Question about LG Prada KE850 Cellular Phone
Speakerphone How can i engage the speakerphone when using the phone?
    Problem Solver:
  • 4 Answers
When the call is connected, press the Un-lock button and then the button at the bottom, in the middle of the touch-screen, looks like a speaker.... =) that turns it on... to turn it off, you un-lock again and press the same button again! =)
Posted on Oct 11, 2007
Speakerphone a 170 samsung
Use one of the steps : "Speakerphone" icon on the bottom Event Status Bar/ "Options" key and select "Speakerphone." / "Speakerphone" key on the right side of the phone/ center "OK" or "X" button on the navigational keys
If you can't turn off "Speakerphone" all the same, try to find the manual for your phone here Samsung Mobile user guides and owners manual
Nov 11, 2013 | Cell Phones
How do I turn speaker phone
    • 1 Press the green "Phone" key on the main screen of your iPhone. This key has a silhouette of a traditional hand receiver and is located on the bottom part of the screen.
    • 2 Begin to use your speakerphone by making a call or accepting a call from other participants. You can make a call by going to your "Contacts" list or activating the keyboard and dialing a number. Incoming phone calls can be accepted by pressing the "Accept" key underneath the caller ID.
    • 3 Activate the "Speaker" function on your iPhone when you are ready to use your speakerphone. This button is located above the caller's information and allows you to switch on and off with one tap of your finger.
    • 4 Put participants on hold while you use your iPhone speakerphone. There is a "Hold" key at the bottom of the calling screen that lets you speak to people without bringing callers into the conversation.
    • 5 Access your contact information over the Internet while you use your speakerphone. You can reach the main page of your iPhone by pressing the "Home" button if you are on hold. The iPhone does not allow you to play music or use other audio options while on hold because you are still on the phone.
    • 6 Adjust the volume level before you begin a conference using your speakerphone. There are volume buttons on the side of the iPhone that provide detailed control over speaker sound levels.
    • 7 Mute the speakerphone if you must leave your office or take a break from a conversation. The "Mute" key is available on the call screen and instantly cuts off your microphone and the speaker.
    • 8 Add new contacts to your iPhone that you have called on your speakerphone. You can go back to your "Recent Calls" list or the keyboard to find numbers to add to your "Contacts" list.
Read more: How to Use the iPhone Speakerphone ' eHow.com http://www.ehow.com/how_2080582_use-iphone-speakerphone.html#ixzz1LKkzVgm3
May 03, 2011 | Apple iPhone Smartphone
Phone turn off when speaker is turn on and it disconnect when it turns off
If it is the handset speakerphone, this usually means the battery is dying. The speakerphone uses more power than the regular phone, so when you turn on the speakerphone with a weak battery the handset will shut off and disconnect the call. You likely need a new battery.
Mar 23, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
I have Cisco 7060 phone and using corded Plantronics headset plugged in to the headset port. I experience problem that speakerphone has priority over the headset. When I enter the phone number on keypad...
There is, but these settings are setup in Call Manager, or Call Manager Express. I would see your systems admin to set the default priorities.
Aug 27, 2010 | Cisco 7960 IP Phone
Avaya 2410 speakerphone
hi
what you could do is duplicate the set-up of a working phone for the new phone and see if that works
to idle a phone use busy sta <extens> and release sta < ext>
May 22, 2009 | Avaya 4621SW
Cant get speakerphone to work on samsung sgh-c416
Here is how you activate the speaker phone:
  1. During a call, press the Options soft key to access the following: Loud Spkr ON/OFF: Allows you to enable the speakerphone option.
  2. Also, During a call, use the speakerphone key in conjunction with the left soft key to activate the speakerphone operation.
For both options use the volume keys (located on the left side
of your phone) to adjust the volume.
If neither of these methods work, then there is a problem with your phone.
Good Luck!
Aug 11, 2008 | Samsung Lands Phones
If the phone programming has been set to 2-way and you have reset the phone. Either by unplugging it and waiting for a few minutes then plugging it back in or from the idle state press the "MUTE" key and then dial R E S E T on the keypad. If after this it will still not work as 2 way then it is most likely a faulty phone.
Jan 24, 2008 | Avaya 2410 Corded Phone
Speakerphone Only
Heres The Answer, Use The Data Cable the Dash Came With And Hook It Up 2 The PC. That Should Fix this Issue Instantly
Dec 19, 2007 | T-Mobile Dash Smartphone
SPEAKERPHONE
The 6510H "H" phone is not a speakerphone. You can make internal intercom calls using a simulated speakerphone (H = Handsfree answer back) but you cannot talk to anyone on an outside call without using the handset. You would need a 6510S
Oct 01, 2007 | Toshiba EKT6510H Phone (Refurbished, One...
LG Prada KE850 Cellular Phone Logo
80 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
