Question about Tally Intelliprint ML450 Laser Printer
Ml450 Service error 14 (next) CMU_CALL.C1226 printer stops printing Help
  • cheffint Oct 24, 2007
    Have tried another toner cartridge with the same effect. Any other advice would be appreciated.
  • 363 Answers
This is a PCL Interpreter Error.
Turn the printer off and on to clear. It could be caused by the user attempting to send a PCL character that does not exist in the printers PCL font table.
Is this happening all the time or only when you print a certain document?
Posted on Oct 24, 2007
  • 4,889 Answers
This could be due to 3 reasons
1. No toner cartridge installed or cartridge not fully seated.
2. Missing sensitivity tabs.
3. Bad toner cartridge.
Check up these on these 3 and let me know
Posted on Oct 11, 2007
Oki B6250 Service Error 14....help please
I have an Oki B6250 ang keep getting a Service Error 14. When i clear all the documents pending it works but happens next time someone wants to print Its linked to 20 PCs
Nov 20, 2012 | Xerox Phaser 6100/BD Laser Printer
Printer displaying E 2 2
Hi hatti
The E22 is the error is displayed in Canon printers. And it relates to waste ink pad full. follow the correct instructions for perfect results.
Canon waste ink tank problem.
1. Change the waste ink absorber
2. Reset waste ink tank counter
Go to the service menu;
1. With the printer power OFF , press the Power button while pressing and holding the Stop/ Reset button.
NEXT
2. When the Power is ON, hit the Stop/Reset button 2 times while pressing and holding the Power button.
NEXT
3. When releasing the Power button and the Stop / Reset button , the printer will go into a service mode.
NEXT
4 When the ON-OFF lights in Green, hit the Stop/Reset button the specified number of times according to the function listed in below.
NEXT
Each time the Stop/Reset button is pressed, the LED lights in orange and green, starting with orange.
NEXT
Hit 4 times for waste ink counter reset.
The number of the Reset button pressing LED
0 time ... Green Power off
1 time ... Orange Service pattern print
2 times ... Green EEPROM print
3 times ... Orange EEPROM reset (EEPROM reset)
4 times ... Green Waste ink counter reset
On the end press POWER button to exit .
Take care.
Aug 23, 2011 | Office Equipment & Supplies
Canon MP640 has 6C10 error, I have used the service mode and restore button x4 to reset absorber counter, but this stops the error until you go to print - then the next document returns the same 6C10 error...
my canno mp640 will not print in black, have replaced the 521/520 carterages new also a new printhead, and stiil it will not print,yet it prints colors ok. can you help please
DD.
May 12, 2011 | Canon MP640 All-In-One InkJet Printer
I find the ip of my Copier Canon imageRUNNER 550, I love to network so that I print, I can do, thanks
Windows XP (also Windows 2000/NT4):
  1. From the Start menu, select Printers and Faxes. (Windows 2000/NT4: Start menu, Settings, Printers)
  2. On the left side of the window, in the Printer Tasks section, click on the link for Add a Printer.
  3. In the Add Printer Wizard window, click Next.
  4. In the Local or Network Printer window, select Local Printer. Uncheck 'Automatically detect and install my plug-and-play printer'. Click Next.
  5. In the Select a Printer Port window, choose Create a new port. From the Type of port list, select Standard TCP/IP Port. Click Next.
  6. In the Add Standard TCP/IP Printer Port Wizard window, click Next.
  7. In the Printer Name or IP Address field, enter the DNS hostname of your printer (ex: myprinter.chem.cmu.edu). The Port Name field can usually be anything you like (without spaces), like 'lp0' or 'print' or the DNS hostname. Click Next.
  8. Click Finish. It may take a few moments before the next window appears.
  9. From the Manufacturers list, select the printer model of the printer you wish to use. From the Printers list, select the model number of your printer, followed by the designation (ex: HP LaserJet 4000 Series PS). Click Next.
  10. If you are asked whether you want to keep an existing driver, select Keep existing driver, then click Next.
  11. In the Printer name field, put the DNS hostname of the printer. This is actually the display name of the printer for just this machine and can be anything, but it's a good idea to set it to the DNS name as a visual reminder that it's an IP printer that can be used from anywhere. Most IP printers also have built in web servers that display status information about the printer, so recording the DNS name here can be a reference to use when typing in the printer's web address, like http://myprinter.chem.cmu.edu.
  12. If this is the printer you will be using most often, select Yes to use this printer as your default printer; otherwise, select No. Click Next.
  13. If you are asked whether you wish to share the printer, select Do not share this printer. Click Next.
  14. When you are asked whether to print a test page, select No. Click Next.
  15. Click Finish.
  16. If you receive a message that a Microsoft digital signature was not found, click Yes to continue the installation.
  17. To check if the printer is working correctly, go to Start > Printers and Faxes. Right-click on the newly created printer and pick Properties, and choose Print Test Page.
Mac OS X:
  1. Find the printer's full DNS name using the instructions at the top of this page.
  2. Go to Applications, Utilties, Printer Setup Utility.
  3. Click Add.
  4. Select IP Printing. Some inkjet printers may install their own section, like 'hp IP Printing' or 'Epson IP Printing'. If so, select that instead.
  5. Leave the printer type at its default value of LPD/LPR
  6. In the Printer Address field, put in the full DNS name off the printer, such as myprinter.chem.cmu.edu.
  7. Leave the queue name blank.
  8. Select the appropriate printer model. (If your printer model isn't listed, download and install the OS X driver for your printer from the printer vendor's website and go back to step 2)
  9. The display name of the printer can be anything, but it's a good idea to set it to the DNS name as a visual reminder that it's an IP printer that can be used from anywhere. Most IP printers also have built in web servers that display status information about the printer, so recording the DNS name here can be a reference to use when typing in the
Apr 16, 2011 | Canon imageRUNNER 550 Printer
I printed all the pages I wanted and stopped the printing. today I want to print something else and it wants to prin about 30 pages I don't want, help
Hi
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Apr 14, 2011 | Office Equipment & Supplies
Error code E27, ink absorber is full. Call service.
Follow these steps :
1. Unplug the power cord
2. Press and hold down the Stop / Reset.
3. Insert the power cable
4. Press and hold down the power button (the button Stop / Reset fixed in press)
5. When pressing the Power button, then release the button Stop / Reset.
6. Press the Stop / Reset 2 times then release the Power button.
"Wait until the digit 0 appears in the display"
7. Press the Stop / Reset 1 time.
8. Press the Power button 1 time, the printer will print a sheet of paper.
9. Press the Stop / Reset 2 times.
10. Press the Power button 1 time, the printer will mecetak a sheet of paper
11. Press the Stop / Reset 3 times.
12. Press the Power button 1 time. (No printing)
13. Press the Stop / Reset 4 times
14. Press the Power button 1 time rather long and loose (to turn off the printers).
"If the printer still can not get turned off, unplug the printer power."
15. Turn on the printer.
16. E27 error message is gone & the printer is running normally.
Oct 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Printer Stopped Working
Check that norton allows access to the printer via the firewall as the printer talks to the computer as well.
Thanks J
Jan 03, 2008 | Brother DCP-7020 All-In-One Laser Printer
Tally Intelliprint ML450 Laser Printer Logo
95 people viewed this question
Top Tally Office Equipment & Supplies Experts
Alexey Krenvalk
Alexey Krenvalk
Computer Links
Vasil Hristov
Vasil Hristov
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
