Question about Boss BV7334 3.2-Inch DVD/MP3 Receiver with 2 6x9-Inch 400W Speak
Having problems with my highs amp
I am having problems with this amp all cabels r ok i have extra cables and it does the same thing the problem im having is a hissing noise from the speakers and the amp is a 4 channel amp but all 4 channels are positive all 4 chanes only have 1 rca in put what else could i do? or doe i need to separte the rcas with the Y's and make them one?
  • 794 Answers
Use shielded cables.
BTW, how did you check the cables to determine that they are okay?
Posted on Nov 27, 2013
Have no spark, have replaced crank angle sensor, im told the ecm is ok,new coil, new ignition module, new rotor, can someone help me please 93 Jaguar xj40 4l
what about the distributor cap?? do you have a spark from the centre lead that comes from the coil??These vehicles also have a factory immobilisor ------ do you have power to one side of the coil??i have a 94 sovereign 4lt as well and a workshop manual somewhere ?? looks like i will have to dig it out
Oct 24, 2009 | Jaguar XJ Cars & Trucks
94 deville w/4.9 engine,surges @ idle & will also rev high,not idle down,when u stop. Do u think -bad ingine idle actuater ?
check gaspeddel cabels on throttel body see if they are hung up pull on both outer cabels ehile running car
Aug 03, 2009 | Cadillac DeVille Cars & Trucks
Pyle pla2170
The power cable and the rem cable need to have different power sources. The best thing to hook the rem. to is a power antenna wire, or if you don't have a power antenna, you'd need to hook it to the ign. or accessory wire.
Jul 31, 2009 | Pyle PLA2180 Car Audio Amplifier
My ethernet cable dosent fit. can i use a dsl cabel?
Your best option is to buy a new ethernet cable.
They aren't very expensive and you'll know for sure that you have the correct cable.
Jul 18, 2009 | Sony Playstation 3 (PS3) Console
Home theater with cabel
Assuming you've got an extra input on your home theater's receiver, it's pretty simple:
On the back of your cable box (assuming you have a cable box), look for "Audio Out", a pair of red and white connections.
Run a pair of audio cables from there, to an available input on your receiver.  That's all you need to do.
You should turn the actual television volume down, when watching TV through your home theater, as you may get a slight echo from the two audio sources.
Mar 17, 2009 | Durabrand STS92 System
NOKIA 6234 DATA CABEL
gday, you can buy the data cable and disk on ebay under phones, then go to accessories, then to data cable they come as a pair. cost about 7 to 8 dollars delivered. hope it helps. linz9000
Oct 21, 2008 | Nokia 6234 Cellular Phone
B&W PV1 Subwoofer
Make sure that your amp is putting out proper signal to the sub woofer.
If the feed from the amp is okay, the power amp and our the power supply in the sub woofer may have become defective. This will require to be serviced.
Jerry G.
Jun 13, 2008 | B&K AV 125.7 7-Channel Amplifier
Very low sound in main left chennel.
disconnect the cabel of left channel from your amp disconnect the cabel of right channel and put it in place of left channel if the problem goen your problem is in left speaker itself (cabel or speaker).if the problem excit the problem will be in amplifier output stage
Jan 28, 2008 | Yamaha DSP-AX1 10-Channel Amplifier
Protection light and nothing. ??
How about the speaker itself? This problem can be caused by a blown or defective speaker. If you disconnect the speaker wires from the amp, do you still get the protect light?
Mar 15, 2007 | Clarion APX401.2 Car Audio Amplifier
Boss BV7334 3.2-Inch DVD/MP3 Receiver with 2 6x9-Inch 400W Speak Logo
22 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
