Question about Intel Motherboard
Help!!! My computer just stopped working. when i put it on it seems everythings working fine. All the light comes on normal in the case and fans working as well but there is no signal to monitor. I tried with different moniter but it was still the same. I have been trying last 2 days and windows came up few times but only for short time then goes to blank blue or stripe brown and then frozen. i think I might have prob with motherboard or maybe cpu but not sure, any idea? thx my computer is packard bell IMEDIA 1516
  • leighsoner Oct 11, 2007
    Hi
    thanks for the tips. One of my colleagues suggested that my problem might be with psu so I took it out and give a good clean. because it was quite dusty anyways since then now I got no power at all. I checked all the connection and connected correctly but now power supply doesn't work. Is it possible that my problem was always with power supply? Thanks again
  • astrotalon Jun 24, 2008
    when I press the pwr button, the led on front blinks and the fans budge, then nothing. To even get the same result, I have to turn off the pwr switch on back of the computer, wait a few seconds, then turn it back on and press the pwr button on front. the psu has been checked out ok, I've switched the pwr button and restart button but nothing has changed.
    Scholar:
  • 116 Answers
It would seem that pc has an integrated video card.
So riddle me this ;) Does the machine give you any post codes?
Those would be the beeps you hear when the pc is loading.
If you power it up and let it run a while, and press the power button briefly, does the machine shutdown. This would indicate that the pc is booting into windows, and windows shuts down as it should.
Your Processor is not likely to be bad, your main board more likly, and the video card most likely.
With any luck you could replace the video card, to do this would be to install a new card, and disable the on board in the bios, or via jumpers.. However because the on board video could be the problem, that would mean the rest of the board may not be far behind.
Posted on Oct 10, 2007
    President:
  • 317 Answers
There's a pretty good chance your CPU is bad.
Could also be the video card.
SOURCE:
No heat just a/c fan works new thremostat flushed heater core seems like everything under the hood is fine temp gauge is normal just no heat
There is a simple test you can do in case the blend door is stuck. On the climate control panel, simultaneously press the OFF and FLOOR buttons, then within 3 seconds push the AUTO button. It is best to do this with the engine warmed up, but you can do it without the engine running, just turn the key to ON position. It will cycle the mini computer for a few seconds, After it stops, press the defrost button. Might fix it for free.
Nov 05, 2011 | 1996 Lincoln Town Car
Sanyo Projector PLC XU83 lamp is replaced 1 everything is fine 2 projector turned on and reset the counter 3 projector switch off and normal 4 Next time imposible to power on the projector After ...
Check the cooling fans. If they are not rotating the Projector will not start.
Did the lamp explode? If it did a bit of glass has lodged in the cooling fan and stopped it from working.
Hope this helps.
Nov 15, 2010 | Televison & Video
Installed the Altura 56" fan (56ATR), worked fine at all speed until we put on the light. Everything worked fine for about 10 minutes, then the fan stopped working, but the light stayed on. Kept trying...
both the fan and light have a common connection .. usually all the white wires are connected at one wire nut .. check to see if the fan wire has pulled out of the wire nut ... remove the wire nut and re-tighten it .. pull on each wire to make sure each one is secure ..make sure power is off before working on this ...
Aug 15, 2010 | Heating & Cooling
When powering from full shut-down, takes about 30
whenever you want to turn it off, put it on hibernate.
Jan 02, 2010 | Toshiba Satellite M35X-S161 Notebook
MICROWAVE NOT HEATING
Most likely you have a magnetron problem. Easy to replace (DYI) but make sure the high voltage capacitor is fully discharged first against the case.
Dec 11, 2009 | Kenmore 62622 Microwave Oven
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Power shuts off and takes several minutes to turn back on
If the computer is overheating, those are the symptoms that would happen. Turn on your computer with the cover off. Are all the fans working (even in the power supply)? Is there a lot of dust build-up anywhere? Can you try another power supply? You need not install it in the computer case, just hook up the connectors with the known good power supply just outside the case and try it. Is your processor heat sink securely connected to the processor?
Dec 29, 2008 | Dell Precision 670 (670MIN) PC Desktop
Samsung SMH7178STD microwave fan stopped working
It looks like the part of your computer board on microwave which responsible for controlling light and fan stop working. In this case you have to replace computer board.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 03, 2008 | Samsung SMH7178STD Microwave Oven
HELP! WIRING...LIGHTS DO NOT WORK
Yes, the blue wire is for the light. Just connect it to the hot wire (black).
Jul 15, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
