Question about Samson dB1800a Subwoofer Speaker
Does samson db1800 have a fuse for speaker
Does samson db1800a have a fuse to protect speaker
Samson SX1200 - Protect light on. No blown output transistors.
Have you checked the power supply section? Also look out for any IC's in the amp stages. They can go causing that kind of fault.
Oct 11, 2014 | Samson SX1200 Amplifier
Samson db1800a stoped working
push on the speaker lightly to see if it moves in and out easly if not the speaker could be blown if thats ok pull the speaker out of the box and check out the terminal see if they are worn
Sep 24, 2012 | Samson dB1800a Subwoofer Speaker
Something blew-up in the speaker cabinet. it turns out it's the protective lamp overload. May I know if you carry that? Thank you
Usually that lamp part ONLY protects the tweeter. If the woofer doesn't generate sound, then you probably blew the speaker as well. This speaker is rated at 250 Watts PROGRAM... that means your amp you drive this with should be no bigger than about 150 Watts RMS or you can blow the speaker. You should be able to get reasonable sound for a 20 foot square room with this unit.
Aug 09, 2011 | Samson RS12 HD PA Enclosure
Every time I use Samson xpl amplifier It shuts off after playing for about 10 minutes do you think what's the problem?
Heat.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Mar 06, 2011 | Samson Servo 300 Amplifier
I have a s1500 samson amp I keep blowing speakers, what can I do to prevent this from happing again? The speakers that blown first was two 12'' yorkville 350 w impedance 8 ohm, the next speakers that blown...
Turn the volume down? Feed it cleaner source material?
http://s3.amazonaws.com/samsontech/related_docs/s1500_s2000_manual.pdf
You don't say under what conditions you're blowing them or if any of the informative indicators are warning you of impending doom. The Samson is capable of cooking just about any home speaker.
The following conditions will cause the Protection LED to go on:
Initial power-up: For approximately five seconds after initial power-up, the
protection circuitry is activated and the speaker output is muted. If everything is
operating normally, you will hear an audible click at the conclusion of this brief
period, as the protection circuitry is deactivated and the S1500 / S2000 begins
delivering signal to connected speakers (at which point you'll hear a click). It is
normal for the Protection LED to fade gradually after the amplifier is powered off.
Overheating: A temperature sensing device in the S1500 / S2000 will cause
the protection circuitry to be activated (and the Protection LED to go on)
whenever the operating temperature of the unit rises above a safe level. To
guard against this problem, make sure the S1500 / S2000 receives adequate
ventilation on all sides and that both the front and rear panels are unobstructed.
Severe overcurrent conditions: This occurs whenever the signal being input to
the S1500 / S2000 rises to a level above 20% THD (Total Harmonic Distortion).
Shorted speaker cables: This will occur if, due to faulty wiring, the hot and
ground signals being output by the S1500 / S2000 short one another.
Output impedance drops below 2 ohms: This can occur if the S1500 / S2000
is connected to inappropriate speaker systems (see the "Setting Up and Using
Your S1500 / S2000" section on page 5 in this manual for more information).
DC voltage detected at speaker output: The most likely cause of this is an
internal failure.
In general, any time the Protection LED lights up (other than during the
approximately five seconds following initial power-up), there is reason to be
concerned. If this occurs, turn the S1500 / S2000 off immediately and carefully
check all wiring and external devices in order to locate and correct the condition
that caused the LED to light up in the first place.
For further assistance, contact your local Samson dealer. If purchased in the
United States, you can call Samson Technical Support (1-800-372-6766)
between 9 AM and 5 PM EST.
Feb 07, 2011 | Crown XTi 2000 2-Channel Amplifier
Hi There the fuse just blew in one of my Samson
Hi there
To answer your question;
If it is not indicated near the fuse holder then look closely at the metal end caps of the fuse.
The value will be written on one of them,
It may look like 2A/250v for 2amps.
Hope this help
Cheers
Jun 14, 2010 | Samson Resolv 65a Main / Stereo Speaker
Samson Resolv 65a Speaker - No Power!
There's a fuse input just underneith the mains input plug.A small screwdriver will open the small latch.You can get new fuses at Maplins.
Jan 07, 2008 | Samson Resolv 65a Main / Stereo Speaker
Samson sx1800 power surge
Hi There,
Manufacturers install protection devices in their audio systems that are there for that purpose, any loud 'thump' or 'crack' trips the protection device so the loud speaker wont be burnt out. Speakers are expensive so the manufacturer does his best to allow you to listen to very loud sound and yet provided protection in case you exceed the sound rating of the output protection device.
In your case it sounds like the protection device has done its job but has not reset, to allow more listening...
Check the operational manual that came with the amp system to see if there are re-set instructions available to you....
If you dont have the reset detail, then phone/e-mail the manufacturer to obtain the reset information...
If there is no resetting you can do as a consumer then it should be no problem for a service shop to do the reset for you...
It may be a simple internal fuse that has blown but if its not accessible from the outside then I dont suggest you go inside and make changes unless you are skilled and trained in electronic servicing...
Cheers for now YUBEUT
Oct 31, 2007 | Samson SX1200 Amplifier
Samson dB1800a Subwoofer Speaker Logo
23 people viewed this question
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Umali
Vito Vacirca Jr.
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
