Question about Canon LaserClass 9000L Plain Paper Fax
Product is telling me doc. is to long when i try to fax a paper also it will copy only the bottom portion of anything i try to copy help please
My 9000L will not send faxes its telling me that the form is too long, also when i go to make a copy its only printing the bottom portion of what i'm trying to copy. is there a setting that i need to change and if so how
  • 1,219 Answers
No there is problem with slow sensor flaper and pick up, feed and separation roller, clean it all, you may need to change the sensor flapper.
Posted on Mar 06, 2010
Printer is only half printing doc on each line, have done test page, very faint, aligned ink, clean cartridges, all with top v faint and bottom dark ink, new cartridge last fri and was working well,...
Open the rear of the printer and make sure theres no paper jam or broken parts.
Try printing a document with the rear of the printer open and watch to see if anything out of the ordinary happens.
Mar 01, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
"Replace Drum" error ...HELP!
Drum is only to be replaced when machine says "Replace Drum".
Not "Replace drum soon".
Try Programm, * , * , I(Capital Letter I ), then ENTER.
Should reset it.
Apr 22, 2010 | Muratec F320 Plain Paper LED Fax
Keep getting a "check original" message on screen - won't fax or copy
the check original relaates to the document you are trying to copy or fax check the guides for the document input and check you are putting teh doc in far enough yuoo can also lift the cover and check there isnt any obstruction .. basically the sensor that lets the machine know you have a doc on the go isnt getting actuated to start the process..try and put a thick piece of card in the doc feed part to see if it goes through it might push through the obstruction
Aug 05, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
HP Office Jet 7410 printer copies, fax are black
If you make a copy and it is black, either the ccd (reader is bad or the lamp is out) either is the end. Take it back to staples if you can.
Make sure you unplug it for about 1 hour and plug back in and try a copy.
Apr 28, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Can't send or receive fax
Your product must be accidently set to copy mode instead of fax mode and when it is, it actually expects a document to be loaded in the tray to "scan/copy" so change to fax mode again and try to sent the document. This should fix your problem.
If you do want to make a copy, make sure a doc. is loaded and press start copy to do so.
Jan 06, 2009 | Canon FAX L-120 Plain Paper Laser
New cartridge; now won't print any document, fax or copy
It is not impossible to get a brand new bad ink cartridge. I've seen lots of bad ones.
Oct 04, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Copying and fax sending problem
  1. Just check & clean the dust in the original feeding area.
  2. if not solved, clean the Document feed sensor or replace the same. But for this you need to open the body of the fax machine.
Mar 11, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Problem with sending faxes
change a paper size in the fax setup
Feb 04, 2008 | Office Equipment & Supplies
Fax machine won't copy or send a fax.
IT MAY BE A CIS BUT  I WOULD TRY A SYSTEM CLEAR FIRST
FUNCTION *2864 IN SEQ. THEN 01
Sep 30, 2007 | Brother IntelliFAX 4100 Laser Fax
Canon LaserClass 9000L Plain Paper Fax Logo
old marine
old marine
