Question about Oregon Scientific Oregon Gator Mulcher 3-N-1 Blade For 42-Inch Model LT1042 Cub Cadet Lawn Mo
Cub Cadet Riding mower Lt1042 how to remove front tire
The tire just came off of the rim while I was riding it. How do I remove the rim so i can get the tire back on. The front wheel rim is covered by a black plastic cap that won't come off
  • 6468 Answers
SOURCE: How do I remove a tire from the front of my Cub Cadet Lawn Tracror LT X1040 to get the flat tire fixed?
there is a clip behind the little hub cap but older units it might be seized on in that case i change the tire right on the tractor leaving the wheel on
Posted on Apr 06, 2012
  • 708 Answers
SOURCE: RIDING LAWN MOWER STUCK IN GEAR
Have someone to rock you while you attempt to move gear shift. Hopefully it is only stuck between gears and will disengage. Your grease in gearbox may have become hard causing problems. If you wash the gearbox with water when hot (after mowing) You may have created moisture in gearbox causing major damage to transmission.
Posted on Mar 28, 2009
  • 708 Answers
SOURCE: I need an owners manual for a cub cadet riding
Go to following site http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10051 Then type in model LT1042 and check your serial no. again as I could not get it to come u.
Posted on Mar 31, 2009
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Posted on May 26, 2009
SOURCE: riding lawnmower starts but will not continue stay running?
its probably in your ingnition switch, grab the switch and turn it right the turn key I had the same problem and that fixed it. It also wasnt starting and it was the same problem the switch is lose.
Posted on May 31, 2009
Freeing up wheels on front and rear of 1955 210 post
hey Mike,
If the wheels will not rotate, its time for their removal..pull of the dust cover, remove the cotter pin,remove the axle nut, then pull the tire/wheel off...if its rusted on, you may have to use a DEAD BLOW hammer to the edge of the rim .. a metal hammer WILL damage the rims..USE JACK STANDS TO HOLD THE VEHICLE UP - DO NOT TRUST A HYDRAULIC JACK WITH YOUR LIFE!
.. remove each tire/wheel and replace the wheel bearings and seals, then check the brake shoe quality and operation... repair as needed..
Sep 10, 2017 | Cars & Trucks
How do you get the tire off a 2005 Dakota once the lug nuts have all been taken off.
Hi Richard:
These can be a PITA!
The diameter of the centre of the wheel can be a nasty tight fit.
Here's a couple of techniques:
- Old brute force trick......... use spare tire as "pendulum" hammer and smack the stuck tire... front.back.front.back
- If front tire, turn all the way to side being removed.... but block of wood between rim and frame.... turn back against rim.
- Put lug nuts back on leave slack. Lower vehicle back to ground and drive slowly forward and back. If front tire, turn back and forth.
Sometimes this will loosen them
- If rear tire, slide 4X4 across from under vehicle. block so it is against rim, then smack 4X4 with LARGE sledge hammer.
- Some people apply heat to the centre of the wheel where it is jammed. I don't like doing that.
BRUTE FORCE is much more satisfying.
Cheers.
Nov 08, 2015 | Cars & Trucks
What are the wheel and tire sizes front and rear for my 99 1200 sportster?
Fitment for 1999 XL Tubeless Cast Wheels:
Wheel Position and size = 19 inch Front; Rim Size and Contour = T19x 2.15 MT; Rim Valve Hole Diameter = 0.45 inch; Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16 x 3.00 D; Rim Valve Hole Diameter = 0.35 inch Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 100/90-V19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16x3.00 D; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 130/90-V16
Tire Fitment for 1999 XL Tube Laced Wheels:
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Tube Size = MJ90-19 Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16 x 3.00 D ; Tube Size = MT90-16; Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 21 Inch Front; Rim Size and Contour = T21x215 TLA; Tube Size = 3.00 x 21; Tire Size = Dunlop Touring ELITE II MH90 - 21 56H
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16x 3.00 D; Tube Size = MT90-16; Tire Size = Dunlop Touring ELITE II MT90 - B16
Tire Pressure - All Models:
Cold up to 300 Lb. Load (includes rider, passenger and cargo)
Front = 30 psi (2.1 bar)
Rear = 36 psi (2.5 bar)
Up to GVWR maximum load
Rear = 40 psi (2.8 bar)
Jul 07, 2014 | 1993 Harley Davidson XLH Sportster 883
Riding metal rail and back tire popped
You need the unbolt the wheel from the frame; there are two visible bolts on either side of the wheel in the center of the spokes. When the wheel is loose enough remove the chain from the back gear and remove the tire off the rim. You can either patch up the tube inside the tire (and the puncture on the tire itself) or replace it.
Aug 05, 2013 | Cycling
Change tire on dyt4000
the cover just pulls off there is a clip under there that holds the wheel on and a lot of time the wheel gets stuck to the axle and then i change them right on the mower
Apr 22, 2012 | Garden
I have a cub cadet rzt50 mower...Need to replace a tire
There is a thru bolt, and inside and outside bushing, and center sleeve. Remove those to remove the wheel. Obviously support the frame on a jack. Most tires can be removed using a slight soapy solution and 2 smooth screwdrivers. Replacement, use a soapy solution around the bead, and using only hand pressure put the tire back on. Use a cinch strap around the center of the tire to help keep the tire beads against the rim and air it back up.
Apr 15, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
How do you change a innertube on a back wheel of a mountain bike
You have to remove the entire wheel from the bike. Then change it just like you'd change a front tire... remove oneside of the tire from the rim, pull out bad tube, clean rim, put in new tube, put tire back on rim, inflat tube... good to go. There are 1,000,000 videos on YouTube to show you this process.
Nov 08, 2009 | Bike Extreme Lite Youth Shoulder Pad
BMW X-3 Front tires will not come off. All lug
buy some liquid wrench and try to spray it behind the rims the best you can and let sit for at least a half an hour. and maybe buy 2 new front rims. because the sledging might make the car shake.
Oct 12, 2009 | 2002 BMW 3 Series
How do you remove the front tire from a Honda crf 150 cc dirt bike?
The axel has a nut on one end and two bolts or one pinching the shaft on the other. Jack the wheel off the grond unscrew the nut loosen the pinch blots pull out the axel and the wheel falls out Watch wher the spacers go as they have to go back turned the right way. the brake rotor has to be lined up with the caliper to put it back in as you don't push the brake with the wheel off as the pads will have tobe pried open to get the rotor back in. Tring to fix a flat? same as a bicycle except use soapy water don't forget to use water to cheak for leaks then put on the powder on the tube before it all goes back good tire irons come from bike dealers and bike parts suppliers. Screw drivers cause more troble than thier worth. Road going bikes chage the tube patches are Illegal DOT
Aug 15, 2009 | 2005 Honda CRF 150 F
I would like to change the front tires lawn mower
Remove the wheel from the mower.
Let all the air out
Lay the tire flat
Push on the tire to release the grasp on the diameter of the rim (use a malet if ou need to)
Apply soapy water to the tire and rim
Insert a standard screwdriver between the tire and rim and pry the tire over the rim in one spot
Then work the screwdriver around the rim, pulling the rest of the tire up and over as you
go
Repeat the last step for the other side of the tire, same side of the rim though!
Viola, there you have it. Shade tree mechanic at it best. And NO labor cost$$$!!!!!
Mar 22, 2009 | Swisher 52" 20 Hp Riding Lawnmower #Zt2052
Oregon Scientific Oregon Gator Mulcher 3-N-1 Blade For 42-Inch Model LT1042 Cub Cadet Lawn Mo Logo
864 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
