Question about Samson dB1800a Subwoofer Speaker
Does samson db1800 have a fuse for speaker - Samson dB1800a Subwoofer Speaker
Reason for burning smell and no audio in my Samson d415
Did it suddenly stop working?
Maybe overload of amp or power supply.
I think you killed you power amp...
Feb 03, 2013 | Samson Auro D415 Active PA Cabinet - 400...
Samson db1800a stoped working
push on the speaker lightly to see if it moves in and out easly if not the speaker could be blown if thats ok pull the speaker out of the box and check out the terminal see if they are worn
Sep 24, 2012 | Samson dB1800a Subwoofer Speaker
Fuses keep blowing on my Samson Servo 120a
If after putting in the right rating of fuse you have a blow out, then you must diconnect the speakers and test. If the fuse hold ok then the speakers must be checked for shorting or fault in the network. However if the fuse still blows off, then you will need to take out the cover to test within the main board for the power section or output section malfunctioning. First of all discconnect the power to the output stages and test, if fuses blows check the powersuppy section, the rectifier to the main capacitors for reduced values. If not check on the output stages, the drivers, the predrivers for malfunctioning. However you will need some knowledge of electronics to probe stage by stage to isolate the fault.If not get help to proceed. Good day
Aug 03, 2010 | Samson Servo 120 Amplifier
Hi There the fuse just blew in one of my Samson
Hi there
To answer your question;
If it is not indicated near the fuse holder then look closely at the metal end caps of the fuse.
The value will be written on one of them,
It may look like 2A/250v for 2amps.
Hope this help
Cheers
Jun 14, 2010 | Samson Resolv 65a Main / Stereo Speaker
My tweeters are blown on my Samson Resolve 65a monitors...anyone know what I should get (and where) to replace 'em?
It might tell you on the back of the tweeter what rating they are. I should do a webserch for Samson spares and see what it comes up with.
Feb 02, 2010 | Samson Resolv 65a Main / Stereo Speaker
Samson Rubicon 5 Studio Monitor speaker is Popping
It seamns like its pretty commom =(
We should organize and complaint with samson!!
Read this:
http://www.gearslutz.com/board/low-end-theory/314545-samson-rubicon-r5a-problem.html#post5794093
Mar 12, 2009 | Car Audio & Video
Samson Resolv 65a monitor repair
Its prob a dry solder joint problem.
Jan 14, 2008 | Samson Resolv 65a Main / Stereo Speaker
Samson Resolv 65a Speaker - No Power!
There's a fuse input just underneith the mains input plug.A small screwdriver will open the small latch.You can get new fuses at Maplins.
Jan 07, 2008 | Samson Resolv 65a Main / Stereo Speaker
Samson dB1800a Subwoofer Speaker Logo
18 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
