Oki b710 code flash error firm ware upgrade
Oki b710 is giving a code flash error firm ware upgrade when trying to print
5 Suggested Answers
SOURCE: I have a OKI B2500 Series. When Print Says Printer Error FuserTem
If you have not fixed this by now, I have the fix.
Turn the printer on, hit the following keys on your printer:
down arrow, *, #, ok, 1, ok
After that, hit the down arrow until you see T>Printer and then hit ok.
Next turn off the printer, count to 5, and then turn back on.
Repeat the first step, but in place of the number one, insert the number 0.
These were the steps given to me by the oki customer service and it fixed my printer. If you have problems, the number is 800-654-3282.
Posted on Nov 11, 2009
SOURCE: Radio Shack Oki C6100 wont print color - firmware needed !
Hey, I got it worked out so that it will print color. I called OKIDATA and initially they said they didn't know what to do and you needed to go back to Radio Shack. Then after talking to a supervisor the associate gave me the following instructions to download
1 - go to okidata.com 2 - click on "drivers" at the top of the page 3 - select "color page printer" 4 - select "C6100n" 5 - click "go" 6 - on the new page that comes up, on the left side of the page, click "Utilities" 7 - Scroll down to "English Job Accounting SERVER" and download the file (version 3.54) 8 - After the program is installed, open it and click the Printer Tab and "Add A Printer" 9 - Once the printer is found, it should show up in the list on the right of the screen. 10 - Right-click the printer and select "properties" 11 - Click the "User" tab - there should be in the status row something about "disabled color printing" 12 - Double click on the rows that say that and for each do the following:
1 - Click the "Use Restrictions Tab" 2 - De-select "print in mono" and "disable color printing"
Then when you've done that for each row, Click "ok"
And then you should be good to go. It worked on my computer right after that. I'm directly connected via USB and also connected wirelessly through our small network.
Posted on Dec 07, 2009
  • 97 Answers
SOURCE: have a oki c9800 ...gives error 923
923: Error - Black Image Drum Lock Error
The K ID unit is not operating
properly.
Check to confirm that Image Drum is seated properly.
Check to confirm that the K ID
unit is in position.
Replace the K ID unit.
Replace the K ID motor.
Posted on Mar 29, 2010
puertobori
  • 7733 Answers
SOURCE: ii have the following code
Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English).
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 18, 2010
Oki MC361 keeps jamming when paper feeds from printer tray or manual feed.
Take out both the drum tray and the transfer belt. Reseat the transfer belt and make sure both clips at the sides are locked down. Reseat the drum tray and checked it is firmly located. Re-try your prints. If it still fails, take the paper tray out and check for a paper fragment in the paper feed path.
Oct 07, 2017 | OKI Office Equipment & Supplies
How to reset Oki 720 to factory default
Okidata B710 and B720 Maintenance Reqd. Reset Procedure
To enter the Diagnostics area:
Turn the printer power OFF.
Press and Hold the MENU^ and Enter buttons.
Turn the printer power ON (you can release these buttons as soon as "loading ... '' is displayed.
The Operator Panel reads "Diagnostics"
There is a list of Test Options and settings.
Press the Down Arrow highlight "Maintenance Info." Press the Enter button
The Operator Panel Display reads "Maintenance Info" with setting listed.
Reset Maintenance reqd. is highlighted. Press Enter
Reset Maint. Reqd. is displayed and Execute is highlighted.
Press Enter.
The Display reads - Resetting Maintenance Required.
This completes the process.
Dec 23, 2015 | OKI Office Equipment & Supplies
Impresora oki b6500
oki b6500 code flash error firmware upgrade que puedo hacer
Jan 15, 2014 | OKI B6500 Led Printer
Error codes
E7-90 - Image Processing Unit error
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Jul 25, 2013 | Sharp AR-M450N Copier
I have oki b710 and only loading... message is displayed but nothing else happeness printer doesn't initialize.
I called this number - 1-800-654-3282 available 24/7
and they have steps
1. Turn off the printer
2. Press the "menu" and "online"
3. Press until the screen says - "Format User Flash"
4. Press "enter"
5. Restart printer when prompted
Apr 11, 2012 | OKI Printing Solutions B710dn Printer
IC25n020ATMR04-0 firmware how can i remove the firmware and replace it
certain utilities from salvationdata or acer lab can help one do a firmware back up and restore, also certain hard drive companies like seagate and wd have firm ware backup and restore utilities,hitachi has its firm ware saved in three places on the harddrive in the SA areas as SA A SA B AND SA C. one has to have hdd hitachi from salvation data to back up firm ware , which i feel is an expensive affair. or just go to a recovery guy and ask for firm ware upgrade done by salvation data or acer equipments
if the charges are exorbitant , let me know the firm ware of your hitachi drive and i will try to give it to you. pm me if you are not in a position to back up by any of my recommended methods
datarecoveryfactory
Sep 04, 2009 | Hitachi 08K0632 (ic25n020atmr04-0) 20 GB...
Sharp ar-m205 error code E7 11
Feb 28, 2009 | Sharp AR-M205 Copier
System error 21
You should try doing factory reset, if it doesnt work then u should try to upgrade ur firm ware version.
Thank you
Feb 08, 2008 | Nokia N70 Cellular Phone
Memorex mmp8567
how do i format my player
Sep 07, 2007 | Memorex MMP8565 MP3 Player
1,904 people viewed this question
k24674
jasbo
jasbo
