Question about GE JES1290SK 1.2 Cu. Ft. Countertop Convection Microwave Oven
JES1290SK No motor or inside light when turned on. Display works. Light works until turning on unit.
    Top Expert:
  • GE Master
  • 12,223 Answers
Please see the steps and fix it. God bless you
  1. Inspect the power cord Unplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switch If your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fuses To determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motor Locate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Posted on Nov 27, 2013
Why does light comes on turntable turns when door opens nothing lights on display or nothing works ?
Normally faulty micro switch which needs replacing: Caution: hight voltage may be present so best left to service person
Jul 23, 2014 | Oster Microwave Ovens
JES1290SK No power when on. Display works, work light works until enter is pushed. No motor movement
Does the convection work? If so likely you need a magnetron If the control panel is having problems then it needs to be repaired or replaced. It could be just a stuck relay inside so a firm hit may release it
Nov 27, 2013 | GE JES1290SK 1.2 Cu. Ft. Countertop...
Microwave timer works but will motor will not run/cook.
If everything works on the unit, but you do not receive any heat or possibly the turntable does not turn you have a faulty magnetron (controls heat) and a faulty motor (controls turntable). You would require service on the unit, if parts are available. Some microwaves are so small in cubic foot size, that manufacturer's do not have parts available for purchase/repairs.
Dec 24, 2012 | Frigidaire FMV156DC Microwave Oven
GE JES1290SK microwave magnetron is arcing
I don't know about a recall, but if your unit is under warranty parts and labour are included in most cases.
Sep 03, 2012 | GE Microwave Ovens
I have a JVM1850 that was installed 4 years ago. The unit was working fine, then a day ago I received an error display requesting a charcoal filet replacement. No filter is needed since it is vented...
I have a JVM1850 White microwave-over the oven-installed 3 years ago. Last evening the unit would not turn off. The inside light and fan continued to run, however, the microwave was not working.
All the controls and functions seem to operate, but when completed, the unit remained working, as stated above, with the door opened or closed.
Sep 18, 2011 | GE JVM1850 1000 Watts Microwave Oven
The display works (clock, mode, etc) I can push
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Apr 27, 2010 | Whirlpool GH9176XM Microwave Oven
I need the glass turn table asap. and how much does it cost? for jes1290sk
http://www.searspartsdirect.com/partsdirect/showPart.pd?partNumber=WB49X10174&productGroupId=0022&supplierId=364&brandId=0432&documentId=G0606370&keySuffixId=NA&modelNumber=JES1290SK02&keyId=1508&pageId=00001&productTypeId=0123245&searchModelNumber=JES1290SK02&subCompDesc=Microwave&brandDesc=GE&modelDesc=MICROWAVE&blt=11
Unless you can find one someplace else cheaper.
Eric
Dec 11, 2009 | GE JES1290SK 1.2 Cu. Ft. Countertop...
Hinari microwave doesn't cook
hello mam
i am having the solution for this problem check the lock terminals for loose connection and if its working and check the magnetron which produses the heat inside the microwave.
Sep 25, 2009 | Microwave Ovens
GE JES1290SK 1.2 Cu. Ft. Countertop Convection Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
