Question about Panasonic PanaFax UF-8000 Laser Fax
Sounds like drum squeeking, have to open and close front door to get even one page to print
  • 56 Answers
There is also the fuser unit that need regulare servicing because the majority of the squeeking comes from the fuser unit because of the generated heat.
Good luck
Posted on Oct 24, 2009
Got a new drum/toner, installed according to directions, but not getting the "replace drum?" or the "accepted" LCD prompt....
ur questions is not really complete, but let me help.
if u are using HL2130/2140 series series:
while the printer on
1. open the front door
2. press the only one button at the printer till all the lights on
3. let go the button
4. close the door
(to test print report- pres the button 3 times)
if u using dcp/mfc series
whilee the printer on
1. open the door
2. press the clear button
3. "replace drum?" press yes---dcp up arrow, mfc button nomber "1"
4. close the door, ready to use
the replace toner sign will appear every +- 12k pages. u dont have to replace the drum with the new one as long as the results is still good
once u perform that and after few pages (below 50pages). it means u need to change the corona wire
Mar 21, 2011 | Brother Office Equipment & Supplies
Printer does not move page fully thru rollers.
Rollers may look good but it sounds like they need to be replaced. You will need the separation and pick up rollers.
Printer Repair Service in Miami and Fort Lauderdale FL
Jun 06, 2017 | Dell 1600n All-In-One Laser Printer
Black text only printing dark on right side of page. I jsut put in a new black toner cartridge
My solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Feb 04, 2010 | Samsung CLP 300 Laser Printer
How reset drum page counter brother dcp-7040
This works for my DCP-7020, so it may work on the 7040.
If your drum is still good - take it out and put it back in - the trick is to LEAVE THE FRONT DOOR OPEN after you put it back in. With the door still OPEN push the "options" button and you will be prompted for "New Drum?" and then push the "Up" button for 'Yes' and "Accepted" will appear on the lcd screen - and then the drum counter will be reset.
Oct 20, 2009 | Brother Office Equipment & Supplies
I've recently installed a new Brother toner, but the drum light is flashing and the Brother hl 5140 printer won't print
DRUM UNIT "spent"
It can be reset if the printing quality is good
To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Caution: Reset the drum counter only when you replaced the drum unit with a new one.
Oct 09, 2009 | Brother HL 5140 Laser Printer
Need new drum for brother mfc-7220 all in one. Not even 1 year old. Is there something I can repair or fix instead of replacing the drum for about $100+ ?
If the print quality is still good, just reset the drum counter. Open the front door, press OPTION, press 1, close front door.
Oct 05, 2009 | Brother MFC-7220 All-In-One Laser Printer
HP p2015 printer has stopped printing
check inside the toner door on the right side. there should be a plastic tab which opens the laser shutter when the door is closed. if this is broken then the lase shutter will not open and will produce blank pages.
Jan 15, 2009 | HP LaserJet P2015 Printer
Drum light on after installing new drum
As posted by Songdancer - this solution worked for my HL-1440 to reset the drum light
"Brother's webpage says to reset the drum counter. On some models this is done by opening up the front door, pressing the GO button until all 4 lights are lit, then releasing the GO button"
Apr 30, 2008 | Brother HL 1440 Laser Printer
Brother HL-5240 drum light flashing
Normally clearing the drum count the machine has to be on open front cover as if to change the drum press and hold the button in for about 10 second then release and shut the door. This should reset the count if not please get back to me and I'll check the service manual to see if anything in that.
Thanks J
Jan 29, 2008 | Brother HL-5240 Laser Printer
Dell printer problem
Sounds like you may need to replace the pick up rollers on the machine.  Without knowing exactly where the jam error happens during the print process, it's hard to say.
Oct 19, 2007 | Office Equipment & Supplies
Panasonic PanaFax UF-8000 Laser Fax Logo
43 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
