Question about Dryers
Dyer has power to motor but will not turn on,checked it with a volt meter.can't find any broken power in wiring.
86963100 kenmore dryer will not start
Check the door switch or start switch.
Posted on May 08, 2009
How can I fix my HE4 Gas dyer it will not start
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Jun 21, 2014 | Kenmore 659 Electric Dryer
Reset after power outage
Assuming this is a 220 volt dryer, are both sides of the breaker on? It should not blow only one side of the 220, but worth checking.
Jan 26, 2014 | Kenmore Dryers
We had an older dryer, and it got to the point that it would run a couple minutes, then quit. We bought a brand new Kenmore Elite dryer... model 110.64994300... and it does the same thing. We thought it...
if you have a volt meter u can check power coming in should b 220 volt put one meter leave on black wire an the other on red wire meter should read 220 volt an if u go front black to white it should read 110 votl u could have a bad outlet dose outlet look like it been burn if best if you dont know how read meter to just call your appliance repair service ok be safe an turn power off to dry b4 you start test it out ok hope this help you out
Jun 02, 2017 | Kenmore 64992 Electric Dryer
Circut breaker turned off and turned back on machine will no longer turn on.
Be sure you have 220 volts at the outlet. If you do check voltage on the power cord inside the machine. Be sure the timer is set correct and check the start switch.Does the motor run? If the motor runs and the drum don't turn may be the belt broken or slipped off the pulley. If motor don't run check voltage to motor if you have voltage most likely the motor is bad it can be checked with an ohm meter. Last resort could be timer. Hope some of this helps.
Jan 02, 2011 | Kenmore 64992 Electric Dryer
Amana electric dryer... M# NED5100TQ1 when I push start button the end of cycle buzzer sounds...what do you think?
check internally for a broken "drum belt", the "Drum- Belt" switch is controlled by the belt tensioner off the motor pulley and drum,if this belt breaks the unit cannot start due to this switch in series electrically,and shuts off the unit for safety, so as the drum cannot turn it cannot start not turning your laundry and catch your clothes on fire
Nov 27, 2010 | Dryers
May Maytag dyer Performa Model number PYE3300AYW will not start the light in the dryer is off i turned to turn off and on the breaker but nothing happens. My question is that if the light needs to be...
no the light has nothing to do with the dryer not running, sounds like a breaker issue. You will need a multimeter and some screwdrivers. first make sure that the breaker has power, you will need to take the front panel off, then with the meter check for your 220 volts at the breaker(where the wires are hooked up), next check for voltage at the outlet, if all these have power then it is in the dryers cord, you will need to move the dryer out and remove the plate and check for voltage, if it does then you will have to trace it into the dryer. Good Luck Tim
Nov 25, 2010 | Maytag PYE2300AY Electric Dryer
My kenmore electric dryer is not heating I checked the heating coil and it seems ok could it be one of the thermostats?
Kenmore style dryer - no heat problems:
Electric dryers - See the "how to take apart" section first if needed. Always check the power supply first...if one house fuse blows or 1/2 of the breaker trips, it is possible for the dryer to run with no heat. If you have a volt meter, you should read 240 volts between the red and black wires, 120 volts between the white and black and 120 volts between white and red, check for this at the main power connection. If you have 240 volts to the dryer, remove rear access panel, turn dryer on and test for 240 volts to the *heating element wire connections (#4). If you have 240 volts there and no heat = bad element, the element must be broken physically to be bad. If you have no power at the heating element, remove power, remove wires to the heating element and isolate them so that they can't touch anything. Reinstall power and check each wire for power from the wire to the dryer cabinet, one wire will probably show 120 volts and the other will show zero. Make note of the color or # of the wire that has no power, remove power to the dryer and check the wiring diagram that comes with the dryer to find out where that color or # wire goes to. EG: - wires might be yellow and red, if the yellow wire (example only) was the one that had no power, look at the wiring diagram to find out where that goes to and check only those parts, no need to check the other colored wire parts as they are working. Things to check are, *thermostats, timer contacts, selector switch, motor switch heat contacts ( 1&2 on the motor switch ) and *thermal fuse. If the wires to the heating element are the same color, just remove power after test and slowly follow that wire that has no power with your hand to see what parts it goes to. If live volt testing scares you, try the ohm checkinstead.
