Question about Exercise & Fitness
Precor brake error 50 - Exercise & Fitness
  • 914 Answers
Precor Error 50, Too Much Brake (Magnet) Current Probable Cause 1. Shorted or damaged wiring between the lower PCA and the eddy current magnet is the most common cause for this error.
2. Bad eddy current magnet.
3. Bad lower PCA.
Corrective Action
  1. Thoroughly inspect the eddy current wiring and connections ensuring that the wires are not shorted to the frame or shorted together. Repair or replace damaged wiring as necessary.
  2. Disconnect the wires from the eddy current magnet. Using an ohm meter, check for approximately 100 ohms across the eddy current magnet terminals. If the reading is considerably low, replace the eddy current magnet. Measure ohms between each eddy current magnet terminal and the frame ground. You should have no resistance between the eddy current magnet terminal and the frame ground. If resistance is present this would indicate a partial short, replace the eddy current magnet.
  3. If the eddy current magnet wiring and the eddy current magnet are both good from the above tests, replace the lower PCA.
Error 50 Too Much Brake Current on Precor Cardio Equipment
Posted on Feb 11, 2015
3 Suggested Answers
bwinton
  • 83 Answers
SOURCE: what is error 50 on the precor efx546
Precor uses the same error codes for all of their units. Error code 50 is for excessive brake (eddy current magnet) current.
Posted on Mar 19, 2010
maxtreadmill
  • 832 Answers
The problem maybe lower board related or improper signal is being translated Call Precor @ 800-347-4404
Posted on May 14, 2010
How to fix error code 50 on EFX 5.21i?
3. Bad lower PCA.
Corrective Action
May 22, 2014 | Precor Exercise & Fitness
Precor elliptical
3. Bad lower PCA.
Corrective Action
May 22, 2014 | Exercise & Fitness
Precor error 3
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 03 E03 EEPROM Test Error
Feb 22, 2014 | Precor Exercise & Fitness
Codigo de error
List of Error Codes for Precor Fitness Equipment
Error Code List for Precor Fitness Equipment
Feb 05, 2014 | Precor Exercise & Fitness
Error41
Precor Error 41, Lift has not Responded in Acceptable Time Probable Cause Error 41 was present in early software versions and is no longer being used.
Corrective Action If you encounter a unit that has software with an error 41, diagnose the same way you would if getting an error 40.
Precor Error 41
Jan 29, 2014 | Precor 9.21 Treadmill
Precor error code 1
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on Precor Error Code 01
Aug 18, 2013 | Precor 9.21 Treadmill
Error code 1 and 3 on my Precor 9.21s treadmill?
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
What is error 50 on the precor efx546
May 11, 2010 | Precor EFX 546i Elliptical Version 4
Mar 19, 2010 | Precor EFX 546i Elliptical Version 4
I have an Error message 50 coming up when iturn on my eliptical
3. Bad lower PCA.
Corrective Action
Jun 27, 2009 | Precor EFX 546i Elliptical Version 4
Exercise & Fitness Logo
350 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
