Question about ASUS P5QC Motherboard - Intel P45, Socket 775, ATX, DDR3/DDR2, Audio, PCI Express 2.0, Gigabit LAN,
Cannot detect external sata hard disk
Using Asus P5Q PRO motherboard. Internal sata drives detected but not external sata hard disk using using esata cable connection.
  • Dan Todd May 11, 2010
    Did you go into set up and define the external hard drive? Lots of Asus boards automatically pick up internal hard drives but have problems with external ones. It could be the cable you are using too.
    Problem Solver:
  • 16 Answers
I would start by swopping the Internal Sata Cables around and check if that solved it.
If not then there's probably a problem with either the E Sata HDD Controller board or Even the HDD or the Sata cable going from the Motherboard to your input E Sata Port.It's a matter of elimination.
So Remove the HDD from the Enclosure and plug it directly into the Motherboard and see if thats picked up.If it is then the HDD is fine.If not, get it replaced and it might still be under warranty.Check with the manufacturer.Continue reading if the HDD is fine.
Then use the Sata Cable from another HDD and connect it straight to to the E Sata Enclosure and see if the Operating System picks it up,Make sure the HDD you removed is plugged back into the enclosure.If that doesn't work then the problem lies with the Enclosure itself and you should get it replaced.
If it does the the problem lies with the cable itself and you should replce that.
Hope this helps you out.
Posted on Mar 26, 2010
MY BIOS IS NOT DETECTING SATA hard disk, i system is not detecting SATA hard disk
When the system is booting go into the bios settings. The option for sata drive detection may need to be turned on there, once verifying that option is on save & reboot the pc and it should detect the sata drive.
Mar 14, 2011 | ASUS K8V-MX Motherboard
I attached my 640GB SATA hard disk drive on my asus p4v8x-x motherboard but my motherboard cannot detect my hard drive.and it gives me that message cant initiate the new hard drive , bios does not...
Your problem same as me, so to solve the problem I attached my 250 GB SATA hard disk drive by external connection via USB pug, hard disk can work properly, ok please try
Sep 17, 2010 | ASUS P4V8X-X Motherboard
Hi, I have a seagate freeagent external disk with 500 Gb capacity, I had long time without to use my diks, then when I tried to use, It doesn't work, the power source is Ok, but my disk it It doesn't...
is the hdd getting detected....??? if it got detected then format it and try to use... if it is not detected then, let me know, i shall assist you further...
May 17, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
As I stated earlier I have ASUS K8S-MX Motherboard, but when I connect IDE 80GB drive with 500GB SATA drive it does not detect my 4 SATA partitions, instead says it is only 500GB unformatted single...
Check your AHCI (or ACHI, can't remember) settings in your BIOS. Turn them off, use "standard pata mode" even though you're using a SATA drive, and try again.
Dec 18, 2009 | ASUS K8S-MX Motherboard
My computer can't detect my external harddrive..
connect the drive, go to disk management and check if the drive is there. change the disk letter.
Jun 23, 2009 | Seagate FreeAgent Pro 1TB External USB...
I have seagate 500gb hard disk which is not recognised by win xp what should i do
If using USB try it on another USB port, if on eSATA then try using USB to see if it will detect it via usb
Have you got another computer you can try it one just to ensure that the hdd is actually working ?
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Astone External Closure - Esata Troubles
Thank you for your question.
I will refer you to a previous excellent answer on Fixya by "map9966" on reducing the specifications of your SATA which I also suspect is of 2.0 genre.
http://www.fixya.com/support/t775563-system_won_t_recognize_sata_drive
On the next link you can download the manual for your motherboard which on Page 2 states that there is "complaints" with SATA drives on this board.
You need to research downgrading the "specs" of the Hard Drive you are using in the external enclosure.
Kind regards
Could you please take a moment to vote for both answers, it assists us in knowing that our answers are on track.
Mar 16, 2009 | EliteGroup P4M800-M7 Motherboard
SATA Raid card on PCI unable to detect eSATA Hard Drive
if you install the raid controller drive,it means it will shown the drives..but it not shown? is this what you mean? did you try to see in the computer management? if you dont know, check this out..right click my computer-manage-select disk management and check if your drive is there......this is only what i know about what you mean.
Mar 03, 2009 | Intel Motherboard
I have had to reinstall my operating system and drives but now the Seagate 500 GB external is not recognized. What now?
Are you using eSATA for the External or USB. If it is eSATA you may need to get the respective drivers for your motherboard for it.
Jan 30, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Asus motherboard cannot detect Seagate SATA drive
Does your internal speaker beeps or stops telling you there is no hd detection?
Try to put another hd.
If you are using Windows reinstall it.
Does the red light blinks
CHECK out the power chord to hd and all power connections from psu
Dec 11, 2008 | ASUS A8N-E Motherboard
ASUS P5QC Motherboard - Intel P45, Socket 775, ATX, DDR3/DDR2, Audio, PCI Express 2.0, Gigabit LAN, Logo
306 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
