Question about Zanussi ZWF1230W Front Load Washer
Drum outer remove - Zanussi ZWF1230W Front Load Washer
Can the bearings in a hotpoint hv8b593g be renewed or is it a sealed drum
Don't know this precise machine but all I have worked on previously have not been sealed, the main outer drum normally comes out of the back after removing the drive belt and pully and unhooking from the suspension then separate the plastic outer drum from its two halves remove the inner drum and knock out the bearing, replace all in reverse order.
Aug 27, 2016 | Hotpoint Washing Machines
Replace bearings in drum
If this is a front load washer, replacing the back drum bearings is probably not worth it cost and time. It usually requires a complete strip down and removal of the complete outer tub and drum assembly.Once removed the outer tub has to be split in half to remove the spin drum. Rear bearing is sometimes part of the back half of the outer tub so that half will need to be replaced and possibly the rear shaft on the back of the spin basket. I have done a few and it takes 2 techs and about 4 or 5 hrs to do the complete job. Only worth the time and parts if still under warranty.
May 12, 2015 | Washing Machines
How do i remove the inner drum. there is a button or something in between the inner and outer drum that i need to take out
depends on what kind of washer you have? and no buttons but yes most use a tool called a spanner wrench to remove one big nut at bottom after removing the agitator
Apr 02, 2015 | Washing Machines
Drum rotating unevenly, squeaking
If the drum moves up/down side/side without the outer drum moving, bearings gone, replace. To check for clothing, which I doubt, remove front seal outer section, look around outer part, to bottom you probably find clip, prise apart, front back, not side ways, refit sideways
Mar 16, 2013 | Maytag MAH2400A Front Load Washer
Drum dirty. Need to remove drum and clean between outer drum and inner drum. Please advice procedure to remove drums from each other.
Instead of all thet troubel try running a hot 90 degree wash with epsom salts. Then do another 90 degree wash with detergent. Be careful for a while with the nesxt fer loads as some greases can take awhile to let go of the outer drum walls. Dont use fabric softerer and you wont have to do this in the future cheers
Sep 09, 2010 | Washing Machines
How do you remove underwire lodged between drum and outer case
hi to remove bra wire from between drums ? you might try this 1st ? if you diconnect water supply hoses and unplug power supply then remove rear panel from machine you will have access to the large rubber drain hose from outer drum down to discharge pump ? ok hose is held by spring wire clips both ends remove clips then hose you may find bra wire either in hose or close to drum drain if you need ? feel inside drom via drain hole ? or probe with a piece of coat hang wire ? you may even find the mysterious missing sock/ thong / etc when you disconnect the hose too?? any debri has to lay in bottom of outer drum and so a little patience will locate them using this method instead of removing the main front door sealto drum for access to same area also with rear panel off you can check belt tension ? hope this helps/inspires you ? best wishes from uk
Feb 26, 2009 | Hotpoint First Edition FEW12 Front Load...
CLUNKING NOISE - SOMETHING TRAPPED BETWEEN INNER & OUTER DRUMS?
Yes, there is something trapped between the inner and outer drum, you could try removing the sump hose from the bottom of the drum, this will give you more room to fish about than possibly removing the heater. If you do remove the heater, you may not get it back in, then you will have to fit a new one.
The sump hose is the large hose fastened to the bottom of the outer tub.
Dec 02, 2008 | Zanussi FJS1225W Front Load Washer
Blocked drum
Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and holds the drum. Check the outer tub port- open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port. Good luck !
Aug 31, 2007 | GE WHRE5260E Top Load Washer
Replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
Aug 29, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1230W Front Load Washer Logo
13 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
