Question about Nikon COOLPIX L10 Digital Camera
I have a nikon coolpix starter memory card and went to put it into computer to print photos and it said it needed to be formatted and i would loose all the pics. what do i o and can i get the photos back if tey are deleted
No U won't get it. So before formating why don't u save it in the computer and then format.
Posted on May 08, 2009
Message memory full
If you've take photos and filled the card, you'll need to transfer them to a computer and then erase / format the card in the camera to free up the space on it. If that doesn't work - remove the card. With the contacts pointing up and away from you - looking at the label side - locate the tab on the left edge. Push it UP - away from the LOCK position. If it is loose, put tape on it and carefully reinsert into camera. Try to take pictures again.
Apr 14, 2014 | Nikon COOLPIX P90 Digital Camera
Camera Nikon S01. I only took 20 pictures. When I turn it on it says: Card is not formatted. Format card? Off course I do not want to format the card because I will loose the few pictures I got to take. ...
Note, the Nikon Coolpix S01 does not have a removable memory card. The memory is built in and this formatting error seems to be a common issue with this camera. There is a small reset button under the bottom cover where you plug in the USB data charging cable however pressing this button does not fix the issue that the OP is having.
I was able to get a 'stuck' S01 working by downloading Nikon's View and Capture NX software to my Mac and opening Nikon transfer 2 where I discovered a photo in memory. I downloaded and then erased this picture which appears to be corrupted and this allowed the camera to restart normally.
Then went through the Home screen to settings where I was able to successfully reformat the internal memory. It is entirely possible that hitting the reset button did help to some extent however once the camera was plugged into the computer and this image removed things seem to be working again.
Of note to the other techs answering this question the Coolpix S01 has 9GB of built in non removable memory used to store images, also the battery is built in. There are no user serviceable or removable parts to this camera, only the proprietary USB connection hiding under the cover on the bottom of the camera that terminates in a standard USB plug which can be attached to your charger or computer.
On a Mac the camera does not show up as a logical drive, it is only accessible through Nikon's software which is free to download from their website here, http://downloadcenter.nikonimglib.com/en/products/224/COOLPIX_S01.html
Aug 21, 2013 | Nikon Coolpix S01 10.1-megapixel digital...
Nikon coolpix l110 usb cable not connecting
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Sep 08, 2012 | Nikon Coolpix L110 Digital Camera
Nikon Coolpix S52C camera transfer pictures problem.
Sep 06, 2012 | Nikon COOLPIX S52c Digital Camera
The display shows that the card is not formatted..Format card ? How to solve this ? When I proceed to change the format.. It comments that the images will be deleted. I'm in need of those images.....
Aug 08, 2012 | Nikon Coolpix L24 Black Digital Camera 4gb...
I own a Nikon Coolpix 5700 and recntly I face a problem with the memory card, The memory card is Nikon Compact Flash 32MB and the camera shoes that I can have Basic 51 photoes, Noraml 26 Fine 13 and Hi...
Nikon Coolpix 5700 Digital Camera memory card failure:
This camera has capabilities which far exceed the data storage of a 32 MB memory card. Put what you can onto the Nikon Compact Flash card and purchase another, larger, 2 GB card for your other storage. This should easily meet both the needs of the camera and your own. The original card must have had data deterioration or a mistake was made in transferring the pictures.
Go to Google and download their Picasa App; it is great for anyone transferring their photography from one storage type to another and you can use it for publishing material to the Web or to your family group e-mail.
Please comment on the success of this solution!
Sciencewoman
Apr 15, 2011 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix L18 suddenly states that card is not formatted.
Sounds as if the card is corrupted - you will have to use data recovery software.
Aug 06, 2017 | Nikon COOLPIX L18 Digital Camera
Cannot format new memory card
The memory card sounds like it is not compatible with your camera what kind of memory card?
May 16, 2009 | Nikon Coolpix 4800 Digital Camera
Nikon digital camera malfunction
Hey jackie jean,
If the two year extended warranty you are talking about is a performance service plan purchased at a Best Buy™ store then you could bring the camera into a Geek Squad® precinct in a Best Buy™ store, and they should be able to send it out for service at no charge to you. I am assuming you formatted the memory card in the camera, but if this is not the case and you have formatted the memory card using your computer then I would suggest formatting the memory card in the camera. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 29, 2008 | Nikon Coolpix S51c Digital Camera
Nikon COOLPIX L10 Digital Camera Logo
59 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
