Question about Acer Veriton S460 (VT.S4155.990ZE-B22) PC Desktop
Acer Veriton S460 keeps crashing - Acer Veriton S460 (VT.S4155.990ZE-B22) PC Desktop
2 Suggested Answers
  • 128 Answers
SOURCE: how to hide or eliminate
when you turn on your computer, certain application,drivers,services are automatically started at the beginning of every window session. you can disable certain application to shorten your computer's booting process by the following steps:
click Start then Run and type "msconfig" (without the qoute) then click OK
there would appear a System Configuration Utility window. On the upper portion, select the Startup button. there you will see the applications that are started during bootup. you can unmark the check box in front of an entry to disable it and the program will not be started the next time you start windows. just be careful to choose the programs that you do not need to start automatically. some applications are needed by windows in order to start successfully.After doing so, click Apply then Ok and you will be given an option to Restart your pc or to Exit without restarting. Hope this helps.
Posted on Oct 15, 2008
I have acer veriton s460 usb speed too slow
Is not a problem with your USB is a problem with your PC.Speed of device depends on your hardware and your amount of RAM to proccess some atsk.So if you had let say 1gb of memory it can be be not enough to process all you task as quick as you want if you had 4gb.
Mar 22, 2013 | Acer Computers & Internet
Will not turn on
probably bad switch contact or your power supply
is defective
Aug 03, 2012 | Acer Veriton S460 (VT.S4155.990ZE-B22) PC...
Cannot connect acer pc to tv
The PC and the TV need to have the same kind of connection such as VGA or HDMI. If not you will need some type of converter between the two to make them compatible. Once you have them connected set the TV's input to PC, Computer or HDMI if you use the HDMI connection. Reboot the computer and see if the image appears on the TV. If not you can hit the FN Function key on the computer + the F1 thru F12 key that corresponds to the External Display. The correct F1 thru F12 key to hit might have CRT/LCD on it or it might have the icon of a display. Press and Hold the FN key then hit the correct F1 thru F12 key that corresponds to the external display to toggle the display between the computer, the tv or show it on both the tv and the computer.
Apr 05, 2012 | Acer Veriton S460 (VT.S4155.830ZE-B22) PC...
Return to Factory Settings
Restart your computer now as soon as you hit the power button keep on holding Alt key & keep on tapping F10 key Alt+F10 it will open the recovery console select full factory restore and follow on screen instruction
(Note:this will erase all datas on the computer)
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps you
Feb 07, 2012 | Acer Veriton S460 (VT.S4155.830ZE-B22) PC...
Acer veriton 7500 display driver s download
Hello Kharak,
Please download the Acer Veriton 7500 display driver from the link provided below :
ftp://ftp.work.acer-euro.com/desktop/veriton7500/driver/win2k_xp14103.exe
Also visit the link provided below :
http://support.acer-euro.com/drivers/desktop/veriton_7500.html#driver
Jun 22, 2011 | Acer Veriton 7500 PC Desktop
Games Crashes
check the cpu temps.... use cpu-z
Apr 30, 2009 | Computers & Internet
Can't install service pack 2
that sometimes happens with a validation issue... make sure that you are using a valid license for the machine, there other reasons for that issue... however that is the most common
Robert
Dec 22, 2008 | Acer-Veriton-M410-US3800P AMD Desktop PC -...
Acer Veriton S460 (VT.S4155.990ZE-B22) PC Desktop Logo
14 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
