Question about Nesa Vision DVD-1002 Car DVD Player
Need to reset nesa dvd. lost signal
The dvd player worked. the buttons on the front of the player got hit and it lost signal to the screen
4 Suggested Answers
SOURCE: Nesa DVD 1002 in car DVD player
do you have the remote?
Posted on May 21, 2008
  • 83 Answers
SOURCE: NESA DVD-1002 Car DVD - Region Codes
Oh that sucks... I had the same issue with a Sony Xplod Indash DVD Player, You have to contact the Manufacturer, They will either replace the system, or explain to you how to fix it, In my case they replaced mine.
Posted on Apr 14, 2010
jdvillanueva
  • 2098 Answers
SOURCE: my Nesa portable car dvd
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust and any fine foreign objects the lens can't read any disc. If you have a DVD Lens cleaner, play it to the unit. If this is not available you may manually clean the optical lens. Open the cover and gently clean the eye of the lens by smooth,clean,soft cotton buds. Be careful while doing this, just a gentle stroke only.
2.Check the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Click this link for more info.
LINK1
LINK2
Hint : Most of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Jun 05, 2011
I have the nesa nsd-741n how do i mess with the eq put the treble up and also bass
hi wats up i have this tv radio too n i dint know how to do it either but i found out that u have to hold the NAVI button for a couple a seconds and a new menu pops up
Jul 06, 2010 | Nesa Vision NSD-590 7'' Fully Motorized In...
My remote no longer works and i need to get a
Maybe you only need to replace the battery on your remote...
Jun 06, 2010 | Nesa Vision DV-2002 Car DVD Player
Apr 14, 2010 | Nesa Vision DVD-1002 Car DVD Player
Will not accept dvd
you've got a bad player. the motor inside that plls in the disk and spits it back out is toast. replace the dvd player
Feb 16, 2010 | Nesa Vision NESA NSCM-1040 Overhead Flip...
Our Nesa DVD-1001 that is installed in our surburban has stopped working. It lights up but won't load the discs. Any suggestions?
Check the fuse for your cigarette lighter the unit neees 12v constant and it gets it from that circuit
Dec 18, 2009 | Nesa Vision DVD-1002 Car DVD Player
CYBERHOME DVD PLAYER WON'T WORK
Dear friend,
Press and hold STOP button on front panel of the player more than 5 sec. The player reset after 5 sec.
Dec 13, 2008 | Cyberhome CH-DVD 300 DVD Player
Stuck in Progressive Scan Mode...please help!
There should be a switch on the DVD player that is makred 'progressive/interlaced.' You need to flick this switch til it says interlaced, as obviously your TV cannot view progressive signals. It may be on the back of the player, or under a flap on the front.
Feb 04, 2008 | Televison & Video
Tview dvd
hi i have a nesa 180 in car dvd, i can only get sound through the nesa nhp-1 head phone, can i get sound with out them, also one of my head phones is broken were can i get a replacement.
thanks
Aug 29, 2007 | Nesa Vision NSC-180 Car Video Player
NESA VISION 10.4
These are the guys you need to contact; http://www.nesavision.com/contact.html Hope this helps :)
Apr 21, 2007 | Nesa Vision NSCM-1339 13 in. Car Monitor
Nesa Vision DVD-1002 Car DVD Player Logo
42 people viewed this question
Top Nesa Vision Car Audio & Video Experts
jdtech
ray gallant
Are you a Nesa Vision Car Audio and Video Expert? Answer questions, earn points and help others
