Question about Canon PowerShot A610 Digital Camera
When camera is turned on you don't see any image
The camera seems to come on but there is no image of what you are seeing. looks like the shutter won't open
4 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: camera turns on but shutter does not open. green light comes on then it beeps twice and shuts down. You can view pictures fine though
You mean SD400 camera doesn't show any error sign and it just doesn't have live view to shoot picture?
If yes, its problem of bad CCD imager and Canon will provide free of cost repair facility for SD400 camera.
Click Canon CCD Advisory for details.
Posted on Oct 24, 2008
SOURCE: black screen when turn on camera, cant see
Try pushing the DISP button; otherwise, canon.com says it needs svc.
Posted on Apr 09, 2009
t00nz
  • 4738 Answers
SOURCE: Shutter won;t open
Are you talking about the shutter, or do you really mean the automatic lens cover ? Take a look at this first to see if this is what you meant. Make sure you read the comments also for additional tips. I don't think it will be necessary to open it up to fix it. Stick with the easy tips, they should work, especially if this is happening occassionally:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on Jun 05, 2009
Our camera seems to be okay but when i'm attempting to get picture, i can't see any image in LCD, is it the lens?
First try pressing the DISP or DISPLAY button on the back of your camera. If that doesn't help, try taking a picture with the screen black. Is the picture also black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 13, 2011 | Sony Cyber-shot DSC-S750 Digital Camera
Kodak M1033 LCD black. entire images on SD black. It powers on and makes audio. Flash works as does the the green light. In other words it seems everything works except viewing, taking, and saving...
It might be easily fixed. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 12, 2011 | Kodak EasyShare M1033 Digital Camera
My canon powershot SD 1000 will take outdoor pictures but wont take any with low light and the flash won't work. I see that someone else asked the same question but I can see what advice was offered
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Recommend trying the pencil tapping fix listed in the link. It worked on my SD1000 with the same problem.
Jun 04, 2011 | Canon PowerShot SD1000 Digital Camera
My s2is powershot camera works fine but it seems the lens will not open there is nothing in the view finder, it takes picture but it is black
Dec 18, 2010 | Canon PowerShot S2 IS Digital Camera
Shutter won't open/blaack when you look through lens
Your shutter may be stuck open... this will give the appearance of the shutter not opening as well as no image when you look through the viewfinder.
Open the back of the camera, as if you were replacing the film, and look to see if the shutter is open. If it is, you can probably see light coming through the lens when looking from the back of the camera.
If this is the case, you will need to find out why the shutter is stuck open.
Some cameras use a battery to activate the shutter, some cameras have a "bulb" setting that keeps the shutter open for long exposures.
Whatever you do, do NOT force the shutter... I might jiggle it a little bit to see if it will close, but I wouldn't recommend more than a slight jiggle.
While you have camera open, inspect the mirror. If the shutter is closed but the mirror is stuck "up" (to allow light to reach the shutter/firm), there is a chance that you would not be able to activate the shutter.
Aug 31, 2010 | Pentax Program Plus 35mm SLR Camera
My camera cant photoshoot on outdoors, everything that captured looks white. When I photo shoot in our house -- dark room, it seems fine, but WHITE HORIZONTAL LINES appear? I've already used it about 3...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. By the way, recommend trying the pencil tapping method described in this article for a stuck "open" shutter.
Jul 31, 2010 | Canon PowerShot A470 Digital Camera
A 620 canon camera iris does not open, photos seem
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 23, 2010 | Canon PowerShot A620 Digital Camera
When I turn my camera on I do not get any type of image on the fold out screen and I also just get a black screen with all the options I have chosen but I cant seem to see"through" the lens
May 21, 2010 | Canon PowerShot S2 IS Digital Camera
Stopped focusing properly. Now get only black when looking through view finder or on screen. other features seem to be working correctly
A stuck shutter is a common failure mode for some model digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Nov 13, 2009 | Canon PowerShot S2 IS Digital Camera
Seems to be o.k. with sounds and menu screens,but no image of pic shows in viewer,and no image is recorded when transferred to computer
Oct 22, 2009 | Canon PowerShot A530 Digital Camera
Canon PowerShot A610 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
