Question about Refrigerators
Ice forming on compressor return pipe.
I have kalvinator no frost model knt 283gy . there is ice formed on return pipe of compressor when the refregerator is cooling. Is it bad for compressor? do i have to reduce gas in the fridge or shall i keep it this way. Thank you. Rafiq
    President:
  • 1,136 Answers
Did you just change compressor? It is more likely that your refrigerator is running to long (check control settings) or that you are starting to get a defrost problem. You should never have to add or remove freon for any kind f adjustment unless you have pierced the cooling system for any reason.
Posted on May 08, 2009
Refrigerator not making ice properly
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Jul 13, 2011 | Refrigerators
A layer of ice keeps forming in the bottom of the freezer. can chip it out and a new layer will start forming by the next day. also has a lot of frost as well. thuoght was the seal and have attempted to...
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Jul 07, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I woke up this morning to my refrigerator humming and not working. It is 5 years old. The freezer seems to be just fine. Help! It is stainless steal model PFSS5NFWASS
Top of Form
Jun 13, 2011 | Microwave Ovens
I have a refrigerator Bosch Model KSU45621AU Auto frost and the Fridge compartment is not running at a cold temp can you help Please. Thanks Ali
Top of Form
May 28, 2011 | Refrigerators
Fridge not getting cold and freezer frosting up and over freezing model frc150ffs. only 2 years old
Top of Form
Feb 24, 2011 | Refrigerators
Freezer not working red light on indicating high temperature and fridge is starting to ice over, drinks forming ice in them
Top of Form
Oct 11, 2010 | Hotpoint Refrigerators
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Frigidaire FRF170FF Freezer,rear of compressor, ice forming.
Fire that engineer. Topping off a fridge is amatuer at best and criminal at worst. The frost is occurring because it has too much gas in it. Let a little out while it is running and it will cease frosting. Hope this helps!
Jan 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer won't get cold
Defrost the unit completely.  There may be ice blockage preventing proper cooling.  You may also be low on gas.  With the unit off for an hour, restart while observing the largest pipe on the compressor.  It should frost and then after about 15 minutes either dry out, form ice or water on it.  If it is still frosted, it will need a recharge.
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost forming around ice dispenser inside side by side Fridge
The presence of frost indicates that the dispenser(ice) probrably isn't closing all the way once you get ice. This allows warm air to rise up, condense and form frost. In all likelihood the solenoid that controls the opening and closing is bad and needs to be replaced.
Jul 10, 2008 | Kenmore 55692 / 55694 Side by Side...
Refrigerators Logo
232 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
