Question about Procom ML300TBA Heater
PROcom md 300 tba bb burner and fan will not shut down automaticly
3 Suggested Answers
SOURCE: ProCom 300 Heater
need thermocouple for MN300TBA Serial # 3531907 where do I find one in Chattanooga, TN area
Posted on Dec 05, 2008
  • 188 Answers
SOURCE: manuel for btu model ml 300 tba procam heater
Here is a link to the manufacturers website... http://www.usaprocom.com/manuals.php?choice=1. You should be able to pull your manual off this site. If you are looking for parts you can contact Master Parts at 800-446-1446 or online at www.masterparts.net.
Posted on Jul 07, 2009
Procom propane heater works fine until the fan comes on then it shuts down, works fine with fan running if the front cover is off ??? anything??
Sounds like when the cover is on it over heats. You need more air ventilation. Check for dirty filters or screen. Check whole machine. Not sure if that's the answer. Good luck.
Dec 26, 2016 | Procom Heating & Cooling
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
Ventless wall heater shuts off during operation
Sounds like thermostat may have a battery going bad as to not supply sufficient power to turn on the relays. As safety procaution when a signal is weak or no longer detected the heater shuts down.
Nov 16, 2017 | Procom Heating & Cooling
Can I turn the burner down low so it does not heat up too fast. The built in thermosat does not shut it down untill it gets 10 to 15 degrees abouve the setting.
If there is a flame adjustible control knob allowing you to do so, than yes. You should not cut back gas presure at a gas shut-off valve. Metering the gas in like this could possibly create C/O. from incomplete combustion and lack of primary air.
Jan 31, 2011 | Procom ML300EBC Heater
Fire lites as long as valve knob is held in but shuts off if I release the valve knob
Sorry to read about your problem, I hope this helps you out.
i will assume you are talking about the pilot lite...if so you have a defective thermocouple
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Heating & Cooling
Manuel for btu model ml 300 tba procam heater
Jan 14, 2009 | Procom ML300HGA Heater
ProCom 300 Heater
got mine from Guadlupe Gas www.guadalupegas.com 830-606-1877 New Braunfels Tx 78130
Nov 01, 2008 | Procom ML300TBA Heater
Heater will not stay lit on auto procom ml 300 blue flame
If you have an ML300HGA, it is a manual-control heater, which means you turn it on and you turn it off. No thermostat. It does not have an AUTO setting.
Likewise, the thermostat-controlled models do not have a Manual mode. If you have the ML300TBA, it has a thermostat and will turn itself on/off in order to maintain a room temperature.
On manual models, the numbers (if any) on the dial are heat output selections. Set the control to the highest heat setting and that's what it does until you turn it off.
On automatic thermostat models, the numbers on the dial are temperature selections. Set the control to the highest heat setting and the heater will continue running until it is 85-90 degrees, then shut off. Set it around 2 and it will maintain a temp of around 70 degrees.
All Procom heaters are either automatic (thermostat-controlled) or Manual. None are both.
Oct 05, 2008 | Procom ML300HGA Heater
Heating & Cooling Logo
59 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
