Question about ViewSonic PJD6221 Projector
Dlp chip white dots - ViewSonic PJD6221 Projector
Need dplclipfor mitsubishitv
I saw a video for this once. The problem is the DLP chip. It has to be replaced. Replacement DLP chips can be found online. The screen has white dots because some of the mirrors on the chip are bad. Be sure to have someone competent replace it. No soldering is involved. Book and manual will come with replacement. The DLP chip is delicate.
Mar 28, 2014 | Mitsubishi WD65737 65" DLP TV
White vertical lines after changing dlp chip and lamp on Mitsubishi WD-65833. good picture in background.
had white dots on mine as well i changed the dlp chip and put it back together and got the white vertical lines i decided to check all connections and make sure the chip was locked in correctly
it was not locked in securely i reassembled and now problem solved picture looks brand new so always check connections before assuming its the dmd board
Aug 25, 2012 | Mitsubishi WD-65833 65" HDTV
White death DLP TV
White dots on your RPTV television are the result of the DLP chip being worn out. You can replace it very easily by buying a new DLP chip for just under $190 and installing the new chip. There is a very good forum over at fixyourDLP that offers tutorials for replacing the DLP.
http://www.fixyourdlp.com/2012/10/11/banish-white-dots-from-the-samsung-hl56a650c1-with-a-new-4719-001997-dlp-chip/
or for Mitsubishi
http://www.fixyourdlp.com/2012/10/02/install-a-new-4719-001997-dlp-chip-and-banish-white-dots-on-the-mitsubishi-wd-82737/
Jun 04, 2012 | Mitsubishi Televison & Video
Light bulb
White dot for DLP Projector TV is not because of the light buy. It is caused by aging DLP chip ( DMD Chip.) Your TV DLP Part should be the following image:
Check the post how to place it diy
May 04, 2012 | Televison & Video
What Causes the white dots on a DLP Mitsubishi tv?
the white dots (sometimes you get black ones too) are caused by a faulty DLP chip. you can find the replacement for your TV at the following website:
http://www.shopjimmy.com/dlp-chips/
Mar 20, 2010 | Mitsubishi WD-60735 Projection Television
I have a samsung HLS4266WX/XAA about 3 years old with white dots.
This is a known issue with Samsung DLP sets. Here's a link to the solution:
http://forums.cnet.com/5208-13973_102-0.html?messageID=3162774&tag=emfrnd#3162774
Jan 01, 2010 | Samsung DLP HL-P5663W 56" TV
Had one last week and now there are 6. they are
You get white spots inside the samsung DLP tv due to bad Digital Micromiror Device , or bad DMD board .
What is actually the problem is the DMV chip connected to this board . Inside this chip are 3 million tiny mirrors ,and when they physically get stuck , they either show black or white instead of a color
This is well know problem with SAMSUNG DLP...
The DMD chip is failing.If not under warranty expect to pay a few hundred to several hundred to get it fixed
The mirrors on the DLP chip are slowly sticking either fully open (white) or fully closed (black). The part that contains the DLP chip is the Light Engine. It is the most expensive part of the TV.Only the Samsung TVs has this issue.
Replacing the DLP chip and the micro mirror would solve this issue...
Pleaserate this solution,
Rnj VINODKUMAR
Nov 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I have white dots on the screen of my hsl4266wx/xaa?
If these dots are only seen when the picture is on I would look for the Optical Block to be causing it. Are the dots in the same place each time you turn it on?
Jul 17, 2009 | Samsung HLS4266 TV
White dots on my samsung dlp tv
Samsung DLP Projection Tv white dots may caused by DLP Chip. Change a new DMD Chip 19106143W. The post show you how to replace it step by step.
Your chip should look like this:
Jul 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
ViewSonic PJD6221 Projector Logo
23 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
