Question about Microsoft MN-700 Wireless Router
Galaxy S4 wont connect to Microsoft MN-700 router
ohms
  • 1879 Answers
SOURCE: Connection to iMac not working
the easiest way is hard wire a windows laptop and use the CD that came with the router.
Posted on Oct 13, 2008
  • 3 Answers
SOURCE: new pc.. old router. not detecting internet
i'm using the MN-100 router right now and it works perfect with Vista! with DSL PHONE LINE
log into your base station(MN-100) defualt password is: admin
1. Make sure 'DHCP server' is set to 'Enabled'.
2. 'Network Mode' setting must be set to 'Routing mode'.
3. Works with Firewall enabled.
GO TO the page (Wide Area Network (WAN) Settings
enable: PPPoe-uses point to point protocal over ethernet
then below that enter user name & password same as you did the first time you used your DSL i include (MY)service name too(SBC Global) when done go back to home page click connect may take a min or two your done! after initial setup is done its fast and you dont have to put user name or pass in again either!
Posted on Feb 22, 2009
RickOz
  • 145 Answers
SOURCE: The driver of Microsoft MN-700 router
There is no driver required. Configuration of the router is done through your web browser. The address is 192.168.2.1. It would be best to do this via a cable connection as the wireless mode may or may not be enabled. If you do not have the users manual, here is a link to download it: http://download.microsoft.com/downlo...tion_guide.pdf
Good luck
Posted on Apr 17, 2009
clb199
  • 164 Answers
SOURCE: can't connect through microsoft mn-700 router when
From your very brief explanation, my first thought is that you may not have the wireless settings set up properly in the wireless router.
You will need to connect first with a lan cat5e or similar type cable to first connect with the router.
If you have already done this, then the problem may be with your network adapter in your computer.
unless I knew more specifics, your problem is to vague to help further.
Posted on Nov 27, 2009
Macs R We
  • 481 Answers
SOURCE: MN-700 just set up as WAP & lost web access to device
Routers typically assign themselves an IP address of the form xx.xx.xx.1. However, it is standard for a multi-functional device that can be configured as an access point to assign itself an IP address of the form xx.xx.xx.2 when configured as an access point, under the assumption that there will be a router on the same network with the address xx.xx.xx.1. So try accessing your AP via the "2" address and see if that does it.
Posted on May 16, 2010
I cant connect to friends on xbox live i have a microsoft mn-700 router
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then contact the Router manufacturer and Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
Dec 24, 2010 | Microsoft MN-700 Wireless Router
Can't connect through microsoft mn-700 router when hooking up trough cable modem
Nov 27, 2009 | Microsoft MN-700 Wireless Router
How do I manually add a device to my MN-700 router with a static IP?
The static ip address is set on the device itself, not the router.
You will need to make sure the ip address and subnet mask you specify for the device is in the same network range as the router.
Ex. MN-700 router IP Address 192.168.1.1
Mask 255.255.255.0
New device IP Address 192.168.1.5
Mask 255.255.255.0
If the new device is a pc, you will also need to enter the DNS settings provided by your ISP to be able to connect to services on the internet.
If you have any additional questions, please post a reply.
If you feel this information is helpful to you, please take a few minutes to rate this reply.
Aug 28, 2009 | Microsoft MN-700 Wireless Router
Lost password mn 700
  • call your router support to reset it to establish the default password
Aug 08, 2009 | Microsoft Broadband Networking MN-700...
Setting password
hi find the link bellow for the router and have a look in wireless security i believe page18
download.microsoft.com/download/B/6/9/B69C956C-85D9-4641-AA6F.../MN700_Base_Station_Configuration_Guide.pdf
Regards AL "alstech"
May 26, 2009 | Microsoft MN-700 Wireless Router
MN-700 needs constant re-setting
probably overheating u may need to get a new one. :(
May 24, 2009 | Microsoft Broadband Networking MN-700...
Good luck
Apr 17, 2009 | Microsoft MN-700 Wireless Router
Oct 13, 2008 | Microsoft Broadband Networking MN-500...
Getting dropped by the MN-700
try latest firmware update ok see if that fixes the issue microsoft.com site or custum windows update then re do settings u dont relly need 256 bit man ok 1268 fine with reg password
Mar 13, 2008 | Microsoft MN-700 Wireless Router (p5308j)
Open Questions:
See all Microsoft MN-700 Wireless Router Questions
Microsoft MN-700 Wireless Router Logo
43 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
