sure that you REMOVE any overclocking you might have on the system. Some RAM won't post wihen the CPU clock and multiplier are not standard. Also it could help if you load FAIL SAFE settings in the BIOS until you determine the proper cause of the problem.
Hope that this helps :) (please rate thanks)
Jan 07, 2009 | Intel D865GBF Motherboard
Motherboard manual ?
is jumpers on 1 and 2 good power test ram front conecter on pw
Jan 23, 2008 | Computers & Internet
OS won't work with RAM upgrade
Hi !
if u wanna upgrade RAM ,ur RAM should be of same capacity in both slot. i mean to say if u wanna use 1 GB....then put 512 & 512 or else put single 1 GB. But u cant use 512 in one slot & 1 GB in another slot at a time. if u do the combination like that ,it will never work.
--APARNA (Mumbai)
Jan 12, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Ram
Maybe one of the memory slot on your motherboard is faulty. Try testing each slot by placing one memory module on a slot and start your pc. If your pc made beeping sounds, that slot might be faulty. Do this on the other slots.
Dec 17, 2007 | Foxconn 6150BK8MC-KRSH Motherboard
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