*#1-Thermal fuse that controls heat. If the dryer overheats, this fuse will blow. One shot fuse. Does not reset.
#2-Canister for the heater element.
#3-Hi limit thermostat. This thermostat is a safety thermostat in case the dryer severely overheats. When this safety thermostat is defective, it should raise a red flag for air flow problems.
#4-This is the terminals of the heater element that is inside the canister.
#5-Thermal fuse that controls motor run.
#6-Control thermostat. This is the thermostat that controls the cycling of the heater in high heat mode.
#7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jul 11, 2009 | Kenmore 62602 Electric Dryer
My electrical washer dryer stackable just quit working,neither 1
If the dryer does not start, you need to make a few observations in order to work toward a diagnosis. If the motor is humming or trying to turn but does not engage, check the following:
Make sure a garment or excess lint build up isn't stuck in the blower wheel, causing the motor to be physically unable to turn. If the blower wheel turns independently of the motor, or it is stripped on the motor shaft, you should replace the blower wheel. Inspect the drum support system, including the rear bearing, rollers, front glides or belt tension wheel for excessive wear, which could make the drum hard to turn. If the drum turns freely, and you have no obstructions causing any drag on the motor, replace the motor. The motor humming is usually an indication the motor is receiving proper power, but it is just unable to start on its own.
If the dryer is "dead" or you hear nothing when you push start on the unit, there are several electrical components to check. First, check the wall socket to make sure you have proper voltage to the dryer. An electric dryer should have 240 volts or two "legs" of 120 volts of power at the terminal block on the dryer. A gas dryer should have 120 volts of power at the receptacle in which it is plugged into. Once you've verified proper power to the unit, proceed with diagnosing the internal components of the dryer. Use the wiring diagram on the unit itself with an electrical test meter to take the guess work out of the diagnosis.
Check the door switch. On the frame of the dryer where the door closes, there is a door switch that should “click” when actuated. This doesn't absolutely mean the switch is good, but if it doesn't “click” it's probably bad. You can test the switch for continuity with a volt/ohm meter.
Check the push button start switch to make sure the contacts are closing properly when the switch is depressed. You can do this with an ohm meter with the wires removed from the switch. If this function is done through the timer, you can check the timer contacts used for this purpose in the same manner. If the motor only runs when the start switch is pushed the motor may be plugged with lint or it may have a bad winding. When a motor has a bad winding it will not stay running once the start switch (or timer) is released.
Most dryers built in the last 10 years have one or more thermostat-like parts that will shut down operation if the dryer overheats. These "one time" thermal fuses are located on the heater housing or on the blower housing inside the unit and must be replaced once they have been tripped. More importantly, you need to determine why the unit has overheated before you resume operating the dryer. Check the venting to make sure it's clean all the way to the outdoors and that it's as short as possible. Also, use a thermometer to check the outlet temperature of the dryer. If it is overheating, replace the control thermostat used for that cycle. A heating element that is touching the frame or cabinet can provide constant heat, even when the control thermostat has cycled off. So be sure to inspect the element for any grounds or shorts.
When all the components listed above seem to be in working order, you either have open contacts in the timer not supplying power to the motor, or the motor itself has an open winding. On occasion, you may have a burnt or broken wire causing the failure. Inspect the wiring around the motor area.
TheRepairGuru --- www.repairclinic.com
http://www.repairclinic.com/Dryer-Parts
Jan 26, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore gas/electric dryer
theordis:
When you say electrical power is working Ok ,I would assume you are saying this because the dryer is tumbling.
Which could mean you are only getting 120 volts to the unit but it will not heat with out 240 volts.
If you are getting 240 volts.
You could have an open thermostat, an open heating element. A bad timer contact or a open switch on the motor.
All these can be tested with a Volt-Ohm meter.
((((The Electrical supply must be turned off and at least one wire dissonnected from the component being tested.
woodychoppers
Aug 13, 2008 | Kenmore 75944 Gas Dryer
Dryers Logo
61 people viewed this question
Top Dryers Experts
